My NX5510H
/ My NX5510H #161
Man, that is one clean rear-end.
/ My NX5510H #162
Not much happening on the tractor front. Attached the pallet forks and moved a pallet of wood up to the house. First use of the new camera/monitor set up; I didn't have a very good angle of view- need to work on, probably opt for increasing cable length and doing temporary camera mounts (use magnetic base).
Showed the wife why all the fuss with this camera stuff. Having her sit behind the wheel allowed her to "get it."
Tractor and Polaris are currently parked side by side and I thought I'd grab some pictures of them after noticing how much smaller the front profile of the tractor is with the bucket off (had the pallet forks on).
For some reason I thought I'd bought a bigger tractor.
Oh! Now I see it!
Does this Polaris make my rear look big? :laughing:
Looks good.
What is your intended tractor use?
/ My NX5510H
Better be, it's only got 10 hrs on it! :D I'm not in to washing (or waxing) tractors.
Notice the warning sign is on the right side? (been meaning to correct that) My dealer isn't very good at paying attention to details.
/ My NX5510H
Looks good.
Eric, I needed something with more loader capacity to deal with my wood handling scheme (using palletized cages to load up wood in the field, after cutting and splitting, season and then deliver to the house). I also need to do more clearing, so a grapple was purchased: I've got lots of piles of brush and stumps. As I clear more I have more grass to cut; the amount that I have was starting to become too much for the B7800 with a 5' rotary cutter. As noted earlier in this thread, I picked up a 6' bush hog; it'll be doing clearing as well as grass cutting: eventually I'll look to pick up a flail mower. Once I get enough pasture area established and some fencing lanes I'll bring in some grazers (would like cattle); likely be looking at only finishing, as year-round isn't going to happen because it's too wet. I'll be looking at using the tractor to (in addition to loading) pull a dump trailer to haul material (from just up the road); need to do a lot of grade work for the new garage and to put down in an area that I'm running some fencing; a neighbor has a bazillion yards of material (comes down off the hill side) and I have a LOT of area that can use it.
Tractor is idle right now because we're smack in the middle of the heaviest part of the rainy season (11" last month; few days ago we had 1.81"; seems like at least 3" per week right now). Water table is about 1' down. At the back end of the tractor is a site for my woodshed, whose construction is delayed because trying to deepen post holes filled with water is a bit difficult: I'd rented a towable augur to do most of the work, but still more to do and a post hole digger doesn't really work with gravely material, which is only made worse when it's more of a slurry.
/ My NX5510H
Got my hydraulics order. I'm undecided whether to use protective sleeving or not. My hoses are extra abrasion resistant: 3/8" HYDRAULAX TOUGH Hose Assembly
The fittings for the rear top link appear to fit the bill (others just stuck up/out too far):
Meanwhile my garage is coming along (slowly). Will have a LOT of grading work to do (going to have to wait until colder weather sets in, which means LESS RAIN!). Hope I don't forget which bay to drive the tractor in to:laughing:
/ My NX5510H #166
You must be pretty busy, I just turned over 50 hours this week. I have had to wash the tractor off from being covered in chaff and mud. I try to keep the gravel floor where it gets parked clean
/ My NX5510H
Yeah, I'm a pretty busy guy. I'm fairly well tied up in the construction of my garage right now: digging trenches and generally trying to plan the electrics (toss a generator in the mix). And I just picked up another VW TDI: #3 2000 Golf; they're breeding:laughing: (couldn't pass up one from a guy I know that had it configured like mine, plus it having a 6spd [US never saw them in this series here; transmission came from the UK]).
Another big reason is that this ain't the time to have any tractor out on the property, off the beaten path (and I don't have a lot of those :laughing:). I'll rut the heck out of things. And if I wanted to I could get just about any machinery stuck! Kind of have to wait for the colder and drier weather to come this way: not a lot drier, but enough to allow operating the tractor- really need to get some materials in for grading in front of the new garage.
Saw that you're booked to have your FEL dealt with. Good deal. I bet you that someone nodded off on one of the loader [manufacturing] runs. Glad that we caught this issue right away.
Hope that your dealer is a better than mine. When I went to wire the rear camera on my tractor I found that the cab top got sealed up with RTV. I contacted my dealer about this and after explaining that it's going to be a pain in my behind should I ever need to pop the top off in the future (speakers, or maybe for a stereo install), I never heard back. At least my cab is staying dry: if it wasn't then they'd be facing having to deal with the RTV!
Did order a nice magnet base for attaching a front camera to. Also got a longer power cord (already had extra video cord). Looking forward to being able to place the camera right up next to the action for my next pallet fork activities.
/ My NX5510H
I knew that I'd eventually want to pick up a box blade for this thing, but my recent episode of getting the Kioti stuck (at the edge of my driveway!) made me see that I really need some more ballast!
I have a great Modern Ag 5' box blade for my Kubota. That box blade is indestructible: I've thought about hooking it up to the Kioti:D
I like the Frontier box blades. Of course, the one that Eric has -BB4284H- is REALLY nice:thumbsup: However, the cost couldn't be justified for me. And, I don't need to try grading out frozen ground:D Looking around I have found a BB1284. It has hydraulic rippers, something that, after doing lots of manual adjusting on my other box blade (doesn't help that I had no hydraulic top-link either), I always thought would be nice. Weighs in at around 1,250 lbs. They are over $4k new. I've found a used one for just under $2k; however, it'll be a fair distance to ship- got no idea how much shipping would be (likely at least $500). Anyway, can anyone comment on the BB1284, if it would be a good match for my Kioti?
/ My NX5510H
Weather forecast is for a string of dry days. I'm thinking I'll be able to haul some material, in which case I'm back to the hitch/drawbar issue...
The hole in the drawbar is significantly larger in diameter than the ball's stud. Am I OK with this -just tighten the ball down really well- or should I look to sleeve it?
To refresh, I'll be pulling a loaded dump trailer a little less than 1/4 mile on fairly level surfaces.
/ My NX5510H #170
Tufline makes the Frontier BB4284H, as a TB4084H. I like it because it is quick hitch compatible which makes it a snap to attach.
TB3 and TB4 Series Hydraulic Box Scrapers | Tufline
You can purchase a new one like mine without the green paint for $2600, plus shipping.
Tufline TB40 Tractor Hydraulic Box Blades
/ My NX5510H
Eric, thanks for the info. No dealers even close. Over $1,200 for shipping :(
Regarding my drawbar/ball issue/concern, I had tried out a 2" ball when I really have to have a 2 5/16" (I've got one on a hitch but was too lazy to pull it off). Picked up the 2 5/16" ball and verified it fits properly.
/ My NX5510H #172
That is an insane amount for shipping.
/ My NX5510H
Yeah. I was trying to get a hold of a guy that transported a Polaris for me to see what he'd want for hauling a Gannon (found a nice one that would be along his normal travel routes). He transports trailers, and anything that he can toss on the back of his truck is extra gravy for him. That Gannon, however, was about the same price as one of these TuffLines.
/ My NX5510H
Finally! Tractor time:D
Installed a ball on draw bar. Have run about 5 loads so far. Seems to be working out real well. Only issue so far is that frozen material is sticking to the dump trailer and I have to do a lot of prodding with a shovel to get it out (and the dump trailer has a pretty extreme dump angle!). Now have 13 hours on the tractor!
/ My NX5510H
Been getting in several more material runs. Tractor now up just over 25 hrs.
I've hauled and graded 30+ yds of material (not including about 2 yds of leftover 5/8" minus from the site prep) for the garage. Here's what it looked like (with only those couple of yds of 5/8" down in front of the first bay):
Here's how it's shaping up (I will let it settle and pack for now):
/ My NX5510H
Things are finally settling down here and I'm itching to get underway installing my extra hydraulic bits. First I figured I'd do the top-link. Looking for some input on how best to route the hoses and position the fittings on the top-link.
The factory top-link holder bracket seems to limit full upward travel of the top-link with hoses coming out to the left. Not sure how much travel I'd be losing, don't think it's much; but, I don't want to jam hoses. So, I'm thinking that I should remove that hanger and bracket. I'd need to use something like a bungee until I get a quick hitch.
I'll likely swap the positions of the two fittings so that the taller one is at the rear (toward the tractor): I was moving them around to see if it would buy me more clearance/travel (not much, and not enough).
/ My NX5510H #177
I put my check valve down for more room
/ My NX5510H
While I was contemplating the top-link issue my tractor was called in to service:
/ My NX5510H
Vince, now you've got me thinking... Is there any reason why a person couldn't loosen up and rotate that block 90 degrees (in my case I'd look to rotate it counterclockwise)?
2006 TerraGator 8104 (A63688)
2006 TerraGator...
23ft. Zodiac Hurricane Inflatable RIB with 2007 25ft Myco T/A Aluminum Boat Trailer (A61574)
23ft. Zodiac...
2022 EZ-GO ELITE...
1059 (A63291)
1059 (A63291)
Gehl Mix-All 95 Grinder Mixer (A64047)
Gehl Mix-All 95...
2023 CATERPILLAR 289D3 SKID STEER (A62129)
2023 CATERPILLAR...
