Forks Need attachment advice for moving brush piles
   / Need attachment advice for moving brush piles #1
atcNick
Longview, Texas
Still shopping
I’ve got brush piles piling up around my property and I need to move them where they can be burned. I’m working with a kioti ck 30 (30hp) with a 5ft FEL and ratchet rake. Looking for some type of brush fork. What do y’all recommend? Grapple is not in the budget.
   / Need attachment advice for moving brush piles #2
It's not really a very good picture. The backhoe is being moved by the JD forks. But I got this (old style) bale grapple thrown in when we bought our JD 6200. I mounted it to a fork carrier and use it to move brush. It will carry way more than a normal grapple.
It's also great for loading up with branches that have been cut off. Every now and then you compact the load to pile more on. You don't lose one on the way to the pile, and just dump it.
   / Need attachment advice for moving brush piles #4
Two pair of clamp-on forks, or a clamp-on brush fork. Depending on your brush piles, a rope or strap over the top of the load may be needed.
Bruce
   / Need attachment advice for moving brush piles #5
Moving how far? Distance has a lot to say on what is most effective.
I've moved a LOT of debris using old truck hoods, skidding. Strapped stuff in my bucket, etc.. Of course, I've also moved a lot of debris by pushing with my box blade: simultaneously have drug with the bucket (tooth bars are really effective). The former is for longer distances, while the later is for very short distances.
   / Need attachment advice for moving brush piles #6
I got by for several years with a set of clamp on forks. If that is not in the budget you can make a pair very inexpensively with some 2x4's and bolts. A neighbor friend of mine did just that for his B7800 and has gotten good use out of them for little $$$.
   / Need attachment advice for moving brush piles #7
I have Hayne's Clamp-On Aluminum Debris Forks. An excellent product however light brush tends to run away from the blunt fork tips rather than load, unless debris is backstopped by a tree. Forks lift more dirt than I like sliding under brush piles.
Debris Forks pick up up heavier debris with greater inertia, fine.
While I have not used Bucket Solution's UltraFork, I would give this attachment consideration. I think UltraForks would slide under brush piles and pick them up with a minimum of dirt.
(I have a Bucket Spade from Bucket Solutions, fabrication is excellent.)
LINKS (2) : Multi-Spear Ultra Fork
multi-spear ultra fork - Google Search
If you only want to transport brush and vines, not tree sections, a Field Cultivator will hook and tow debris piles with barely any debris loss and hardly any dirt. I often work with Ratchet Rake on the FEL bucket and Field Cultivator mounted on the Three Point Hitch. Field Cultivator is about the same price as quality Debris Forks, around $800.
(Five tractor horsepower required for each Field Cultivator tine.)
LINK: http://www.tractorbynet.com/forums/attachments/339095-dirt-dog-all-purpose-plow.html?highlight=
   / Need attachment advice for moving brush piles #8
I have some regular 4' pallet forks and it works like a charm for big piles you wouldn't believe. If you only have to move the pile a couple hundred feet just fork it and lift it a couple feet and off you go. The pile has a tendency to stick together when a bunch of weight is added. I do like jeff9366 brush fork setup also.
   / Need attachment advice for moving brush piles #9
I致e got brush piles piling up around my property and I need to move them where they can be burned. I知 working with a kioti ck 30 (30hp) with a 5ft FEL and ratchet rake. Looking for some type of brush fork. What do y誕ll recommend? Grapple is not in the budget.
For less money than some of those clamp on forks cost...you can get a thumb grapple and curl circuit diverter or even a separate scv...! Shop Online
   / Need attachment advice for moving brush piles #10
You will be surprised how much you will use a good pair of pallet forks. Some of the first advice I got on TBN was to try them before investing in a grapple. I am still saving that grapple money!
Kinda funny but I've never seen used pallet forks for sale.
TBS
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55302)
BOSS MT 660 Fuel...
New/Unused CFG Industrial QK18R Mini Excavator (A54865)
New/Unused CFG...
2012 MACK CXU613 DAYCAB (A55745)
2012 MACK CXU613...
2005 MACK CXN613C FLATTOP SLEEPER (A55745)
2005 MACK CXN613C...
2020 John Deere 1025R MFWD Compact Tractor (A55302)
2020 John Deere...
2017 Ford F-650 Stakebody Flatbed Truck (A53422)
2017 Ford F-650...
