Yanmar YM2000 Fuel Pressure/ hard starting
/ Yanmar YM2000 Fuel Pressure/ hard starting #222
That is weird.
/ Yanmar YM2000 Fuel Pressure/ hard starting #223
I always post from pc, not phone. I get those weird characters within text I am quoting. Obviously the apostrophe is encoded differently than intended.
You would think VBulletin (the software here) could properly interpret something that another poster wrote under VBulletin software in a prior post .... but no.
Oh well, I figure I’m good enough at inferring what people mean most of the time if that happens in their text.
Mocked up the YFL1500 cross member tonight on some wooden blocks to see how I am going to attach it to my YM2000BD. This is that loader I drug off of a parted out 336D.
The ends of the cross member tubes stick out to about the width of the rear tires, the bottom of the loader feet clamp around those tubes about an inch inward on each side.
I am going to bring some cardboard home tomorrow so that I can make some templates to cut out some 3/8” plate to make side supports that go from the cross member up to the 2nd set of vertical bolts on the tractor engine/frame area.
I will also use some 1/4” plate to make 2 brackets to mount to the 4 bolts under the transmission, and possibly later decide to run two pieces of square tube back to each side of the draw bar for extra strength.
/ Yanmar YM2000 Fuel Pressure/ hard starting #225
You need that structure back to the rear axle so you you don't split the tractor at the bellhousing.
I took this photo to show the old-guy step I added. (with oversize rear tires it is a narrow, high climb to get aboard). The photo also shows one of the members to the rear that alleviate the split-the-tractor stress at the bellhousing. The only stress there is simple downward weight.
67060d1167546453-old-guy-step-ver-3-a-p1050601rtractorstep-jpg
Is that the same bar pictured here?
Those of you with the loafers on a YM2000, how does it handle without having power steering?
I had a company tell me they wouldn’t sell me a loader because my tractor was too small basically to have one, the steering wouldn’t hold up and that my front axle would fall apart.
/ Yanmar YM2000 Fuel Pressure/ hard starting #229
We've seen that happen on here. I think one of the posters has broken spindles.
My (US model) YM240 is a YM2000 with green paint - but it has what is apparently is the optional loader-ready front axle. This axle is adjustable for width. I expect it is simply the axle for one of Yanmar's larger models.
I have never had a problem with the axle but both front wheels have been welded up, apparently after the hubs were nearly ripped out of them. And one of these welded wheels is clearly a replacement - it has '$20-' written on it.
I obtained replacement wheels during my initial renovation of the tractor when I bought it, but so far have only put one into service - when I had a flat tire repaired. I can't imagine what a prior owner did to rip the centers out of two wheels and then one replacement. Backing up fast with the wheels cramped then hitting a curb is the only thing I can imagine. I haven't had a problem.
Steering at a standstill is impossibly stiff with a big load in the bucket. Not too bad after you get moving. If a tight slow turn is needed, drop the bucket and power-down to get a front tire off the ground, turn as needed, raise the bucket and proceed in the new direction. This works fine for occasional loader use. If I needed a loader daily I would get a different tractor with PS and factory-matched loader.
142294d1255290189-tires-wide-stance-ym-oldfrontwheelsdetail-jpg
Well stated, and about how I feel about it as well.
Eventually I’ll probably build a smaller bucket for this loader, as I know it’s a bit oversize for this tractor, and its bottom is rusted out, and filled over with a steel plate.
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
2014 Lincoln MKX SUV (A59231)
2014 Lincoln MKX...
2014 Eager Beaver 50SL/3 53ft 60 Ton Tri-Axle RGN Low Boy Trailer (A59230)
2014 Eager Beaver...
Coats 1055 Direct Drive Wheel Balancer Machine (A59230)
Coats 1055 Direct...
2005 Chevrolet Impala Sedan (A56859)
2005 Chevrolet...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
