Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #2,621
I'm a new member but a long time reader. How is the ground speed with a flail mower vs. a rotory cut of the same width? I do a lot of cutting for food plots and normally they are cut once per year, so vegitation can sometimes be tall.
/ Let's talk flail mowers #2,622
I've never actually measured but I tend to go a little slower with flail because I'm looking for a better cut. With a rotary I'm just knocking stuff down.
/ Let's talk flail mowers #2,624
I've found for me ground speed is pretty similar but my rotary mower is 5' and my flail is 7'4" and the result of my cut and the forgiveness in rough terrain means I almost never use the rotary mower.
/ Let's talk flail mowers #2,625
Well, managed to lose my detailed response :(
Still original belts, still in great shape.
Replaced the two rear roller bearings a couple years ago, only one went bad. No zerk for lube.
Last year replaced the bearing on shaft from gear box. My fault as I hadn't checked the lube in a while.
Main shaft bearings tight and true, couple shots of grease and broken hammers/blades replaced ASAP.
All originals bolts and nuts.
3rd set of blades. I used the first set of hammers as ground engaging to even out wild pig rooting.
Betsco has been great support. Reason I bought from them again.
David Sent from my iPad Air using TractorByNet
Thanks for the response Dave. I think that clinches it. Sounds like a quality machine, I will get my order in as soon as the money accumulates.
Smilinjak
/ Let's talk flail mowers #2,626
Same here, my travel speed is lower with the 7' flail, but I get a better cut in about the same time or less than my 5' rotary cutter.
/ Let's talk flail mowers #2,627
The flail mower arrived for my panther finally.
[/URL]
It arrived in a nice steel frame. Here I am setting it up.
[/URL]
Tried it but it was a bit low so I raised it up one notch and wow. I have already mowed a paddock with it. Fantastic job.
All Dirty
[/URL]
/ Let's talk flail mowers #2,629
Thanks. There is a small fault. If you look at the assembly photo you can see several yellow plastic plugs. These are removed if you want to fit a hydraulic side slip assy.
However, after a half hour mowing, they were all gone. Yep, down the paddock somewhere. Obviously debris drove them out from underneath. Doesn't appear as if anything comes up through the holes though. Not an issue. I am just surprised by the fact. I may put some little dome head bolts in the holes.
/ Let's talk flail mowers #2,630
Well, after a couple of days of use I must say I am extremely impressed with the mower. I have thrown everything at it from Lantana, saplings, dried up stick debris, dirt, stones, and even some small stumps that were hard to see in the grass.
The mower has come through with flying colours so far.
I did regular inspections of the hammers and they look as good as new so far.
I re-checked the tension on the belts and greased it a couple of times so far. The only other minor thing was I re-positioned my 3PL so it sat better.
My paddocks never looked better. Still got a ways to go but......
I even got my chainsaw out and cut a lot of low branches off some trees so I could drive in under them easier. My place is starting to look like a city park. :D
I would have no hesitation recommending this mower.
/ Let's talk flail mowers #2,631
I'm curious. Do the current line of flail mowers drive the cutter drum at PTO speed or does the gear box over-drive it? I've noticed that most have only one drive belt. My flail has three drive belts but I suspect that's because the larger drive pulley over-drives the drum pulley about 2:1 or there about.
In fact, its upper pulley outer diameter is 170mm, its lower pulley outer diameter is 120mm, so its ratio is 17:12. This mower is called EFGC flail mower in China Alibaba, you can find many of them, but it is difficult for you to identify if good or bad.
/ Let's talk flail mowers #2,632
Hi Alien, this mower is from a factory in my city, can you take a photo for me about its gear box brand? I would like to see what gear box they are using now. Is it "JCTT"? I m quite familiar with this mower.
/ Let's talk flail mowers #2,633
Will do Jack, Without getting notifications any more, I missed this request. Later today when I wake up properly....
Edit
Nipped out and had a look. Yes, It is a JCTT. If you want a photo I will do that later.
I have done quite a bit more with it already and love the way it shreds lantana etc. It really does a great job.
/ Let's talk flail mowers #2,634
Neighbor has a Ford flail mower he offered to sell. The tag is beat up and old! Looks like model: 1 22-I08 and serial number looks like I (or L) 958. He said he used it, but got a bigger mower. Looks like it's been over the mountain a couple of times!!
Anyone have an opinion of this model. I need something for a 30HP tractor to cut some buck brush. Thanks.
/ Let's talk flail mowers #2,635
/ Let's talk flail mowers #2,636
Neighbor has a Ford flail mower he offered to sell. The tag is beat up and old! Looks like model: 1 22-I08 and serial number looks like I (or L) 958. He said he used it, but got a bigger mower. Looks like it's been over the mountain a couple of times!! Anyone have an opinion of this model. I need something for a 30HP tractor to cut some buck brush. Thanks.
Can you post a photo?
/ Let's talk flail mowers #2,637
Ya, would help a bit with photos.
If its anything like the old thrashed 917 I got for $100 & spent $400 & 2 weekends on, it will be way worth it.
/ Let's talk flail mowers #2,638
Does it look like this one on eBay? Ford Model 22 108 Red Flail Mower Demo Video | eBay
/ Let's talk flail mowers #2,639
Hey Alien, nice mower but how bout a picture of that paddock? A before and after would be great but might be too late for that!
2016 Hino 195h Truck, VIN # JHHSPM2H9GK001609 (A65563)
2016 Hino 195h...
Rhino Servis 2160 Ditch Bank Mower (A62180)
Rhino Servis 2160...
Lowe Pontoon Boat and Trailer (A65579)
Lowe Pontoon Boat...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A63118)
Bulk Lot of NEW...
2001 Pierce Tilt Crew Cab Pumper Fire Truck (A61573)
2001 Pierce Tilt...
Concrete Mixer (A62613)
Concrete Mixer...
