As the title says, I am a tractor newbie, just bought my first tractor ever. It is a T264 with a loader and cab. I was watching a youtube video of the T264 and the youtuber mentions to "grease every 8 hours". I looked at my owner's manual, and nowhere does it mention anything about greasing every 8 hours. I've just hit 8 hours on my tractor, so I'd like to make sure I am following the recommended maintenance schedule. The only thing the owner's manual says is to "Grease in front wheel hub" at 100 hours and to "Grease each nipple" at every 50 hours. This is where I am getting confused.... I did some googling around and on TYM's site it says this:
Anyway, if someone can point me in the right direction it will be much appreciated, I just want to make sure that I follow the recommended schedule. Also, I do own a grease gun, but have zero clue which grease to get.
Thanks in advance!!
- Grease every eight hours of operation. This is the standard recommendation for most tractors, but some lubrication points have different greasing intervals, so it's important to refer to the manual. Don’t skip greasing intervals, even if your tractor appears to be running fine. By the time you notice a problem, it may be too late to fix it.
- Remove old grease before applying new grease. Because some greases are made of different components and not always compatible with one another, any old grease should be completely removed before switching over to a new grease.
- Keep grease fittings clean. Before you re-grease, make sure to clean off the grease fittings in order to prevent dirt from getting into the bearing. Dirt can become caked on grease fittings and result in equipment failure.
Thanks in advance!!
