pole barn insulation
/ pole barn insulation #1
Zerk
Wisconsin/UP
New Holland 2120
I'd like to insulate all or start with half of pole barn walls. Mostly so I hang sheeting and mount stuff on walls, that I won't have to move later.
Eventually will have Woodstock but for now torpedo heater. I paid extra for insulated doors, for future.
6x6 poles 6' apart. I am thinking some kind of 6' insulation with barrier on one side??? 9' strip would be nice, but I am thinking it will be a roll.
Book shelf 2x4s on edge and flush with front of 6x6????
25x30. I use it shop, with maybe more shop use someday. But time and money are factor. This is my camps barn.
Some did recommend products and tips?
Foam would be nice but to much money. I have wondered about foam along bottom for rodents. Not sure what or where to get if I did.
/ pole barn insulation #2
It kind of sounds like you want to do the walls before doing the ceiling. If that is true, I wouldn't do it. Insulating the ceiling is much more rewarding than the walls. I did my ceiling and have no intentions of doing the walls anytime soon. It keeps the shed cooler on sunny summer days and stays a little warmer in the winter through natural ground radiation.
I understand ceiling is better.
But I want to start ganging stuff on walls and filling shed. I know my other pole burn will never be insulated because of this.
I may start with just one wall. I want Osb up right away to keep rodents from chewing on it.
Last night getting a shelf out to get behind it to work was bugger. I also screwed down first piece item to it. Which I have been resisting
I also live in area of 300 inches of snow and cold, so at some point I will want wall insulated.
/ pole barn insulation #5
Build false 2x4 walls between the 6x6 post, Stack the studs on a 24 inch center for insulation. Once insulated you could sheet rock if you wanted.
I agree with above about insulating the lid first.
I don't like drywall in barns or garages, ends up banged up not. To flimsy.
What I am looking for is the insulation itself. Anyone have one they used?
You can argue building false walls defeats the purpose of a pole barn.
/ pole barn insulation #8
understand where you are coming from but...., stapling up a vapor barrier and slapping large drywall sheets on the ceiling isn't going to take that much. Then blow in the insulation. Then do your walls OSB. Dry wall lift for the ceiling, really does not take that long. Can use the drywall lift for the wall sheets. I would book shelf the insulation between 6 x6. going length wise insulation has a tendency to slid down settle on long runs.
Ya but that is not my goal.
I just want to get my shop set up.
I was hoping someone here had insulated a pole barn, and product they like for walls. I know to do for ceiling, so I didn't ask.
I have drywall lift.
Since my trusses are 24" will use drywall lift to raise fiberglass bats, on a board. Done this before. Easy by yourself.
But my goal is not for heating it this year. Big torpedo heater will do for now.
My garage has r19 crossed by r30 bats.
Anyone done 6 foot wide insulation? That is what I am curios about. Bookshelf would then be to hang sheets and stuff on wall.
/ pole barn insulation #13
You could use either spray foam ($$$) or blow in cellulose or fiberglass. I have seen both used and the blown in is a simple DIY project. Put the OSB length wise and blow in the insulation in 4ft lifts filing the void between the outside wall and the OSB.
/ pole barn insulation #14
:thumbsup:
/ pole barn insulation #15
Spray foam has a lot of advantages over blow-in or batts. No settling, no condensation issues, effective air infiltration barrier, and it blocks rodents instead of providing a massive nesting habitat. We did blow-in cellulose in our car garage. We are soon going to do spray foam on our shop before covering the walls, hard foam (closed-cell) on the ceiling and open-cell on the walls. We are going to hire someone to do it.
I don't think I will do blown in on the wall of metal building, due to moisture. Maybe if foamed first. Need a way to keep insulation off of metal. Plastic down or some kind of tyvec?
/ pole barn insulation #18
In a building with metal sheeting, I think the only "right" way to do it is spray foam. Metal building cause a lot of condensation, closed cell foam is an excellent moisture and air insulator and it will make your building more rigid.
I got a DIY kit and spray foamed the 14 x 24 Morgan building that we're using as a cabin and it made all the difference in the world. Just an inch of closed cell foam on the walls and roof with R13 and drywall on the walls (ceiling is still open) and we're able to keep it 70* inside when it's 100* outside with 1 12k BTU and 1 8k BTU window unit and they're cycling.
I would strongly suggest finding a way to do at least 1" of closed cell foam on walls and ceiling and then do batt or blown cellulose after that. This is one of those things that is REALLY difficult to change later so an area where you should not skimp on material just to save a few bucks now, the spray foam will pay for itself in time.
Look at your garage wall. How much time would it take to clear it off in order to insulate?
This barn is fairly empty, it won't be for long. Which is why u want to walls, even just 1 or 2.
/ pole barn insulation #20
I have come up with a unique way of insulating pole barns that you never seem to see many people do but it works very well. I purchase 1 1/2 in thick cheap white foam sheeting. I cut it to fit in between the sheet girts and wedge it in then I cover it with 7/16 OSB or Drywall or whatever you want. Gives you about R7 and works very well against radiant heat from the sun. Seals up nice so you don't have as much of a problem dealing with critters getting behind your false walls. Some people get all freaked out because it's only R 7 instead of R13 but then they have huge doors with only an inch of insulation in it. This method works well because most of your heat loss will be through openings around the door or out the ceiling anyways and this provides a very good thermal barrier against the hot sun and prevents many moisture related issues. You could always come back and add false walls after-the-fact if you find you need even more insulation but doubt you will.
2014 Crossroads RV Elevation T/A 5th Wheel Toy Hauler Travel Trailer (A64557)
2014 Crossroads RV...
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
2011 UE Manufacturing Armada 1000HP Single Pump Tri Axle Frac Blender Trailer (A64194)
2011 UE...
HAY KING PASTURE AERATOR (A64278)
HAY KING PASTURE...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
HONDA generator (A64553)
HONDA generator...
