Grease Guns
/ Grease Guns #31
Loosen the jaws of the nozzle. Perhaps putting it on a little loose and applying pressure to keep it tight.
/ Grease Guns #32
Several things on my mind. First I HATE that black grease. It's hard to get it off your hands. Is it any better though? There are so many kinds of grease, I even bought this super expensive Food Grade grease that I used for a project up at the pond. If I guess that greasing with almost any grease is a million times better then no grease, would I be right?
I saw a nice grease nozzle at an auto parts store (not expensive) and replaced the one on my cheap electric gun I bought at TSC. It just seemed to hold on the zerks nicely. A neighbour of mine came over with his MF 265, maybe with a leon loader. He was having trouble greasing the loader. I believe it's the top of the bucket cylinders but the zerks are in a cage of sorts with just enough of a round hole to get the grease nozzle into. Greasing was easy, getting the **** thing off was nearly impossible! That nozzle, or maybe any that lock on, seem to require moving the nozzle off to an angle to get them off, but in this case you couldn't. I undid the nozzle to relieve pressure, but this was of no help. Eventually I just rigged up a pry bar and pulled like crazy on the hose, being left with little other options and it came off. Anyone have any tips on this?
If the slightly larger lockNlube nozzle will fit in the holes and they are not too deep, then the lockNLube is what you want.. No pulling, no breaking zerks NO curse words.
Amazon.com: LockNLube Grease Gun Coupler - Zerk Grease Coupler Fitting Tip - Easy Lock-on, Clip-off - Stays on - Grease goes in, not on the machine - FREE Shipping & 30 day money back trial plus $3 for return shipping.!: Automotive
/ Grease Guns #33
all the grease guns I have you can adjust the end by turning it so it isn't to hard to get off some Zerks.
/ Grease Guns #34
What do you mean by ineffective?
Grease comes out when the lever moves, to me that is effective.
It is rated at 10,000 psi. If there is a stubborn zerk, I lock the hose on, hold the gun with the hose pointed down, put the gun against my chest, put both hands on the extended lever and pull as hard as I can. So far the grease always goes in.
My 18v Lincoln is rated at 7,500 psi, for comparison.
Ineffective as in comparison to a pistol gun or powered gun. If you are happy using it, I am happy for you. To me, it's ineffective.
/ Grease Guns #35
Yep. Sometimes with use they'll get out of adjustment but a quick turn with your fingers and everything is good again.
I bought one of the lock n lube ends. I pumped a couple tubes of grease thru it and took it off. Too bulky. Too slow. A properly adjusted normal end works better for me. I am a grease freak and use a LOT of grease in a year.
/ Grease Guns #36
So on this whole grease gun thing, I hate my manual pump version and have been looking at a Milwaulkee (I have a bunch of battery milwalukee so). Question I have for the group is maybe I am just friggin messy but how do these tools take to all the grease? I mean the battery must just be a sticky mess after a while? That is my thing as I use the batteries on tools that work wood.
/ Grease Guns #37
I am messier than I like to admit. But I'm also a bit OCD about it. I wipe my gun off after every use. I try to not handle it with greasy hands. For example, I'm left handed. I always run the gun with my right hand and run the hose, zerk coupler with my left. Left hand gets greasy, right hand stays clean. In a perfect World at least.
I don't work wood so don't have your worries. Maybe commit one battery to the grease gun?? If the Milwaukee is anything like the DeWalt it will pump a LOT of grease on one battery charge. I'm guessing 10 tubes or so.
/ Grease Guns #39
I have a bunch of Dewalt Cordless tools, but they are all NiCad. I wanted to try Milwaukee brand tools and also switch to Lithium batteries. To keep the cost down, I bough a refurbished gun through CPO outlets. I have purchased a couple other tools from them, and been very pleased.Paid about $125 and liked it so much, a week later I bought an impact driver to go with it. If you do much greasing, and you know you should, battery operated is so much easier and cleaner. One hand still has to get greasy from the Zerk, but the pump hand stays clean. Is applies good pressure, and is easy to load and doesn't seem to get airlockks like the hand pump did. Plus no hand cramping . I'm wishing I had got this thing 10 years ago.
/ Grease Guns #40
For years I struggled with cheap grease guns with the very same problems. Solution? Go to NAPA auto parts and get the best grease gun they carry. I have had mine now for over 10 years and it still operates great. They are not cheap but worth every dime.
2012 Freightliner Cascadia (A61307)
2012 Freightliner...
2018 Trail King Lowboy (A61307)
2018 Trail King...
(INOP) ELGIN PELICAN SERIES P SWEEPER (A59823)
(INOP) ELGIN...
2015 Ford Explorer AWD SUV (A59231)
2015 Ford Explorer...
2016 Ford Expedition XLT 4WD SUV (A59231)
2016 Ford...
2014 WESTERN STAR 4900 SF (A60736)
2014 WESTERN STAR...
