B2320 with L304 FEL needs quick change adapter on FEL
/ B2320 with L304 FEL needs quick change adapter on FEL
I don't know. You don't weld. You need this yesterday. It will likely cost over $800 to buy a pin on ssqa adapter .
I don't see a cheap way to do this.
$474 w/tax for kubota ssqa from LA504 loader with same pin-to-pin and cylinder-to-cylinder measurements. $365 w/tax for tree scoop and one hour of my labor to R&R and grease it.
/ B2320 with L304 FEL needs quick change adapter on FEL #23
Forgive the noob but what is R&R in regards to tractor stuff?
/ B2320 with L304 FEL needs quick change adapter on FEL #24
Do you have to buy a new FEL bucket once you have the SSQA?
/ B2320 with L304 FEL needs quick change adapter on FEL #25
At a minimum one would have to cut the brackets off of the old bucket and weld on an SSQA attachment plate ... figure around $100 for the plate, minimum.
That's what I did with mine ...cutting the brackets off is no walk in the park, but it can be done.
/ B2320 with L304 FEL needs quick change adapter on FEL #27
2022 John Deere 5090E (A60462)
2022 John Deere...
yellow ball Trailer (A56859)
yellow ball...
Sdlanch SDLL60 (A60463)
Sdlanch SDLL60...
2015 CATERPILLAR 140M3 MOTOR GRADER (A58214)
2015 CATERPILLAR...
2024 Bobcat T86 (A60462)
2024 Bobcat T86...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
