Repairing MF35 Utility Hydraulics
/ Repairing MF35 Utility Hydraulics #1
shaeff
Hudson Valley, NY
MF Utility 35 Gasser, JLG LJ500
Some of you may remember my thread from a few months back:
http://www.tractorbynet.com/forums/...c-vintage/347197-early-60s-mf-35-utility.html
Well, life got in the way for a while and the tractor was on the back burner for a few months while I sorted out other issues. To sum up my issue from the last thread (which is way long at this point), I bought a MF35 Utility, got it all up and running except the rear hydraulics did not function. I came to the conclusion that the lift cylinder studs snapped off of the lift cover assembly. I finally got around to opening up the rear of the tractor on Saturday, and that's exactly what happened. I'm not sure whether it's due to water ingress, or the previous owner lifting something that was way to heavy and possibly bouncing it over a bump. The fact remains that the lift cylinder is indeed snapped off, all four studs. It otherwise seems to be in good condition.
I have the factory AGCO manuals, but one of the exploded diagrams is still leaving me with a question concerning the hydraulic pump. Considering how easy it was to remove the lift cover, I'm tempted to fix the lift cylinder and put it back together to see if it all functions, but wanted some opinions first.
Third picture below shows the innards of the tractor as seen from the rear. The lift cylinder was sitting on top of the main drive coupler, and the rock shaft was hanging down. In the upper right corner, all the way down in front of the hydraulic pump, I found a very long spring. It looks as long as the springs used for the lift/draft controls. I know there is a spring in the hydraulic pump down in that area as shown in the second picture I got from Google. This spring I found is easily 8-10" long. Is it likely that it came from the lower left side of the hydraulic pump picture?
I'll have to try and drill out the four broken studs, as the lift cylinder appears otherwise undamaged. I'd like to reuse it if possible. Aside from the usual o-rings here and there, is there anything else I should replace inside? Can I fill this thing with some diesel (to continue to flush the system) and run it with the lift cover off to see if the pump works? Without the stand pipe bolted in, I'm betting it would make a huge mess, right?
Thanks, all!
/ Repairing MF35 Utility Hydraulics #2
Thanks, all!
I'm more familiar with the TO/TE-20, -30, which has a different hydraulic control system. However I don't see that anything is damaged from whatever broke the lift cylinder attach bolts. Before you attempt to use the same lift cylinder, check the lift cover mating surfaces for flatness to make sure the lift cylinder was not distorted.
Attempting to run diesel in the system with the lift cover off will give you a geyser of diesel out of the standpipe. I'd build a defector (slide a rubber hose over it and point the end down into the sump) over the standpipe to pump the fluid back into the hydraulic compartment. It will tell you that the pump will pump with no restriction on it and that's not much info. I'd just try to turn the pump via the pro shaft by hand or maybe with a pipe wrench to see if there is anything mechanically interfering with it. If there is, drop the pump. If not, reassemble and test with fresh fluid after you have it buttoned up. You'll get meaningful information with the regular restrictions in the hydraulic circuit.
I'm pretty sure if the pump needs rebuilding it can be dropped without removing the lift cover. But check your shop manual to be sure.
As far as that spring, look in the parts manual to see where it goes. I don't think it's on the pump. I think it is under the lift cover where the control levers are attached. maybe someone with more MF 35 experience can be more helpful.
/ Repairing MF35 Utility Hydraulics #3
I've run the engine at idle with the lift cover off, and moving the pump control lever back and forth you should see the oil flow off and on out the standpipe hole. Pump comes out the top on the 35, 50, and 65 models, not out the bottom like 20 and 30. MAKE sure when replacing the lift cover the levers are in FRONT of the roller, I've used the dipstick through the lower side plate hole to hold the lever back.
I have a friend who has a mechanic's straight edge, so I'll use that to check the lift cover. When I emptied the case of oil right after I got the tractor, there was a little oil, and mostly water. I'm fairly certain that the case froze and broke the lift cylinder off. Luckily just those four studs, so as long as I can drill them out, hopefully I should be good. My main concern is with that large spring I found in the bottom of the case. Looks to be the size of the hydraulic lift/draft control springs, but it was broken in half and in the front right of the case near the lift pump as you look at it from the back. I need to make sure that spring didn't come from the lift pump. Maybe I'll try filling the case a bit and making a deflector just in case my RPM are a touch high when it fires. I know there's nothing interfering with the pump, as the PTO works fine, and I've driven the tractor (before I figured out what went wrong in the case) There were no odd noises or anything.
I don't see any way of getting the hydraulic lift pump out without pulling the top cover again, nor did I see any other method in the AGCO manual. That's why I'm considering pulling the pump now while the lift cover is off, replace o-rings and whatever is worn, refurbish the adjustments on the lift cover, then I know everything back there will last me another fifty years.
I did look in the parts manual to see where that large broken spring goes, but since I'm 100% unfamiliar with the pump I can't say for sure. It appears to be the size of the lift/draft lever springs, but neither of those are missing (maybe replaced and the old one fell in the bottom?) and I don't want to risk putting it back together then have to pull it all back apart.
Yep, I see where the stand pipe connects to the pump, I just wanted to be sure it wouldn't force fluid out like crazy. As for your last statement, I've read that a few times. I just read a thread on another forum where a guy fixed his lift cover adjustments and lift cylinder, started the tractor, and the lift arms when all the way up, didn't stop, and snapped the rear of the tractor nearly in half! That would be terrible, so I may order the vintage tractor engineer DVD regarding the hydro pump overhaul and draft/lift adjustments. I want to make sure I've got it 100% correct before starting it. Maybe I'll leave the lift lever in the down position, and crank it over with the coil disconnected to make sure that the lift arms don't do anything funky.
Thanks for the suggestions guys.
Edit: just for kicks, I looked on eBay for new hydraulic pump, found one sold by a fella named hamiltonbobscubs that's supposedly new for about $120. If I were to go that route, just for peace of mind, I'd replace the relief valve with a new factory unit to ensure it doesn't over pressure my system. The only reason I'm asking, is that a rebuild kit costs about $170 from various sources. Thoughts? Are these pumps any good?
Here's a link: New Hydraulic Lift Pump Fits Massey Ferguson MF to 35 50 65 MF35 TO35 MF50 MF65 | eBay
vs rebuild kit:
Ferguson Hydraulic Pump Repair Kit for Ferguson 35,65,135,TO35,150,165,175,202,2135,302,304,50,765 - S.40843
/ Repairing MF35 Utility Hydraulics #5
On my friend's 35, I had the gearbox off the rear casing to renew gearbox bearings and seals a couple of years ago. I believe the pump from memory would have been easily removed at this point as well - only a front PTO shaft to remove, although it's a snack to remove the top cover in comparison to splitting the casings behind the gearbox. BTW, you may need to remove your PTO output shaft in order to remove the hyd pump with PTO front shaft. I can't remember the finer points with any accuracy, but looking at your 3rd pic, it may be difficult to get the pump upwards past the gearbox-to-diff driveshaft.
Yep, according to the manual, the main driveshaft has to come out (easy, pull cotter key/slip yoke), and the PTO shaft as well, which is also pretty simple- pull the bolts off the rear PTO housing and slide it out. This coming Saturday I should have the pump out, then I'll start making a parts list.
/ Repairing MF35 Utility Hydraulics #7
Great stuff! You have an advantage - a manual to consult. I forgot about the splined sleeves! They were intended to fail in the event of inordinate shock loads before anything major was damaged, and be renewed easily. Have never seen one broken though - they must be pretty tough, like everything else! Nothing scary there ... just be careful and attentive to detail, a reasonable standard of cleanliness and specs & settings. Give it your best shot. :thumbsup:
Well, I gave it a shot today. Got the sheer collar out in about 40 seconds. I cannot, however, get the PTO shaft out. I removed the three bolts for the retaining ring, I pulled the large diameter seal retainer with no issues.
I had a screwdriver through the hole in the PTO shaft and pried against the rear of the tractor with huge pry bars, still no luck. The shaft spins freely, but I'm guessing that the water in the case seized the shaft inside the inner bearing race. Suggestions? Other than this setback, the hydraulic pump is ready to come out!
/ Repairing MF35 Utility Hydraulics #9
The bearing is seized into the transmission casing. You need a slide hammer to "shock" it into moving. Don't forget there's a serious amount of oil there! Tapping it inwards a little may also achieve this. I'm pretty sure they are all the same - two pry-bars or some sort of slide-hammer on a strong bolt through the hole in the shaft might be needed to move it outwards. The bearing has from memory a snap ring/circlip before it on the PTO output shaft and this shaft should come straight out the back with the bearing on it. Renew the seal, O-ring and bearing (they are very cheap) and grease the outside of the bearing and the seal lip on reassembly. I would also strongly recommend fitting the protective cap available for covering the PTO shaft and seal area.
Ah nuts, the forum glitched and I lost my lengthy response. I'm out of time, so I'll leave the abridged version:
I tried a slide hammer quickly but had used a piece of chain to connect it. I'm lost too much striking force through the chain, I need to figure something more rigid, maybe bend something through the PTO shaft and just cut it off when I'm done. I'll figure something out. I tried tapping it inwards as well, but didn't want to destroy the bearings. If I have to, then so be it, it'll give me a reason to grab a nice hydraulic press. :)
I've got a parts list going so I can make one large order for everything I'll need. If i can save the bearing I'd like to, as it's still smooth as silk with literally no play in it that I can feel at all. I'll also grab one of those PTO caps, that'll help keep out some of the debris when it's not in use.
Thanks, Patrick!
/ Repairing MF35 Utility Hydraulics #11
It's called technology - Computers are supposed to make life easier! :mad:
Don't stress - PTO shaft is brutally strong, but circlip in front of bearing may let go - this will help!
A soaking for several days with penetrating oil will assist..
*** Remember: Bearing holder (round, but with two flats) is held in housing by three bolts through retaining plate and is sealed by a thick O-ring.
Bearing, seal and O-ring are very cheap to buy (here at least). Bearing is also quite robust and will stand up to some force.
A slide hammer is the best tool, to connect it maybe sacrifice a D-shackle just larger than the shaft diameter, and a strong bolt through the hole with a nut to close it against the shaft.
Best of Luck! :thumbsup:
Right on!
I've got the inner seal and outer o-ring on my parts list for the bearing holder. Definitely replacing those. I'll swing by the hardware store and see if I can find a suitable D-shackle. That's a pretty good idea!
/ Repairing MF35 Utility Hydraulics #13
Yep, start by spraying the area again regularly with penetrating fluid, then grab a couple of shackles, beefy-looking ones - as close to the shaft diameter as you can find. You will need a 1/4" bolt & nut through it and the shaft, strong enough so as to not shear under stress. Pull it just tight enough to close the shackle onto the shaft, but any further tension will only be counter-productive. Add a serious-calibre slide-hammer with an eye on the end. Be aware the shackle or the bolt may break, you may also quickly succeed instead! :thumbsup:
I can't remember the specific shape of the shaft inside of the casing, but you may pop the circlip off and get only the shaft out. Then you'll need to get inventive to engage the slide-hammer in the bearing - I suggest a short but stout piece of round bar through the slide-hammer eye and across the inner edge of the bearing (you might need long-nose pliers, a magnet, an assistant, or all three) :eek: If if comes to this, I would feel more comfortable renewing both the bearing and the circlip.
As my father used to frequently repeat: On reassembly (after cleaning off rust and scale etc), coat over-lapping surfaces and all screw threads & shanks with grease ..... think of the next poor guy removing them - it could easily be you!
Example: Our MF135's rear wheels were last off in 1981 for replacement rear tyres. I punctured one about three years ago - the first tractor tyre I have ever damaged. Just as I was jacking it up after letting the water out, repeatedly re-inflating it until it was almost empty, one of my friends happened to visit. He scoffed at me expecting a 1/2" drive pneumatic gun to undo anything. Imagine his surprise when it removed all 8 nuts holding the centre to the axle and all 6 bolts and nuts holding the rim to the centre! :laughing: That was possible only because the threads were greased ..... and no, they weren't loose at all! I have continued this habit over the years, and found how advantageous it is, especially around cooling system components and also in areas exposed to the elements.
Well, I got it out. It's amazing, I had tried a 6' pry bar attached to a chain last week too. No luck with that. I shoved the bar into the ground and created a nice sturdy hole and let it rip. PTO shaft wouldn't budge. So I tried the D-ring method, but I couldn't get it tight enough and it kindof acted like the chain, it seemed to take up too much of the blow from the slide hammer. So I tried to think of ways to hook the slide directly to the PTO, or more solidly, anyway. Considering I'm working on it at my parent's house, it's not uncommon to see my father wandering around with the dog. He walked by and suggested the method that worked like a charm.
I found a piece of heavy angle iron, grabbed my plasma cutter and cut it down the middle. (I couldn't find anything else thick enough). Ground it down, welded it into a flat piece of steel. I traced the slide hammer end in marker, cut out the holes and bolted the universal end of the slide to the plate. On the back side, I bent up a piece of band iron into a U-shape, drilled two holes and welded it to the larger plate. I stuck a bolt through to hold it to the PTO shaft, gave two very solid hits with a 5lb slide hammer and the PTO shaft ended up in my lap. Excellent.
Now the hydraulic pump is out, sitting on my workbench in my basement. Sometime this week I'll start pulling it apart. I've attached a few pics to make it clearer what I did to get the shaft out.
Also, it seems that the control valve on my hydraulic pump is seized. The large spring I found in the bottom of the sump definitely came from the pump. The good news is that the pump still spins very freely. Hopefully getting the control valve unseized won't be too difficult. I'll take pics as I go.
Thanks for all the help, I'll be back with more updates soon!
/ Repairing MF35 Utility Hydraulics #15
Great news - you got it out! Love your work! :laughing: Persistence combined with ingenuity pays off! :thumbsup: I like your and your Dad's idea very much - obviously very effective too. I've never seen any stuck as tightly as that. What a mission! Now you can continue. I look forward to seeing your continued progress. :)
Haha, thanks Patrick!
I've got the pump torn down, I just need to grab my snap ring pliers to get the valves out for inspection. It looks like work may have been done to it at one point, though I can't be sure. I found a piece of debris in the pump that might be the remnants of a broken piston ring. I find this odd because my pump is fitted with the filter, but I digress. There is a little marring of one of the brass journals, but I can't feel it with my fingernail so I'm not overly concerned about it. I forgot to take pics (my hands were very oily, so not a lot of pics) of the brass cam blocks. There is a little marring on them, too, but not on surfaces that make contact with anything else. It looks like debris fell on top of the pump and as it rotated, got crushed against the pump casting and pistons. I'm checking with my local Massey dealer today to see what he thinks, he used to work on these machines daily so I trust his opinion.
Also, of note- for anyone looking to rebuild their pump, the Vintage Tractor Engineer DVD is truly the way to go. It takes out all the guesswork and goes into great detail. I'm pretty certain I could have pulled this apart and put it back together, but they go into detail about what to look for, and all the adjustments you need to make to the control levers and draft spring to make your hydraulic system function as intended. I highly recommend it!
On to the pics, they're grainy because I was working in my basement. My hands were oily, so cut me some slack. :)
/ Repairing MF35 Utility Hydraulics #17
Great, you've surged forward now! Nothing really high-tech - just thoroughness and attention to detail.
Yep, I had a concern about the brass cam blocks being slightly scored, even though the scoring isn't on a mating surface. Local Massey dealer says they're fine. Looks like a good cleaning, new 0-rings, control valve/spring assembly, and pressure relief valve and I'll be putting it back together. Very promising!
I'm VERY happy I pulled the pump out, despite that pesky seized PTO shaft. The control valve wasn't operable in it's condition. The c-clip and end piece are long gone, the spring was laying in the bottom of the case, and the control lever with the rollers was not connected to/touching any part of the valve. I'd have been quite upset if I put it all back together and it didn't work.
/ Repairing MF35 Utility Hydraulics #19
Yes, it would not have made sense not to have investigated the pump condition having already gone that far into diagnosing the problem.
It all sounds rather straightforward from here.
My thoughts exactly. I ordered all the parts I need to put the hydraulic system all back together. A full rebuild kit for the pump only cost me $150, then I got all sorts of other assorted o-rings and stuff for the stand pipe, and for the top lift cover too. Hoping they'll all be here before the weekend after this coming weekend, then I can put the pump back together and drop it in.
I do have another question:
The four studs that hold the lift cylinder in place- are they special studs? I've read that they're just grade 5 studs, and I've also read that they're special hollow studs designed to sheer if the hitch is overloaded. The guy at the Massey dealer told me that they're just grade 5 studs. That being said, when he looked up the price, they're $27/EACH! If they're just grade 5, I'll see if I can source my own. If they're special hollow studs, I'll order factory studs. (ouch!)
