dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,718
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
Did the manufacturer provide hydraulic pump specifications? Max RPM's?,
gpm output graph across the RPM spectrum? Believe you shared pressure reading when your gauge was
connected to the aux. Circuit.
The only spec I got was for the relief setting on the stack valve. 2400psi, which I verified in the pressure
test. I always test pressures, esp on new equipment as it is often set incorrectly.
I have purchased new hyd pumps for tractors in the past, and this one seems to be a bit larger displacement
than what I normally buy. That is based on the width of the center section, an approximate guide to volume.
My estimate is 1/2 to 3/4 cubic inches. I suspect that the volume was chosen based upon an engine running
at somewhat less than 2500RPM.
Also discovered in my initial test of my new engine: my IN and OUT hoses were connected backwards at
the factory! I could have blown my stack valve. I do not know how this mistake could have been made
as the unit I purchased (originally intended for a volume customer in Slovakia) showed clear signs of
having an engine installed then removed. I guess it was not tested.
