Forks Need attachment advice for moving brush piles
   / Need attachment advice for moving brush piles #11
You don't know the right people. Fork lift places always have a supply, all different sizes. Usually a couple hundred bucks CDN. I took my first set to HORST and they made up a JD 640 carrier to accommodate them. Pretty sure, those days are long gone, but a good shop will do it.
   / Need attachment advice for moving brush piles #12
Worksaver Manure fork. Raise the loader, point the tines to the ground and drive forward slowly...works awesome!
   / Need attachment advice for moving brush piles #13
Is your bucket SSQA? (bucket quick attach) Can you weld? or are you looking for something to buy?
What do y’all think of titan debris forks. The 60” are $260. Seems like a good price. Only thing that concerns me is the forks are only 21” long.
6" Clamp-On Debris Forks
   / Need attachment advice for moving brush piles #18
I like that you can buy Worksaver Forks with SSQA and John Deer QA to the FEL. You improve visibility of debris piles and increase payload capacity a bit by eliminating the bucket.
However, I like the design of Bucket Solutions' Ultra Forks a little better. Ultra Forks seem a little beefier (170 pounds/60" vs. 146 pounds/60") and individual tines unscrew so you can vary spacing or replace one easily. Varying the tine spacing allows carrying verdure with less dirt included.
See Post #7.
Manure Forks from Worksaver
   / Need attachment advice for moving brush piles #20
What do you think of Titan debris forks? The 60 are $260. Seems like a good price. Only thing that concerns me is the forks are only 21 long.
The tines on my Hayne's aluminum debris forks are 19" long; five fork tines spaced over 54" width, outside to outside. I have never wanted more depth.
See Post #7.
Several respondents suggest some pallet fork tasks are best handled with two pairs of pallet forks.
I use 600 or 850 pounds of Three Point Hitch mounted counterbalance when lifting and transporting verdure with my debris forks on my L3560 with LA805 loader, about 1,700 pounds lift capacity.
Kubota B3300SU in photos.
2005 V.E. ENTERISES 130 BBL STEEL VACUUM TRAILER (A53843)
2005 V.E...
2015 Vermeer SC362 Stump Grinder with 2018 S/A Flatbed Trailer (A53421)
2015 Vermeer SC362...
S/N: 1240824 (A55853)
INOP/NON-RUNNING 2012 International WorkStar 7400 Vacuum Truck, VIN # 1HTWCAZN1CJ609461 (A54865)
INOP/NON-RUNNING...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
