Yanmar YM2000 Fuel Pressure/ hard starting
/ Yanmar YM2000 Fuel Pressure/ hard starting #193
Yea that sounds more right than 30. Since the headlights and anything else just dims them. Probably more like 15.
/ Yanmar YM2000 Fuel Pressure/ hard starting #194
I know there were no new ones availible a short wile ago, Hoye and everyone else was waiting on new ones. There is no rebuild, you can do the orings, but if worn there just wornout. And if it's all pitted and it won't be fixable. Either get a new one or a serviceable used one from Hoye or similar.
/ Yanmar YM2000 Fuel Pressure/ hard starting #195
Between the regulars here we have about every manual for some model or the other, that is available.
Seems to be working good. Had lunch and a movie, got back home around 4:30pm, ran the tractor again with the box blade till about 7:45pm. Played around more with the hydraulics, and turning the adjustment knob at the front of the seat. Got feedback back and now the 3 point stays up even with the box blade on.
/ Yanmar YM2000 Fuel Pressure/ hard starting #197
Adjustment knob, you talking about the screw in shut off valve. You don't want to restrict flow from the pump.
/ Yanmar YM2000 Fuel Pressure/ hard starting #198
Like ST said. That huge back plastic knob under the seat, between your legs as your sitting on th seat you DO NOT want to mess with. It needs to stay all the way open or you can damage your system. If you close it you can dead head the pump, if you need it slightly closed t work something is not right in the system and your putting wear on the system that does not need to occur. That is the service lockout knob. It's used when you cut off the tractor to block off fluid flow in 3pt. It will lock up the implement when closed unless your O ring is bad hen it will still leak down. This is the way to tell if you have a bad valve or O ring in your 3 pt , if an implement leaks down.
/ Yanmar YM2000 Fuel Pressure/ hard starting #199
Only thing I hate about the system is once you raise the lift I have to push the lift lever forward just a little to take pressure off the pump.
Wished it worked like our other tractors, self relief the pressure.
/ Yanmar YM2000 Fuel Pressure/ hard starting #200
Gotcha, I've got a Ford 3 wire sitting here from the boat engine, but the alternator on the tractor is brand new, and is 90amp vs the factory 50 or whatever it was it came with.
I looked in the YM240 Parts Manual. The OEM 'generator' (alternator) is 15 amps.
2025 Kivel 48in. Forks and Frame Skid Steer Attachment (A59228)
2025 Kivel 48in...
2014 Sea Ray 250SLX Bowrider Boat with T/A Boat Trailer (A59231)
2014 Sea Ray...
2004 Saturn VUE SUV (A59231)
2004 Saturn VUE...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2020 Deere 544L (A60462)
2020 Deere 544L...
2018 FORD TRANSIT 350 CARGO VAN (A59906)
2018 FORD TRANSIT...
