So here is where I cap things off with the videos I posted on my Utube channel.
A few notes on using this mini-X: with 2400psi and 3" cyls, this machine can
really pull itself around, even with the dozer blade dug in. The hyd pump is more
than big enough to generate decent flow even at 2500RPM or so. The only
thing that is slow is the drive speed. The wheel motors are enormous.
Getting the oil too hot by running long periods on hot days will be an issue. An
oil cooler would be a great upgrade. Larger units from China seem to provide
coolers and better filtration. Both are necessary for this machine to last.
I have not tried out the track adjustment. It is mechanical, not hydraulic like you
see on name-brand excavators. Larger Chinese units do have hydraulic adjustment.
These small Honda-clone engines have no oil filtration (even on Hondas), so frequent
oil changes are a good idea. I plan to install a drain valve to make this easier. The
engine runs great, tho it generates some sympathetic vibrations that cause rattling
at idle. I will install padding to fix this next time I have the rear panel off.
walkaround after most mods installed:
XN 8 walkaround Small - YouTube
startup testing:
XN 8 initial startup - YouTube
pressure test:
XN 8 mini-excavator pressure test - YouTube
testing the log
grapple:
XN 8 log grapple on mini-X - YouTube
first digging test using larger bucket with new welded-on teeth:
XN 8 digging - YouTube
