New HD equipment trailer
/ New HD equipment trailer #1
coolbrze
Gold Member
VA
Kubota MX5800
I'm looking at purchasing a new 18-20' long 10k or 12K tandem axle equipment trailer for hauling our tractor, FEL, & attachments. I like the Bri-Mars I've seen but what about Big Tex & CAM? I don't know much about heavy duty equipment trailers so lookin' to y'all for advice. Who makes a really good solid trailer?
/ New HD equipment trailer #2
/ New HD equipment trailer #4
I would caution you that even a 22' trailer may be too short, depending on what attachments you want to have hooked up to the tractor. Case in point, my 18' trailer is about 3' too short for my tractor with FEL when I have the brush hog on the 3 pt.
Now, if I wanted to also have another attachment along for the ride, like a rake or a tiller strapped down in front of the tractor, I'm looking at 26' to 28' of deck space. I'm looking at 28' goose deckovers myself for this reason.
/ New HD equipment trailer #5
I'm happy with my 22' 14K PJ full tilt trailer. I agree that you may want to go longer. I went from a 20' to 22' when I upgraded trailers.
/ New HD equipment trailer #6
Whatever you do, I strongly suggest you custom order your trailer instead of buying off the lot. Unless they have exactly what you want. I have ordered the last few trailers I bought and it is very much worth the 5-6 weeks wait for years of having what you need.
Having said that, my last trailer is a TopHat brand 20' bumper pull with 2 - 7k axles and tailgate ramp and 2' dovetail. You can read more about my trailer here. http://www.tractorbynet.com/forums/trailers-transportation/391715-new-tophat-20-trailer.html
I really like mine, and it fits my needs very well.
/ New HD equipment trailer #7
It may not be absolutely necessary to have a trailer with a deck long enough to accommodate everything you might bring along.
I bought a 14K - 20' equipment trailer, when I would have preferred a 22' or 24'.
Why?
Because It thought it would work for me, and it would leave 14' additional for me to store my Jeep ahead of it for the winter.
I have adequate storage square footage, but never enough organization.
I knew that my backhoe bucket would hang over the trailer rear by 20", and that my loader bucket would need to be curled over the trailer front.
It was a bit of a guess for weight distribution, but it has worked out great.
TLB + trailer = exactly 12,000 lbs. Tongue weight 1250 Lbs. Perfect!
I put a red flag on the hoe for towing, but it is less than 2' beyond the tail, so not legally required.
Of course if you store your trailer outside, the length would not matter.
I store no tractors, implements, vehicles, or trailers outside.
/ New HD equipment trailer #8
I went from a 20 footer and recently bought a 24 footer. As time went by, I realized the 20 footer was just too short. I got a "Diamond C" trailer after looking at other trailers and ordered mine.
Thanks guys, really appreciate the advice so far. Another quest... for an equipment hauler moving my tractor, do you prefer tilt deck or equipment ramps?
/ New HD equipment trailer #10
I have both the tilt deck is faster and you can load everything even small ride on lawn mowers
/ New HD equipment trailer #11
I prefer the ramps since I don't even need them to load a tractor on an equipment trailer. I've only hauled my tractor on a tilt trailer once but I didn't like the idea. There was only about a foot of deck that didn't tilt at the front. I like to load several implements at the front then load the tractor. The tilt deck wasn't very friendly to doing that.
/ New HD equipment trailer #12
I have never owned a tilt deck, so I can't comment on those.
In my case, some if my equipment is 3 wheeled, so I need a full width ramp instead of 2 'slide in' or 'fold up' ramps. But, my full width ramp does not allow me to haul anything that would hang off the back of the trailer, such as a brush hog wheel.
I also have a 28' gooseneck trailer and on it, I have the fold up ramps with spring assist. I prefer the fold up over the 'slide in' because they are just easier to handle.
/ New HD equipment trailer #13
How do you load without the ramps ?
/ New HD equipment trailer #14
Tilt deck is the best for me. My last one had ramps and I came to believe they were a PITA. I had slide in ramps which were heavy. The tilt up ramps type prevents longer loads from being carried and take up space on the back...unless the trailer is long enough. If you get tilt deck type trailer, get one with the angled deck at the end all the way across. I have seen some that have a deck just where the tires on a tractor normally go. But what if you want to drive your lawnmower or atv on top? Also, you can get tilt decks that have a portion of the front non-tilting. Mine has a 6 foot portion stationary which is good to put extra stuff not attached to the tractor.
/ New HD equipment trailer #15
I had a PJ 14k 20ft equipment trailer with dovetail and fold up ramps, that was a very nice trailer. But I found I really did not need the carrying capacity. And the dovetail subtracted from the useful length. I replaced it with a Big Tex 10k 18ft trailer with what they call Mega Ramps. Folded all the way up, they provide a full flat 18ft bed. They can be left straight up too. And they are full width, so loading is easier and safer than on the usual fold up ramps. So far I like it fine.
/ New HD equipment trailer #16
With a dovetail equipment trailer the end is only about a foot off the ground. Lift the front end up with the loader and the back wheels will climb it.
/ New HD equipment trailer #17
With a dovetail equipment trailer the end is only about a foot of the ground. Lift the front end up with the loader and the back wheels will climb it.
OK beaver tail up here makes sense now:D
/ New HD equipment trailer #18
I was looking for a new "Last Trailer I Will Ever Buy" ....
I needed it to be big and strong enough to haul my Mahindra 4025 with a FEL and backhoe as well as easy enough for me to use hauling motorcycles. Ramps were out because my wife rides a Can Am Spyder (3 wheels) and I also have a JD AMT 626 (5 wheels). So a tilt bed with a straight back edge was the ticket.
There are 2 manufacturers of trailers within driving distance so I looked at them as well as "Big Tex" and all the other major brands. I went with the Gator (picture below). I went with a 16K 20' + 4' tilt bed. The 4' stationary is big enough for my needs and I really like the low bed tilt. easy to load anything including my wife's Can-Am - Spyder 3 wheel motorcycle.
The Gator has a much stronger gooseneck made out of 12" "I" beams and the frame is all 6" X 3" (I believe) square tube. The tires were upgraded to 17.5 in 16 ply, and came with a spare.
This is a beast that's easy to handle, drives great, loads easy. looks good (powder coat finish), and was significantly cheaper straight from the factory.
Take a look at them, you may be surprised.
/ New HD equipment trailer #19
I ordered also, and very glad I did.
/ New HD equipment trailer #20
Looks like the same trailer that I bought last summer. It took me several years to be able to get a tilt bed, but I'm glad that I made the move.
Having owned both types, for my uses the tilt bed is better for sure. But different people have different equipment and uses, that's why there are several styles.
Evaluate what and where you're going to haul and make your decision from there. Anyone who tries to steer you totally one way or the other is just trying to fit their solution to your situation.
