dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,721
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
I replaced the hydraulic return line to the tank with the filtration system shown above.
The original fitting on the tank had 2 lines returning fluid. One was out of the stack
valve, and the other smaller hose came out of the distribution valve (photo).
The distribution valve allows the house to rotate 360 degrees, while providing hydraulic
power to the tracks and the dozer blade. I have never had one of these valves opened
up. Anyone else work with these?
I kept the distribution valve drain hose on the tank fitting, and I used the original return port
on that fitting for a capillary-type fluid temperature gauge. The fluid can heat up very
fast on a hot day, especially when using the track motors.
I opted to use the passive temp gauge, rather than an electric one since the engine puts out
so little charging power. The gauge is installed where the diesel fuel fill cap used to reside.
It works well.
Note the metric grade 12.9 bolts used in the last photo. The maker did not cheap-out on any
of the fasteners used on this machine.
It works well.
