Standby generator when fire hits your house
   / Standby generator when fire hits your house #1
RalphVa
Super Member
Charlottesville, VA, USA
JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
Anyone done anything to disable your standby generator in case of a house fire?
The home inspector came by with our solar panel contractor, to do the final inspection.
She cited them for not putting the building's input (from the solar panel) at the bottom of the panel in the house. She said fire code requires inputs be at top or bottom of a panel so firemen can turn them off in case of fire. That got me to thinking. If they did that, my generator would come on. What are the requirements for disabling ones generator in case of fire. (Also crossed my mind: why the **** would firemen come into a burning building to flip breakers when they can quickly just pull the meter outside? You don't want to trouble inspectors too much with such questions.) (My generator inputs to one 200 amp panel while the solar panels input to another 200 amp panel.)
I'm thinking of putting a quick disconnect end onto one of the battery cables on the generator. Looks as though thumb knob or knife edge ones are available.
What have others of you done?
Ralph
   / Standby generator when fire hits your house #2
Why would it matter? Unless they pull the meter the feed from the power company is still live.
   / Standby generator when fire hits your house #3
30 years as a fireman and I never pulled a meter. Kill the main was our standard and never ran into a backup generator but I worked in an urban area.
   / Standby generator when fire hits your house #4
Ralph
Is there a transfer switch in place between the panel and genset? If so, the transfer switch will turn the genset on, if it's on auto start*. Usually there is a disconnect at or near the genset to disconnect it from the house as needed for servicing or emergency.
*I corrected what I erroneously stated in this post earlier today
   / Standby generator when fire hits your house #5
EXPLOSIVE Bolts on just about everything! You gotta admit, those things sound exciting.
Good question. I throw my main switch to get my (200 amp) transfer switch to flip over (for testing). There is a switch for this, but throwing the main is more convenient. But that's after I have started the generator. I don't want my genset to start automatically for a number of reasons, and I guess this might be another good reason.
There should be an emergency STOP switch somewhere in clear view. Something I may consider.
   / Standby generator when fire hits your house #6
You can pull the meter on my house, and the solar will switch from grid tie to off grid feed....and you'll have a 1200amp/hr @24v battery bank feeding it.
Not that it matters anyway....our local dept is known as the MarshMellow Patrol.....they get there about the time the embers are perfect to roast marshmellows.
   / Standby generator when fire hits your house #7
Never ran into that problem. Ive hooked many gennys into many mains. And yes, when you turn off main the gen will fire up.
Again, no one has ever said anything about this
   / Standby generator when fire hits your house #8
EXPLOSIVE Bolts on just about everything! You gotta admit, those things sound exciting. Good question. I throw my main switch to get my (200 amp) transfer switch to flip over (for testing). There is a switch for this, but throwing the main is more convenient. But that's after I have started the generator. I don't want my genset to start automatically for a number of reasons, and I guess this might be another good reason. There should be an emergency STOP switch somewhere in clear view. Something I may consider.
Why do you not want your generator to start automatically? I consider this a huge plus. If I am away from home for an extended period and the power goes out my generator will start automatically. The plus to this is the food in the freezer ( over $1000 worth) won't spoil and the water won't freeze. Most of these standby generators are powered by nature gas. The FD could just shut off the gas meter which is a good idea anyway.
   / Standby generator when fire hits your house #9
CODE required that if my inside distribution panels (two 200 amp) were more than 3 feet wire distance from the meter base, that there be a inside disconnect switch within the 3 ft distance. Supposedly so that the fire department could remove power from the house in case of a fire. So I had to buy and wire two 200A disconnect switches IN THE BACK CORNER OF THE BASEMENT! Added about $500+ to my electrical system cost.
I'm not a fireman, but the back corner of the basement is the LAST place I would intentionally go if I WAS a fireman responding to any house on fire! And the only way they would know that the disconnects existed is by tracing the incoming service from the meter by being IN the basement. Made no sense to me at all.
- Jay
Zero Turn Mower (A48082)
Zero Turn Mower...
2011 Kubota M7040SUD 68HP 4WD Utility Loader Tractor (A49461)
2011 Kubota...
2012 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2012 GENIE...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
