Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #2,121
Ken,
Do you find the Ford cuts better or the Motts? I been looking at Motts/Alamo and some Fords recently and was wondering which you would recommend and why? Is the Ford difficult to find parts for? Any advantage of one over the other? Thanks
/ Let's talk flail mowers #2,122
Is your current tractor bogging down? If not it won't make a bit of difference me thinks.
Lol, yes and no. I know it seems like an easy question. I'm not sure if it come from eating to much grass or the tractor not having the power to cut it.
My average speed for 3' grass is 1 mph when thick. When it's just tall weeds I run about 2mph ... It's only 1mph more but if I could cruise at that or even 2.5 Id be happy.
All the blades are essentials dull too. I spent over 3 hours sharpening 1 row the other night. Unbolting each one individually then sharpen and reattach made for a slow evening. 184 blades total and I only got %25 percent done.
/ Let's talk flail mowers #2,123
Ken, Do you find the Ford cuts better or the Motts? I been looking at Motts/Alamo and some Fords recently and was wondering which you would recommend and why? Is the Ford difficult to find parts for? Any advantage of one over the other? Thanks
The mott with dull blades cuts better than the ford with new blades.
From flail master, a new set of 33 blades for the ford was $150
A new set of blades from flail master for the mott was about the same price. (Different kid if blade). There are 184 blades on the Mott.
Each set of blades (2 per set) are bolted on individually on the Mott... Loooong process.
I had new blades completely installed on the ford in about 15-30 minutes (hard to say exactly as I was also distracted by other things). But it went very fast and that was the first time doing it.
Since I burned my belt I've still not made it a priority to get a new one. Although I should. The ford seems heaver built and may take more PTO power to turn.
I should have a hydro top link coming soon as this does make a difference in cutting.
I was able to use the ford and make a few passed to literally scalp the ground, then rototill into a food plot.
The thing I don't like about the ford is the belt is not on a spring tension pully. Apparently that came after my model. Although I now have several hours using both its still hard to decide which I like better.
More tests will be to follow. I can say for grass, the Mott cuts better. The Mott seems daintier but is a good machine and actually seems to be my "go to" piece.
So now that my ramble is clear as mud I hope to add more opinions in the future of my findings.
/ Let's talk flail mowers #2,124
Maybe this might help after reading your question.
It depends on what your cutting and how often.
If it was for my house, only cutting a field a few times a year and time permitted. Cutting thinner grass and light weeds. I think I'd pick the Mott everyday first.
/ Let's talk flail mowers #2,125
Thanks Ken - I am looking to cut grass, weeds and some smaller brush (decided I will clean the area out good with the brush hog so nothing will be over 1" except an occasional branch - mowing atvs trails in the woods and along the wooded edges of my lawn)
I been eyeing the "rough cut" rotors and liked the idea that the Motts/Alamos are used by road crews. Figure if they live long lives doing that I should be set for life! The Fords are more plentiful around my area and I just didn't know much about them. Been staying away from the new lighter duty machines as I know I will be in the woods with it and like a heavier unit for long term use.
I appreciate any idea, thoughts and feedback you have
/ Let's talk flail mowers #2,126
In my limited experience it has to be on the ground to creat a suction for it to cut right. I played around with all different heights before I figured that out. LOL I dont think 8" high would be good for the flail but then again I could be completely wrong about the suction theory. 😳
/ Let's talk flail mowers #2,127
In my limited experience it has to be on the ground to creat a suction for it to cut right. I played around with all different heights before I figured that out. LOL I dont think 8" high would be good for the flail but then again I could be completely wrong about the suction theory. ��
hello esbwn,
If I have not done it already I want to welcome you as the newest member
of the "Flail Mower Nations"(no passport required).
No, you are not wrong esbwn. The correct term is "pressure gradient".
If the mower shroud is not close to the ground the ground underneath the
flail mower does not create the restriction required to create the pressure
gradient needed in front of the flail mower rotor to create the lift needed
to carry the clippings up and over the flail mower rotor and back to the ground.
Always think of it this way; if your upright vacuum cleaner with the carpet beater brushes
is held above the carpet while trying to clean it the vacuum cleaner will be sucking only
air and very little dirt except for the occasional dust bunny that wants to sacrifice its self.
/ Let's talk flail mowers #2,128
I have no idea where you're getting this theory, but I'd be willing to bet a scientific analysis would disprove it....and the vacuum analogy doesn't work either.
Even with the mower shroud touching the ground there are far too many areas that are wide open (the entire front of the mower) for there to be any significant suction caused by the spinning rotor and blades. There is air movement, but it's not suction caused by a seal with the ground. Further, as you describe, the clippings are already cut if they go up and over the rotor...suction won't change anything...they're already cut.
A vacuum uses a suction motor to suck up what the rotor brushes lift off the ground....a flail doesn't work that way.
A flail needs to be near the ground for the best cut because of mechanical factors. The front of the flail (usually the metal or rubber guard) hits the grass/brush and pushes it forward (assuming it's long enough) and the blades then cut it. If the flail is up high (8" example) the grass and brush will be more flexible and it's going to move around before it gets cut. It's possible that in some situations it will bend enough that the blades miss some pieces entirely.
In short, if the mower is down low, the brush gets pinned in place better before it's cut which is going to give the most consistent cut. I've been watching my flail as I cut a lot...since it's new, and if you watch what happens to the brush as it goes under the mower, the tops are moving all over the place as they get run over. The bottom can't move because it's in the ground. Cutting closer to the fixed part is when you get a nice cut, but it's simply a matter of mechanics, not suction.
Regardless of all of that, if you drive through a field that has 36" tall weeds, and you set the mower at 8" above the ground, it's still going to cut the weeds...just not as smooth of a finish.
/ Let's talk flail mowers #2,129
Leon is correct, as always, with regard to the need for ground contact to establish the pressure gradient needed for optimal mowing/mulching efficiency.
Another characteristic of flail mowers that might not be obvious to those more familiar with rotary mowers is that flails don't cut well when backing up. I often back into thick brush but have learned to always drive out the same way to finish cutting. The flail does cut in reverse but not nearly as cleanly as when moving forward.
/ Let's talk flail mowers #2,130
You can't have a significant pressure gradient without a seal...and there is no seal. Only the sides of the mower touch the ground with actual contact. The roller touches, but has gaps above it, and on the ends. The front is open...chains, metal bars and rubber shrouds don't create a seal and often aren't in contact with the ground.
Until somebody shows an actual reference, I'm sticking to reality...the closer to the ground the grass/brush makes contact with the mower, the less it will move around, and the better the cut will be.
I don't know why anybody would even worry about the theory...if the ground is full of rocks, and you don't want to trash your blades, lifting the flail high enough to clear them will still let you cut that brush. Will it be perfect? No. Will it get cut down? Yes. That's all the guy asked....will the mower worked raised up a bit. Yes, it will still work.
/ Let's talk flail mowers #2,131
You can't have a significant pressure gradient without a seal...and there is no seal. Only the sides of the mower touch the ground with actual contact. The roller touches, but has gaps above it, and on the ends. The front is open...chains, metal bars and rubber shrouds don't create a seal and often aren't in contact with the ground. Until somebody shows an actual reference, I'm sticking to reality...the closer to the ground the grass/brush makes contact with the mower, the less it will move around, and the better the cut will be. I don't know why anybody would even worry about the theory...if the ground is full of rocks, and you don't want to trash your blades, lifting the flail high enough to clear them will still let you cut that brush. Will it be perfect? No. Will it get cut down? Yes. That's all the guy asked....will the mower worked raised up a bit. Yes, it will still work.
There is a pressure gradient between the front and rear of any fan and most have no seal. Wind or air movement is all about pressure gradients and doesn't require seals per se.
Rotary mowers create pressure gradients that allow clippings to be forced into a shoot and collected. A flail does generate a "pressure gradient" to create a vortex that causes cuttings to be recut or mulched. Trapping the cuttings under the mower allows them to be recut more efficiently just as with a rotary cutter with the grass shoot blocked. With the flail mower elevated, there is enough escape of air and cuttings to diminish the recutting which lowers the quality of the cut. It will still cut but it will not recut as efficiently.
/ Let's talk flail mowers #2,132
That would be true if you were talking a traditional fan with blades shaped like aerofoils intended to create low pressure on one side, and high pressure on the other. That simply isn't how a flail works because the blades are parallel with the direction of movement, not nearly perpendicular to it like a desk fan.
A flail will generate some rotational air movement, but narrow, sharp blades that have virtually zero angle of incidence (and angle of attack, but that would be carrying it a bit far) aren't going to create any significant pressure as they pass through the air. That's why horizontal rotary mowers have part of the blade angled offset from the direction of rotation (angle of incidence) to create a pressure differential pulling the grass towards the blades.
Imagine a flail mower mounted to a boat that happens to have a 540 PTO drive. You can set the flail right on the top of the water, and start it turning...some water will go around the rotor, but the boat isn't going to move a whole lot because it simply can't generate a significant amount of pressure.
The quality of the cut, and the quality of the mulching are two entirely different things. Clippings being cut a second time doesn't change the quality of the cut, it changes the quality of the mulching, and what you see left lying around. You have a blade of grass....a blade cuts it, and the standing part doesn't get cut again in most cases....that sets the quality of the cut and how level and even it looks. It's a pretty safe bet the a significant portion of the mulching capability of a flail happens because the clippings wind up on top of the already cut grass, leaving them where the blades can make contact with them again....and watching the big clumps that get left behind says that has to be true. Whether there's enough suction to draw clippings up into the blades is another question, and I'd love to see references on it, but I doubt they exist.
/ Let's talk flail mowers #2,133
Agree that data is needed to understand this issue. "In God we trust, all others must show data".
While flails don't have angled blades, they do still create considerable "wind" simply because they are moving at ?1000-3000 feet per min and even if the blades themselves are relatively aerodynamic, the mounting points, clevises and bolts are not so would generate "wind" which is contained under the mower. Presumably that air flow dissipates more rapidly when the mower is lifted.
/ Let's talk flail mowers #2,134
Hi,
I am currently using a rotary mower and a side disc mower to mow road ditches and waterways. I get all I can with the rear mower then switch to the disc mower to reach up the ditches in the steep parts. I have been looking for something that would mow behind the tractor like the rotary but also extend out and reach up and down the steep areas so I don't have to keep switching mowers. I found this and it looks like it would work for me. Anyone have any experience with this?
Diamond rear swing flail
Rear Swing Flail Mowers – Diamond Mowers
/ Let's talk flail mowers #2,135
Hi,
/ Let's talk flail mowers #2,136
Hi,
Looks like the answer to a lot of questions.. cheap too I bet!:D
/ Let's talk flail mowers #2,137
Please contact your local diamond implement dealer for a customer list as that is the
fastest way to find an owner of this mounted implement.
The Diamond folks have been building mowers for a long time.
You will have to decide if you want an integral mounted flail mower
or a boom mounted mower first.
Saying that the majority of these units are owned by municipalities to
mow ditch banks on roadways the flat areas the mules can access safely.
Many users have loaded tires and or wheel weights on the outboard(roadside)
portion of the tractor to maintain its stability when mowing so keep that in mind.
You will find that a boom mounted flail mower with hydraulic drive will
cost you more money about the same money, but you will have to compare
the price between the two types of flail mowers before you can make a decision.
This type of flail mower depends on the tractors hydraulic system to operate the
mower mounting frame side shifting cylinder and the tilt cylinder frame to position
the flail mower for work while the Rear Power take Off operates the mower through
the drive shaft to the right angle gearbox and then to belt final drive for the flail mower.
I believe the parent company is located in England.
I want you to succeed not fail.
/ Let's talk flail mowers #2,138
I cannot attach pair of crude hand made drawings illustrating the differences in knive hangers as they are too big using picasa GRRRR!!!!!!
I will gladly send the files to anyone who would like the drawings to show the difference in knife mounts.
The Mathews lawn genie knife hangers allow a slotted mount knife to become airborne as they provide the knife the range of motion to move sideways and become an airfoil due to the tapered knife edge.
The 45 degree angle of the stamped and rolled knife aids in its aerodynamic lift at the high speed of rotation required for mowing
Sadly these knife types are no longer being stamped(I am working on that and an additional aid for flail mower owners
with the current mounting station types.
/ Let's talk flail mowers #2,139
Blade Breaker, you might also check Betstco and their AGL line of flail mowers. They advertise on ebay and are listed under flail if want to look at their models. Perhaps they have been discussed in this thread at some point or someone could comment on their quality, I can't. The AGL models are pto driven and require two circuits to adjust the shift and bank angles. Might be what you are looking for.
/ Let's talk flail mowers #2,140
hello esbwn,
Thanks leonz! You have already welcomed me but ill take the welcome again! Thanks for pointing me toward Flail Master for blades, pins, ect. Kristi was really easy to work with and even helped me buy a few extra knives instead of paying for shipping! *Shipping was free over a certain dollar amount so why not get a few more blades?*
After my son and I replaced 152 blades it cuts like a dream! Super glad to have one. I will need to replace a bearing at some point in the future, I dont know which one is starting to squeak but every once in a while I hear it. If anyone has replace bearings and put up a step by step instruction and would point me toward it I would be very grateful! It never ceases to amaze me the amount of knowledge on this forum!
2014 FREIGHTLINER M2 4X2 S/A CNG FLATBED WITH CRANE TRUCK (A66091)
2014 FREIGHTLINER...
GENERAC MOBILE  MTL65 LIGHT PLANT (INOPERABLE) (A68842)
GENERAC MOBILE...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
VOLVO L330C GP Bucket (A68134)
VOLVO L330C GP...
1998 CATERPILLAR D5M XL HIGH TRACK CRAWLER DOZER (A65056)
1998 CATERPILLAR...
1980 Great Dane 102'x48' Lowboy (A64912)
1980 Great Dane...
