Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #2,581
Hello Hoochy,
I want to welcome you as the newest member of the Flail Mower Nations.
OK you definetely have a problem if the V belt guard cannot be reinstalled.
The V belt that was on the flail mower is the wrong size.
Now, where is the spring that connects to the tensioner arm of the flat idler
to keep tension on the flat side of V belt??
I will have to check my parts catalog for this model SH74's parts and numbers
I will get back to this later today.
/ Let's talk flail mowers #2,582
Hello Leonz, yes the belt that is on now is a bit narrower, the OEM belt is a bit wider and shorter. The spring tensioner is in place and in good working order. 20151204_131018.jpg
The new belt is M-100706 which is what my parts manual calls for.
The guard can be tricky to take on and off, maybe i need to try to get it behind the idler and the bottom first then slide to top in or something.:confused3:
Thanks, any help is appreciated.
/ Let's talk flail mowers #2,583
Hello Leonz, yes the belt that is on now is a bit narrower, the OEM belt is a bit wider and shorter. The spring tensioner is in place and in good working order.View attachment 451351
Hello Hoochy,
as time is short for my evening chores, The V belt guard goes on one way and comes off the same way-patience and take good look at the parts diagram of the mower to see everying there.
1. I want you to remove the current belt
2. remove the idler arm
3. replace the grease fitting in the idler arm
4. clean the old grease off the idler arm shaft
5. use some fine grit emery cloth to clean it more
6. make sure the flat pulley idler is not stuck or sticking
7. use fresh grease in the new idler arm fitting and make sure it can swing a wide arc.
8. reinstall the idelr arm spring
After that you should have no issues using the OEM Belt .you need the OEM belt and
then use a hose with hot water to wash off all the dirt under the V belt guard and around the pulleys.
/ Let's talk flail mowers #2,584
Hello Hoochy,
You need to use the OEM V belt, and please some grease in the idler arm too
as it looks like it has not seen any in while
/ Let's talk flail mowers #2,585
Thanks Leonz. That pic is a bit older. Since then, I have done all you mentioned above to ensure the arm was well greased and moving freely, and started sanding blasting and prepping for a paint job. The idler was moving freely and there were no issues with the arm swinging or being tight. The spring is also very strong although it looks like crap. I plan to replace it after the paint job.
I was thinking maybe someone replaced the idler pulley with one of a larger diameter to accomodate the longer belt??? Do you know what the diameter of an OEM pulley is supposed to be?
I am not at home ATM, but I can measure mine next week.
Thanks again!
/ Let's talk flail mowers #2,586
The Toro Flail mower head in question is a finish cut flail mower.
A finish cut flail mower will have:
Balanced FLAIL MOWER ROTORS that have THREE or FOUR rows of paired side slicer knives that are spaced to follow behind and slightly left or right of the knive pair in front of it to provide adequate coverage and provide a finish cut quality to the mowing job.
Scoop knive flail mowers/shredders have wider cuting edges ment ot cut material ONLY ONCE and cannot recut the material as it has ben cut to its final length no matter how tall the grass or brush.
The Spiral mounting of a sccop knives/hammers on some flail shredders is simply a way to enable the end user to have an all purpose shredder/mower with fewer knives and a poorer cut in thew scheme of things that will not shred and slice the material finely enough to rot and dissolve quickly.
I hope this settles the issue.
The scoop knives actually cut more than once. If I cut one foot tall grass I wind up with clippings and not one foot tall grass pieces. The scoop knives cut several times from when the front of the rotation reaches the grass until the bottom of the rotation does the final cut. Side cutter knives are considered industrial knives while scoop knives are considered finish cut knives. From my experience scoop knives provide a more even cut verses a serrated cut.
/ Let's talk flail mowers #2,587
Update on my belt issues. I emailed Alamo support and Mr. Quesada quickly replied with the answer. He confirmed that the belt that came with the mower is not OEM and also suggested that there are some manufacturers producing a similar belts to the 100706, however the "M" designation in front of the number confirms it is not an Alamo belt and thus too short causing guard issues. It is what I get for trying to save a few bucks and buying off flea bay:ashamed:
Yes, a new OEM belt is on the way....minding the holidays I'll have it next year:laughing:
/ Let's talk flail mowers #2,588
Here's a pic of the belt I bought, notice the "M".....not EOM and although it will work, it will make it impossible to use with the belt guard because it is a bit shorter than OEM belts.s-l500.jpg
Just though I would let you all know in case you are considering a new belt. Stay clear from these with the "M":thumbdown:
/ Let's talk flail mowers #2,589
Here's a pic of the belt I bought, notice the "M".....not EOM and although it will work, it will make it impossible to use with the belt guard because it is a bit shorter than OEM belts.View attachment 451416
Make sure to leave some feedback for the eBay seller.
/ Let's talk flail mowers #2,590
Hello all. I must say this is one long thread! New to TBN and want to thank you for all the info, specially on this thread, which help me with my decission to buy a flail. It's an Alamo SH74, fine cut. It was state DOT owned and all it needs is a decent paint job.
I have been mowing with the belt it had on but ordered a new one. The new one appears to be a little shorter than the one it had on and the idler pulley sticks out too far to attach the belt cover.
Original belt
Sorry i do not have a pic with the new belt, but I hope you get the picture
Any suggestions?
Are you sure you got the right belt? I hope you love your flail as much as I like mine. I have an SHD88. Love the thing, mine is regular cut not fine but **** it's tough and I work it hard.
Where did you get your belt from? I get all my knives/belts from Flailmaster and I've never had an issue. Our models should take the same belt. M-100706 Belt for Models #50,62,74,88 & 96
Rear Mount $25.10
You can view their catalog here: http://flailmaster.com/wp-content/uploads/2014/01/FlailMaster_Catalog.pdf
And their website here. Our Products | Flail Master
You have to call them to order stuff but I've always been happy with their service and their products. I've gotten a new belt, drive side bearing, new rear roller bracket and bearing, new belt, new transfer drive shaft bearing (the upper pully bearing) and lots and lots of knives from them. :) On a side note my shield is cracked in a couple of spots and I haven't gotten a new one or gotten in welded, so I have just been running without it on. I'm not mowing in areas where there would be kids about etc to be in danger of getting into the pully system but obviously it would be safer to have it on.
/ Let's talk flail mowers #2,591
Does anyone own any self-powered flail mowers? I have one that I use to pull behind my ATV but I'm thinking of adapting it to pull behind my 35hp tractor (no PTO) and use the tractor rear remotes to control offsets left to right to maneuver around my 10 acres of pine trees. Any ideas?
/ Let's talk flail mowers #2,592
PRCWI according to the ebay ad it was supposed to be, not! And there is another seller selling the same non EOM belt also. I will keep it just in case but the OEM belt will be installed as soon as I get it.
I just love this mower, truly amazing...and I am looking for the 88 as well, if I find a good deal like I got on the 74
/ Let's talk flail mowers #2,593
Yep, I can see a very tight spiral. ;)
I can also see straight rows of hangers slightly offset from the previous row. :D
That's just the coincidental result of spacing them around the spiral at some even spacing that divides evenly into 360 degrees. Just a lucky coincidence you see. It's a spiral for sure!
/ Let's talk flail mowers #2,594
I'm curious. Do the current line of flail mowers drive the cutter drum at PTO speed or does the gear box over-drive it? I've noticed that most have only one drive belt. My flail has three drive belts but I suspect that's because the larger drive pulley over-drives the drum pulley about 2:1 or there about.
/ Let's talk flail mowers #2,595
Leonz - You're a good man. I did sharpen the knives last winter. I guess the answer is to toughen my ...s in the tractor seat more often to prepare it for 3K mile trip on my Ducati Multistrada this summer from New Mexico to Montana. Only other option at this point is a Caroni 1900 or a Landpride.
Regards,
Sam
/ Let's talk flail mowers #2,596
From what I read it is around 2.1 ratio. The one I am ordering has 3 belts. FLAIL MOWER HPHD1500
/ Let's talk flail mowers #2,597
Have done some sanding priming and prepping my Alamo for final paint. This is after all the prep and 2 coats of base yellow. Did work it for a weekend and hope to do the final paint job later on this week. Hum, now I am having trouble uploading pic:confused3:
/ Let's talk flail mowers #2,598
They may too large now after the Forum Sever Upgrade. Try re-sizing down to 800x600 or smaller.
If using a phone you need to be on Tapatalk.
/ Let's talk flail mowers #2,599
Thanks Xfaxman I am using my Samsung tablet and they are big...ooops....do have the option to downsize, so I will give that a go.
/ Let's talk flail mowers #2,600
Second try downsized
John Deere 980 30' Field Cultivator (A66285)
John Deere 980 30'...
Coleman Go Cart, 2 Seater, Gas Engine (A65640)
Coleman Go Cart, 2...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63689)
2023 Takeuchi TL6R...
2011 Takeuchi TL250 Compact Track Loader Skid Steer (A64553)
2011 Takeuchi...
2022 YANMAR VIO35-6A EXCAVATOR (A63276)
2022 YANMAR...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
