B2320 with L304 FEL needs quick change adapter on FEL
   / B2320 with L304 FEL needs quick change adapter on FEL
I don't know. You don't weld. You need this yesterday. It will likely cost over $800 to buy a pin on ssqa adapter .
I don't see a cheap way to do this.
$474 w/tax for kubota ssqa from LA504 loader with same pin-to-pin and cylinder-to-cylinder measurements. $365 w/tax for tree scoop and one hour of my labor to R&R and grease it.
   / B2320 with L304 FEL needs quick change adapter on FEL #23
Forgive the noob but what is R&R in regards to tractor stuff?
   / B2320 with L304 FEL needs quick change adapter on FEL #24
Do you have to buy a new FEL bucket once you have the SSQA?
   / B2320 with L304 FEL needs quick change adapter on FEL #25
At a minimum one would have to cut the brackets off of the old bucket and weld on an SSQA attachment plate ... figure around $100 for the plate, minimum.
That's what I did with mine ...cutting the brackets off is no walk in the park, but it can be done.
   / B2320 with L304 FEL needs quick change adapter on FEL #27
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A59230)
2015 Freightliner...
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A59904)
2012 INTERNATIONAL...
UNUSED FUTURE FT-180H HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
SDLD25 MINI DUMPER (A58214)
SDLD25 MINI DUMPER...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
