Metal Building Lighting?
/ Metal Building Lighting? #41
40' x 60' x 16' ceilings. Five rows of four t8 32 watt 6 lamp fixtures. Each row is switched individually, each fixture has two ballasts which are split, So 10 switches total. image.jpeg
/ Metal Building Lighting? #43
Is that 3.84 Kw-hr to run these?
Thats what the math tells us. 20 fixtures each with 6 32w bulbs. 120 bulbs @ 32w = 3840watts
I have 10 of those fixtures in a 40x40, with another 6 fixtures with 4-bulbs along the workbenches and over the loft.
/ Metal Building Lighting? #44
40' x 60' x 16' ceilings. Five rows of four t8 32 watt 6 lamp fixtures. Each row is switched individually, each fixture has two ballasts which are split, So 10 switches total.View attachment 444541
I have 20 lights similar those also, but my shed is a bit bigger. My electrician installed them so I don't know if they have 1 or 2 ballasts. It gives me an average of 65 lumens at the floor. Mine were wired up to run on 220V and have only 2 switches. It sure is nice to have enough light to work in comfortably.
/ Metal Building Lighting? #45
At full power (both ballast) the light level is generaly 100-120 foot candles, the corners are around 80-85.
Most of the time I run at 1/2 power.
/ Metal Building Lighting? #46
That is correct, at my electric rates that's about 60 cents an hour at full power. Most of the time I run at half power though. Good lighting makes for easy working.
/ Metal Building Lighting? #47
I hear you about the lighting. I can't see anything without it. (no pun intended).
/ Metal Building Lighting? #48
I have a couple of sayings; "too much is just enough" and " you can choose to not use something you have but you can't choose to use something you don't have".
Everytime I go somewhere with my wife she say's " should I bring a jacket?" I reply with the second saying above.:)
/ Metal Building Lighting? #49
Nice building Todd727. Can I ask who the manufacturer was? Are you happy with it/would you do anything different?
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
New/Unused Wolverine 48in Mini Combination Bucket (A65583)
New/Unused...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
New/Unused Landhonor Power Rake (A65583)
New/Unused...
2012 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A65643)
2012 TROXELL...
2022 FORD F-750 SUPER DUTY DUMP TRUCK (A63276)
2022 FORD F-750...
