Metal Building Lighting?
/ Metal Building Lighting? #41
40' x 60' x 16' ceilings. Five rows of four t8 32 watt 6 lamp fixtures. Each row is switched individually, each fixture has two ballasts which are split, So 10 switches total. image.jpeg
/ Metal Building Lighting? #43
Is that 3.84 Kw-hr to run these?
Thats what the math tells us. 20 fixtures each with 6 32w bulbs. 120 bulbs @ 32w = 3840watts
I have 10 of those fixtures in a 40x40, with another 6 fixtures with 4-bulbs along the workbenches and over the loft.
/ Metal Building Lighting? #44
40' x 60' x 16' ceilings. Five rows of four t8 32 watt 6 lamp fixtures. Each row is switched individually, each fixture has two ballasts which are split, So 10 switches total.View attachment 444541
I have 20 lights similar those also, but my shed is a bit bigger. My electrician installed them so I don't know if they have 1 or 2 ballasts. It gives me an average of 65 lumens at the floor. Mine were wired up to run on 220V and have only 2 switches. It sure is nice to have enough light to work in comfortably.
/ Metal Building Lighting? #45
At full power (both ballast) the light level is generaly 100-120 foot candles, the corners are around 80-85.
Most of the time I run at 1/2 power.
/ Metal Building Lighting? #46
That is correct, at my electric rates that's about 60 cents an hour at full power. Most of the time I run at half power though. Good lighting makes for easy working.
/ Metal Building Lighting? #47
I hear you about the lighting. I can't see anything without it. (no pun intended).
/ Metal Building Lighting? #48
I have a couple of sayings; "too much is just enough" and " you can choose to not use something you have but you can't choose to use something you don't have".
Everytime I go somewhere with my wife she say's " should I bring a jacket?" I reply with the second saying above.:)
/ Metal Building Lighting? #49
Nice building Todd727. Can I ask who the manufacturer was? Are you happy with it/would you do anything different?
Coats 5060AX Rim Clamp (A63689)
Coats 5060AX Rim...
2014 Jeep Wrangler 4x4 (MPV), VIN # 1C4BJWDGXEL206125 (A65579)
2014 Jeep Wrangler...
1980 Gleaner F2 with heads (A61307)
1980 Gleaner F2...
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
SEARS ELECTRIC AIR COMPRESSOR (A64276)
SEARS ELECTRIC AIR...
(3) Tires (A65640)
(3) Tires (A65640)
