The WICKED Root & Debris GRAPPLE!!!!!!!
/ The WICKED Root & Debris GRAPPLE!!!!!!! #3,261
For all you ETA grapple-bucket fans, here are some pics of my handy towing/lifting/rigging-chain storage... I am sure that many/most of you have already seen this or iterations of it and perhaps have designed your own adaptation... I give you my rendition herein and look forward to YOUR ideas/application(s)... The loader-tube-liner/'chain-holder' is salvaged (free) drainage pvc (ADVANTAGE: It has a thinner wall, lighter-weight, and allows more room for a LONG chain) and the vented ends are heavy-duty pvc drains... The pipe/end-plugs have added friction via duct-tape...
NOTE: I also replaced the original small (4"x4"x12") OEM plastic tool-box (behind the seat) with a steel (6"x8"x20") and the addition of a OEM bracket... The bracket/parts/tool-box cost approx. $50 and is MUCH more useful/professional... I will be happy to post pics if there is any interest... BTW, this is not tractor-specific, as I understand this is a universal issue and this tool-box-issue remedies many such problems... LMK
LoaderChainStorage1.JPG LoaderChainStorage2.JPG LoaderChainStorage3.JPG LoaderChainStorage4.JPG
View attachment 550281 View attachment 550282 View attachment 550283 View attachment 550284
Cool tricks, LiveDog! I'm sure people will benefit from them.
Ohhh, that Wicked Grapple.
I like your style...Give em h*ll then go home for pampering! :thumbsup:
Travis
/ The WICKED Root & Debris GRAPPLE!!!!!!! #3,263
I would like to see the Tool Box upgrade, What is covering your hyd cly shafts and why ? Thanks
/ The WICKED Root & Debris GRAPPLE!!!!!!! #3,264
The hydraulic cylinders are wrapped with oily rags to keep the from rusting and to protect them from getting damaged/scratched... It would be difficult/inconvenient (almost impossible) to store the grapple-bucket without leaving the cylinders exposed...
Attached are 4 pictures of the steel-tool-box retro-fit and 1 small plastic original... I did not take a pic with ALL my tools in it but in addition to them it also holds a full-size grease gun and if I leave the lid open it will hold my small STIHL-Pro climbing-chain-saw... NOTE: I ordered/installed an additional mounting bracket, the tool box is secured with 1/4" rubber-sandwich (between the 2 rear brackets AND on the bottom) and 1/4" rubber matt inside/lining the bottom (this rubber matt covers the 2 bottom mounting bolts)... I hope this is clear and helpful...
ToolBoxNew1.JPG ToolBoxNew2.JPG ToolBoxNew3.JPG ToolBoxNew4.JPG ToolBoxOriginal.JPG
/ The WICKED Root & Debris GRAPPLE!!!!!!! #3,265
Yours looks better than show room treatment.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #3,266
Thanks... Like a LOT of folks, I came up the hard way... Learned how to make-do/take care of my/old man's tools/equipment/vehicles OR ELSE... EVERYTHING gets used (NOT abused) and put away cleaned/greased/sharpened/adjusted/READY to go back to work (in ANY emergency)... I am VERY thankful/appreciative... NO trust-fund, NO inheritance, NO welfare, NO fat-gifts here (not one gawd damned f'ing screwdriver)... When you navigate life via hard-knocks, blood/sweat/tears, I don't think I have to tell YOU, what it takes to purchase/maintain/preserve... It's all good man, I own/embrace/LOVE it all...
MY cup runneth over...
Here are 3 more pics of the retro-fit tool box, since I mentioned the grease-gun/chain saw... NOTE: There are many other tool-boxes/caddy's out there and some new/better ones coming... I am sure YOU can improve... ;+)
Let's turn this thread back to the ETA Wicked Grapple Bucket... NOTE: The ETA Bush Hog...;+)
I hope this side-track has been a help NOT a hijack...
/ The WICKED Root & Debris GRAPPLE!!!!!!! #3,267
This was lifting our back wheels off the ground
so we just repositioned it for more chainsaw work.
tvMHvZlZ66csd5ufC2X5PRpQVvW-iv6dTGZ21U6cwOdkIuN6DtXy9cIuo9G8-GYjBjlQkB6U4F1GdG6HOWoTgFMN4eHM48TPKvxvCZ3JeqLNgZx_2vATVrFC3B5ZDhFY2h7HlIEG0Ofr6VkbilndWCZG1Wifhtydd_a1r_jv_0Mg_48rbiUM1H8U0fcjSnZyJ-xSKvTlMdGVPbcs1LV187wb2OxKk-pNe1jU1YiM03KcXEdkKgcTfIxA3dq9vZtIXU2vYlJ6ktkwPw0oa2p2F479kwycJ87Itzj0Qk3FXUyZ65zu_qQgXu1zmQCFhoHgi3OXpVP2dYv7mpY3SfNGAAMP9BLs9E9OHMlN4gX3WdXFfmIot_1Z5ceZn8Y9xJULCkVi5-SdEZ4s0SMSlqaIEFoJOQHa8i7rGAws4uqZej1Fuh5-TsC0oH0ZPSU0vbJFeykT0OcIzJtubU0M3y8Ne4VKuAIXopJtKFruRl0Lv6wQ-K63uDUE7vFftIHZ_69zvOa9IxVraYu0qFpBAg_Ma2tZopv0mGobFTAknzS_8iaWOSNTQk1MRchS9ODB23BcHOJorOQJ4KFx8PDxhCjnR6X8pQ01mP68lzUTaKpr=w877-h655-no
Awesome! Man, I know it takes a LOT to lift that tractor's back wheels off of the ground!!
Travis
/ The WICKED Root & Debris GRAPPLE!!!!!!! #3,270
Nice, but those hoses are going to get snagged.
I was just browsing YouTube and stumbled upon this BRAND NEW Wicked Grapple video by 94BULLITT. He has some great log moving skills, which comes from tons of seat time.
Travis
Check it out.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #3,273
Nice! Great job as an operator taking care of the equipment!
/ The WICKED Root & Debris GRAPPLE!!!!!!! #3,274
And speaking of uses for the Wicked Twin here's yet another. I needed to move this 30' pole to the back and there isn't 30' of width to get back there. So I was able to get under the end of the pole and slide it through the Wicked Twin until I could pick it up and walk off with it. To get if off I hooked it on a cross tie and back away. Be careful hauling like this, keep the pole down beside the back tire or it can hit your fender. Also lifting it up too high will hit your turn signal.
Here's up close how the pipe went through.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #3,275
You should take up jousting? I like it!
Just when you think you've got every Wicked Grapple use covered, here you guys go thinking outside the box! :laughing:
Travis
/ The WICKED Root & Debris GRAPPLE!!!!!!! #3,278
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59909)
2016 FREIGHTLINER...
Massey Fergusson 4710 (A60462)
Massey Fergusson...
2012 Kenworth T800 T/A Wet Kit Sleeper Cab Truck Tractor (A60352)
2012 Kenworth T800...
Case SV280B (A60462)
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
Mama Goat Decorative Statue (A61569)
Mama Goat...
