Yanmar YM2000 Fuel Pressure/ hard starting
/ Yanmar YM2000 Fuel Pressure/ hard starting
Like ST said. That huge back plastic knob under the seat, between your legs as your sitting on th seat you DO NOT want to mess with. It needs to stay all the way open or you can damage your system. If you close it you can dead head the pump, if you need it slightly closed t work something is not right in the system and your putting wear on the system that does not need to occur. That is the service lockout knob. It's used when you cut off the tractor to block off fluid flow in 3pt. It will lock up the implement when closed unless your O ring is bad hen it will still leak down. This is the way to tell if you have a bad valve or O ring in your 3 pt , if an implement leaks down.
Okay, well, then I definitely have an issue as I have to hold the handle back to keep the 3 point raised with the lockout valve all the way open, and the box blade on the back.
/ Yanmar YM2000 Fuel Pressure/ hard starting #202
Are you saying if you let go of the handle, the lever doesn't stay in position and falls foward?
/ Yanmar YM2000 Fuel Pressure/ hard starting #203
Do you have the Spring. I had a similar problem after I first bought the 2000. I have to keep pressure to the valve esp. When I am Raise position. Handle is forward "lower". You don't need any Spring pressure to the Valve. Lift it, Pull the handle back And set your Spring tension. So that way your keeping pressure at all times on the valve "Lift".... Hey been like this for over 10 yrs. and haven't had the first problem...Ghetto Rig I know but I have so much play in the Handle Linkage it would fall...
The lever will stay in position, but the 3point will fall.
Again, this IS with the box blade attached.
/ Yanmar YM2000 Fuel Pressure/ hard starting #205
Everything look like this or is something missing?20180930_171156.jpg20180930_171213.jpg20180930_171234.jpg
/ Yanmar YM2000 Fuel Pressure/ hard starting #206
Mine was Beat to **** and back. It may be common but I've never seen it. If you look at my Height Adj. on the Arm. You can see were it's been welded without a doubt. And mine won't work correctly with the Drop adj. that far back of the pin position in stsid1 Pic.
/ Yanmar YM2000 Fuel Pressure/ hard starting #207
Mine was Beat to **** and back. It may be common but I've never seen it. If you look at my Height Adj. on the Arm. You can see were it's been welded without a doubt. And mine won't work correctly with the Drop speed adj. pin that far back of the stsid1 Pic.
/ Yanmar YM2000 Fuel Pressure/ hard starting #209
This is what I was looking for the other day also. What you have should work. I think and pretty sure my Raise/Lower handle is all the way in down Pos.. You can see my drop Rate also it's pointing straight up. I haven't touched it in 10yrs. Truth.............
I have to put my Speed handle at about 1/4 open.
From there with the raise lower handle back, and the front open/close knob all the way open it will stay all
the way up with the box blade on the back as long as the tractor is running.
/ Yanmar YM2000 Fuel Pressure/ hard starting #211
If you cut off the tractor with the box blade raised, and it drops back down on its own, sounds like piston seal leaking.
/ Yanmar YM2000 Fuel Pressure/ hard starting #212
Mine drops also when it's not running. But slowly. Don't bother me. I lower everything anyways and if I want to keep it raised for Maint. etc. I'll lock it up and then it does stay..................;)
I agree, mine now doesn’t just fall, it’s a slowish decent when I turn the tractor off. I am not doubting there may be a seal leak, but it works well enough for me to be okay with its operation, and nothing too abnormal from other tractors I’ve worked with.
My project this week is figuring how to adapt the cross member from the 336D fitting YFL1500 front loader to fit my little YM2000BD.
After searching a few pictures and some sent over by California, I think I致e got a plan figured out.
Also, I致e found that the tach/hour meter cable did in fact break internally, so I am waiting for the new one to get here from Hoye.
/ Yanmar YM2000 Fuel Pressure/ hard starting #215
Glad to hear it's working ok and you found the tac problem.
/ Yanmar YM2000 Fuel Pressure/ hard starting #216
the arms will take the handle being almost all the way back to get the arms all the way to the top, but i will cram my top link into the ROPS structure long before that occurs usually and no more than 3/4 up is really ever needed with pretty much any implement to lift it high enough to be out of the way, where i leave the handle the implement stays. My valve is worn, i have replaced my big oring in the 3pt cylinder and every oring that i can when i took apart the valve, it just is what it is. Mine leaks when i turn the tractor off, the implement will slowly leak down. While running it does not move.. EXCEPT when i lift an item at idle for example and then throttle up to operating rpm it may move up an inch or so with the increase in fluid pressure. And the same when i am running and have it in the air and come back to idle it will settle down just a tad bit lower but happens so slow unless your watching where the arms line up on the tire or how many inches the deck is above the ground you wont notice it. THis is just how it is, i have talked to Steve and Aaron at HOye, they both said why does it matter your making an issue where there is none. Their point is it works, its a 40 year old tractor and some parts are just worn. Said when it wont work anymore then get a new one or a serviceable replacement. I just like things to work as designed was my response. Which is why i tore into it in the first place. The o ring was worn but just a tiny bit, it barely if at all leaked down with the service stop closed, but it did more of the up down with the engine rpms than it does now with the old one on. Now when the stop valve under the seat is closed it will stay up forever telling you that the 3pt is fine but when open it leaks down meaning that the valve is letting pressure out of it.
/ Yanmar YM2000 Fuel Pressure/ hard starting #217
what's with the weird contractions or the way that it printed them....the way it wrote "I've" is my guess?
/ Yanmar YM2000 Fuel Pressure/ hard starting #218
I thought it was Japanese or Chinese writing.
I have discovered this site does that repeatedly with contractions for some reason.
/ Yanmar YM2000 Fuel Pressure/ hard starting #220
Must be on a pc, never had a problem on my phone.
2014 Ford Explorer AWD SUV (A59231)
2014 Ford Explorer...
2018 MACK CHU613 (INOPERABLE) (A58214)
2018 MACK CHU613...
16ft x 8ft Flat Bed (A57454)
16ft x 8ft Flat...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2021 Chevrolet...
2014 REITNOUER MAXIMISER 48' FLATBED TRAILER (A59905)
2014 REITNOUER...
