Yanmar YM2000 Fuel Pressure/ hard starting
/ Yanmar YM2000 Fuel Pressure/ hard starting #181
Haven't started the tractor yet ? I thought the video was after your engine repair ?
Yes I did post that idle video after the engine repair. I was referring to had not started it since putting the hydraulic valve back on for the 3 point.
Just had it out for a little test a bit ago, definitely works now. Have the box blade all hooked up ready to work tomorrow. We shall see how it goes!
Couple of things though, where should the small lever be position wise that comes out of the left side of the valve for the 3 point?
Secondly, could someone post a picture of the linkage from the left side upper 3 point arm and how it is connected?
Thank you all very much!
/ Yanmar YM2000 Fuel Pressure/ hard starting #183
If you're talking about the one with the knob, two position hole, bottom hole if I'm not mistaken.
/ Yanmar YM2000 Fuel Pressure/ hard starting #184
Is this what you're looking for? YM195 - 240 manual.
33833d1108746182-ym1700-draft-control-587946-feedbackrod-jpg
/ Yanmar YM2000 Fuel Pressure/ hard starting #185
Another diagram emphasizing the small knob that controls the 3-point drop speed. (The big knob in front should be wide open except when you want to lock an implement in the full up position, for maintenance etc).
60195d1156820929-all-us-yanmar-owners-ym3ptloweringvalve-gif
/ Yanmar YM2000 Fuel Pressure/ hard starting #186
... and a photo I made for someone when he asked about adjusting the threaded rod. Paint indicates mine has never been disturbed.
76132d1178396482-unknown-part-p1090564r3ptfeedbackrod-jpg
Yes, all of those exactly. Okay, so I will have to adjust the speed lever some more tomorrow.
The “feedback linkage rod” appears too short to line up with the arm under the seat.
/ Yanmar YM2000 Fuel Pressure/ hard starting #188
my speed of drop lever is straight up. the way it's been since I bought the tractor
Was able to flip the feedback rod around this morning, and got the three point going with the box blade.
Down side is, it doesn’t start coming up until about 3/4 of the travel with the hand lever on the right of the seat. With the box on the back, I have to hold the handle back to keep it raised while operating, unless of course I turn the adjustment knob closed to lock the hydraulics in place.
I’ve been on the tractor with the box blade since around 8am, it is now 11am, and she is running pretty good engine wise. Seems to have plenty of power. I’m pulling a 5ft box blade (sans rippers currently), low range 4wd in the 5-8 gear selection at about 1/3 throttle lever fairly well.
/ Yanmar YM2000 Fuel Pressure/ hard starting #190
Manual on your hydraulics. Note step #3.
  • YM240Hydraulic.pdf
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A59823)
2017 KALMAR OTTAWA...
2012 GENIE GTH844 TELESCOPIC FORKLIFT (A62129)
2012 GENIE GTH844...
2016 Dodge Grand Caravan Van (A59231)
2016 Dodge Grand...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
Preliminary Listing / Full Catalog Coming Soon! (A53317)
Preliminary...
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A58214)
2008 MOTIV...
