Tractor Shop Building Options / Pointers?
/ Tractor Shop Building Options / Pointers? #1
otus_branch
The NC High Country
BCS 850
Thus far, my farm has operated with two steel 40' shipping containers as the sole tool / equipment shelters. This has meant that the hand tools, 4-wheeler, and BCS's & attachments have spent their lives 'indoors' but the Kubota has had to bear the brunt of the elements for more than a decade. Abundant grease and Fluid Film usage has kept the corrosion at bay, but the paint and tires are showing signs of UV damage. Plus, servicing the 'bota on gravel or mud has been a PITA to put it mildly.
For these reasons, I am looking at a steel building on a concrete pad. With the other needs for shelter/shop space and the available building site, I am thinking that 30-40'W x 60'L x 12'-14'H makes sense for my purposes. The site would permit an even wider structure than 40', but my understanding is that increasing the span drives up cost considerably compared to increasing length. Sixty feet of length is about as long as I can fit. A fourteen foot height to rafters would be nice, but 12' is probably adequate for my purposes and any equipment I'll ever own. I hear that adding height gets expensive quickly as well.
In researching options in Western NC, I see Champion Buildings at:
Steel & Metal Building Company | Southeast USA | Champion Buildings
These folks seem to be a 1-stop shop outfit, with in-house construction teams.
Viking Steel Structures at:
Viking Steel Structures- Metal Carports, Barns, Garages, RV Covers
These folks seem more like the traditional Middle Men who neither manufacture the buildings, nor install them, but just take their cut along the way...
& lots of other professional middlemen, such as:
Metal Buildings, Garages, Carports & Barns Online- Elephant Structures
&Metal Barns | Steel Building Garages
etc.
I'd like to hear from the TBN community, especially folks relatively nearby who have put up similar buildings. Any companies to avoid like the plague? Any particularly good products or outfits? My county will permit this as an Ag structure, so no permits to pull before electric.
While I don't plan to put in plumbing, does it make sense to run a few pipes for potential future drains before pouring the slab?
Any other pointers are welcome. My searching found a few good posts in the Rural Living section, but I figured a more specific tractor use steel building post fits OK here.
-otus
/ Tractor Shop Building Options / Pointers? #2
There have been guys that used the shipping containers for their sidewalls.
Works out pretty good
/ Tractor Shop Building Options / Pointers? #3
Can't say about any of the contractors you mentioned. Built both of my barns and the shop myself.
Since you live in NC, I assume you need to figure in snow load. Down here, that's not an issue. We just hope to build something that will stand up to the occasional hurricane force winds. :eek:
One thing I will say, is however big you think you need, build it bigger!
/ Tractor Shop Building Options / Pointers? #4
I am from Kansas, but plan on moving to Shelby, nc soon. That being said, we have Morton building in Kansas. They are considered the "Cadillac of buildings" but they are a little pricey. There are other contractors in Oklahoma that build buildings that are just as good as Morton buildings with about half the cost.
If it were me, I would go with a pole barn design and 14 ft tall. With this height you have the option of backing in really tall stuff (ie. A load of hay, a semi, etc or the option loft it). I believe I would plumb it for a frost free water hydrant and drains. I would wire it for 240v in case you want a welder or large air compressor. If you go with a pole barn design, all the plumbing and concrete can be finished after the barn is built. This way you get a better idea of how thing look before you pour the concrete. The poles in the pole barn are generally laminated 2x6 lumber. They claim that is stronger that a 6x6. All you have to do is nail 2x6 lumber to the base of the poles on the pole barn, and that make concrete form. Pour your concrete. there will be about a six inch gap between the concrete floor and the barn tin. Fill that gap with gravel. Helps to control seepage and drain a major spill/flooding event inside your building. Be sure to put in plenty of doors and windows or will be hot hot hot in the summer time. Hope this helps.
/ Tractor Shop Building Options / Pointers? #5
Personally, I went with the 'one stop shop'. The only thing that I had to do (although they would have) was prepare the site, which, with the help of my tractor/tiller/FEL-bucket I was able to do using nothing but my eye.
A competent 'one stop shop' does a lot more than simply erect the shed... (here in Tassie and, therefore other places) they'll submit all of the paperwork that the local council/government require for erecting. There's more involved than you might think as buildings are rated for your area's slope/exposure/maximum wind/snow-load/roof drainage etc...
The footings for my open 5-bay shed were properly set into the concrete pad = the shed as erected straight and true. I put in a 5,000 litre water tank for rain water collection + ran an extension cord from my house out to the shed to power the tank's pump and any power tools that I use. Nothing heavy that would require a 230v/3phase.
My shed is oriented facing South, to minimise sun entering, you, in the Northern hemisphere would/may want to face North, depending on your circumstances as predominant wind direction and average intensity would be factors to consider.
Natural light can be employed via 'clear' roofing panels or skylights.
I have thought about using the shipping containers for side walls of a lean-to off of the main structure. Will float this possibility once I settle on a company for the main structure / concrete pad. Thanks.
I may tackle the site leveling myself. We'll see how that shakes-out, but there is not too much earth needing to be moved. But after that, a 'one stop shop' option is high on my list.
Good point on the solar orientation. My garage bays will be oriented west, which could get warm at times, but with a hill in that direction blocking the late afternoon sun, it shouldn't be too bad. But that orientation makes the best sense from an access and flow standpoint. Thanks!
I am from Kansas, but plan on moving to Shelby, nc soon...
Welcome, future Tarheel! Lots of growth around Shelby with the highway expansion from what I hear.
That advice on the system for pouring a pad in a pole barn makes good sense. Thanks!
I wish I had the skills, time, and patience to do this building myself, but I don't right now, and I need the building sooner rather than later.
Snow load will be a factor here. We can get up to a few feet at a time. One of the contractors I looked at had a minimum of 20 psf snow load, but I suspect I will need to bump that spec upward for my region.
Regarding size, I have already moved from thinking that 30'x40'x12' might suffice to thinking that 40'x60'x14' is a more reasonable minimum...
Thanks for the worthwhile advice!
/ Tractor Shop Building Options / Pointers? #10
This is one of the things that a competent One-Stop-Shop can provide... I should have elaborated more in my earlier post.
The company that built my shed submitted all of the paperwork & plans to my local council which led to a seamless building approval, and it was built to the specifications required for the rated environment (max wind exposure for the elevation/slope). The pad building crew was hired by the company and the cement was ordered by them, both local and to spec. The fabricated shed was delivered and assembled (after the pad had cured) within 3 days by a 3 man crew.
The site was fully cleaned up after the erection.
All done for the agreed price.
/ Tractor Shop Building Options / Pointers? #11
I went w/ newmart builder.. painless.. 24x32 w/11' sidewalls & hurricane steel.. 8k even..set-up & delivery included.
I already had the concrete pad.. & went w/ 1 10x10 roll-up instead of the 2 8x8's they offer & I went w/ 1 walk in door.
Up in 1 day..
The only thing I would change is the position of the walk-in.. I put it on the left of the roll up & I cant see it from my kitchen window..
Pretty minor change.. overall I'm VERY pleased w/ it..
/ Tractor Shop Building Options / Pointers? #12
I think you are very wise to consider the larger building. I also has a shop built the same size, i.e. 40' x 60' x 14'. While the 14' height may seem excessive to most, I find that feature to be very valuable.
/ Tractor Shop Building Options / Pointers? #13
I looked at the steel buildings and pole barn buildings. I decided on the 30x50x16 pole barn built by Morton. They are to start this week weather permitting !! There wasn't much of a price difference with either building. I am paying $38K for a turn key job. I had a bid from Renegade Steel Buildings....$22K for the building and then another $16K for the building to be erected by a separate contractor and concrete. We live in the Cherokee National Forest which is somewhat remote, so its difficult to get builders to come here. With a steel building you really need to pour a floor first so that it ties in with the support column pilings. Morton uses the perm column design, so no more wood posts in the ground ! I am pouring the floor later myself, which allowed me to add a few extra features to the barn now. I would like to build it myself, but the wife wants the building yesterday and I am getting older and don't need to be walking around on metal roofs !!
/ Tractor Shop Building Options / Pointers? #14
I like my 16' sidewalls and 14' door. I do not have to worry about forgetting lowering the hoe driving into the shed. Also had a Semi tractor in there once. It's just handy.
I also do not like doors skinnier than 12' wide as a rule. I have one 9' door primarily for the lawn mower
/ Tractor Shop Building Options / Pointers? #15
Just another option 'American Steel Span' buildings. my brother has one. 30' x 40' I believe with a 16 foot peak. 'P' style.
/ Tractor Shop Building Options / Pointers? #16
My advice is to shop around. Don't get 3 estimates and then stop. Talk to people, get word of mouth recommendations, give the smaller contractors a fair shot. Get references from your contractor and follow up on them. I know its a PITA but it will pay off.
I spent 3+ months researching local contractors and getting bids before I finally pulled the trigger. My first 3 bids were all around $40k, which led me to believe that was about standard price for what I wanted, and normally I would have have just eeny-meeny-miny-moe picked one of the three, except that it was a lot of money and I wanted to be a bit more diligent about it.
I wanted either a metal building (a real one, not a chincy enclosed carport) or a pole barn, insulated, and built to appease Texas Windstorm Insurance requirements (I live in hurricane country) so I could get it certified and insure the building and contents; this means the building and foundation is delivered with (and more importantly built in accordance with) blueprints stamped by a licensed architect. This drives the cost up considerably over "Any Ol' Pole Barn, by Bubba."
I got bids from $15k (bubba) to $65k (Morton & similar). The bubbas out there, half of them didn't even know what I was talking about with windstorm coverage and I'm sure the barns they built would have been ok, but not when I have my livelihood inside that costs more than my house and can't get wet. The Mortons (and similar) are not always the best! They build good buildings, yes, I went saw some of them, but other smaller local contractors can build just as good, and usually for less. You're paying for a name. Granted the name stands for dependability and a good history, which really is important, but you need to decide for yourself how much that name is worth.
After getting probably 20 bids, I ended up getting mine built turn-key for $30k by a local small contractor and have been extremely pleased. The research really paid off. I have a drawings folder probably 1/2" thick with each page stamped by P.E./architect documenting every little bolt and nut on purlin 6a of the West wall, the tensile strength of the guy wires, every facet of the 6 footings 6ft below the foundation, it's all there, and my stuff is secure & insured. The building is every bit as good as a Morton (dare I say better) and was half the cost. Engineered from (below the) ground up to withstand 130mph sustained winds. Truth be told I'm not sure how the contractor made any money on the job. But he named the price and I didn't even try to negotiate, so if he lost, that's on him. I was very leery about the low price; it felt "too good to be true" so I was very thorough with his references. I went and looked at buildings he claimed to have built, spoke to the owners, and confirmed his work. He seemed legit. With only a little reservation left in me, I finally wrote the check to begin the project. It was a great deal.
/ Tractor Shop Building Options / Pointers? #17
I will confirm Morton as a solid source.
They will undoubtedly be a little more than what you can get a good quality local builder to do the same job. However, with Morton there is no question that you are getting a quality building. If you have no question about the local, go for it.
This is absolutely excellent advice that I will certainly take to heart. I found four potential companies online that I will solicit bids from, and also will start talking to local folks more. Was in a nice barn of a neighbor yesterday, and they recommended that builder, so there is #5, and another farmer/builder friend of mine is who I will ask for recommendations #6+. Thanks!
/ Tractor Shop Building Options / Pointers? #20
I have a raised aisle barn = 60x60 - basically a 30x60 with 15 by 60 metal sided pole barn extensions on each side - I have two outside horse stalls on one 15x60 section and on the other side a 15x40 living quarters area that I rent out = pays for barn!!!!
my other 15x40 section is my heated/cooled work area and the middle is for storage of larger items and repairs that I need to do that are quick and not tying up my heated/cooled side.
the drawback of the shipping container is their width, hard to do a lot other than storage in those because when you get an avg sized item in there, not a lot of room to move around it for repairs etc.....they would be great for dry storage obviously and shelter/living quarters and smaller items - try removing a 6 foot belly mower out from under a tractor in one of those LOL. A drive over is the solution there.
The buildings themselves are reasonable but then you add the overhead doors/openers and then concrete, then electrical/water/heat/cooling, insulation, interior finish - you get $$$ in it pretty substantial - I would recommend 14 foot sidewalls in the center to get your 12 foot overhead doors in - they are a must and don't go minimal width on the door I went with 10 - you will be glad you did when getting things in/out.
I like the idea of the overhead unit space above the containers - that could be used as a rental also or.......many things - not sure I want to climb that many stairs when I get older tho. I have no overhead storage in my raised aisle barn so that would be nice. Thought about a loft using an LVL but didn't ever get that done...........will engineer in my next one!!!
2018 PETERBILT 567 FLATTOP SLEEPER TRK (A67714)
2018 PETERBILT 567...
GAS CYLINDER TRANSPORT BED (A67714)
GAS CYLINDER...
2013 5x8 Port City S/A Enclosed Cargo Trailer (A66738)
2013 5x8 Port City...
2017 CATERPILLAR 926M WHEEL LOADER (A65056)
2017 CATERPILLAR...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2019 INTERNATIONAL...
2017 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2017 FREIGHTLINER...
