B2320 with L304 FEL needs quick change adapter on FEL
   / B2320 with L304 FEL needs quick change adapter on FEL
I don't know. You don't weld. You need this yesterday. It will likely cost over $800 to buy a pin on ssqa adapter .
I don't see a cheap way to do this.
$474 w/tax for kubota ssqa from LA504 loader with same pin-to-pin and cylinder-to-cylinder measurements. $365 w/tax for tree scoop and one hour of my labor to R&R and grease it.
   / B2320 with L304 FEL needs quick change adapter on FEL #23
Forgive the noob but what is R&R in regards to tractor stuff?
   / B2320 with L304 FEL needs quick change adapter on FEL #24
Do you have to buy a new FEL bucket once you have the SSQA?
   / B2320 with L304 FEL needs quick change adapter on FEL #25
At a minimum one would have to cut the brackets off of the old bucket and weld on an SSQA attachment plate ... figure around $100 for the plate, minimum.
That's what I did with mine ...cutting the brackets off is no walk in the park, but it can be done.
   / B2320 with L304 FEL needs quick change adapter on FEL #27
CAT D6T LGP DOZER (A58214)
CAT D6T LGP DOZER...
2007 FELLA SM350 3 PT DISC MOWER (A55315)
2007 FELLA SM350 3...
2019 FORD F150 STX CREW CAB TRUCK (A59823)
2019 FORD F150 STX...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
2004 DCT PUMP TRAILER (A58216)
2004 DCT PUMP...
2021 VERMEER S925TX STAND ON SKIDSTEER (A52709)
2021 VERMEER...
