Chipper or Shredder for Grapevine Prunings
/ Chipper or Shredder for Grapevine Prunings #1
Riddler
Gold Member
Sonoma County, CA
New Holland TN75VA, New Holland TC45DA, New Holland TC18
I am looking to process/dispose of prunings in place from 20 acres of grapevines. One option is a specialized flail mower/mulcher designed to pulverize prunings while mowing a permanent cover crop between the vine rows. As another possible option, I'd like to experiment with a chipping/shredding option. The prunings aren't large (much less than an 1", for the most part), but the operator needs to be able to pick up multiple prunings from the ground and have the unit process them without much operator assistance (i.e., high degree of self feeding).
Is a good quality shredder the best tool for the job? I am thinking that a handful of prunings dumped into a large opening, horizontal shredding chute will get processed on its own while the operator is grabbing another handful of material for processing. If so, then I was thinking about trying out the Wallenstein BXM42 (PTO drive) or the BXMT4224-38 (Various gas drive options).
On the other hand, would a dedicated chipper, like a Wallenstien BX42 or BX42R, work just as well (or perhaps better)? In other words, is there any disadvantage to using a dedicated chipper to process a large volume of relatively small diameter dormant grapevine shoots?
Thanks in advance for any experience or advice you have to offer.
/ Chipper or Shredder for Grapevine Prunings #2
I don't know the answer but I'll bet Robert in NY does. He grows grapes in New York State and is familiar with grape clippings. If he doesn't find this thread, look him up. :)
/ Chipper or Shredder for Grapevine Prunings #3
I have a Wallenstein BX42s chipper. I chip a lot of wild grape vines pulled from trees. The BX42s is fine for 3/4+" vines. Running a 30' section of 3" vine through, which self-feeds, is fun!
BX42s tends to plug with thinner cuttings, like green, flexible, annual pruning material, which does not have enough mass/inertia/resistance for the knives to cut and therefore wrap around the rotor trunnions and load the rotor chamber before plugging the chute. Chipper (only) is not the tool for you.
For processing annual pruning waste get a Wallenstein BXM42 CHIPPER/SHREDDER.
Pictures show the Wallenstein mounted on my Kubota B3300SU (25 PTO horsepower) which had enough power to run the BX42s chipper satisfactorily.
LINK TO WALLENSTEIN WEB SITE: Wallenstein BXM Series PTO Wood Chipper / Shredder Specs - Wallenstein Outdoor Power Equipment Made in Canada
/ Chipper or Shredder for Grapevine Prunings #4
I would think the flail mower would be a LOT more effective for a business. I had a lot of wild grapevines to chip when I got my Jinma. I agree it's nice to see a long line of clippings go thru the chipper BUT it takes a lot more time than running them over with a mower.
If you could rake them up then pick them up with a grapple and dump them into a chute to feed the chipper/shredder it might work
/ Chipper or Shredder for Grapevine Prunings #5
Chippers are great for thick material, say 1" or more. For thinner, twiggier stuff, they are fairly lousy. I have a Wallenstein BX-42, and it's been great, but I know not to try and feed twiggy material through unless it's attached to something thicker so it can properly feed. For what you describe, a chipper/shredder would be the best choice. I bet the BXM-42 would be great.
/ Chipper or Shredder for Grapevine Prunings #6
I have a BX-42. Trying to chip small twiggy stuff is frustrating and labor intensive.
/ Chipper or Shredder for Grapevine Prunings #7
I have alot of wild grape vines i chip on my hydraulic feed salsco little big it doesnt matter its all clinged togeather it all gets suck in its fun and easy
/ Chipper or Shredder for Grapevine Prunings #8
As I read your post again, loading all that small stuff into a chipper, even a self-feed one seems like it would be enormously labor intensive.
Good thoughts all.
I had a hunch that a chipper/shredder, like the BXM, was the way to go. I have 20 acres of woodland to care for too, so while eliminating the prunings from the vineyard is a big priority, I have need for a chipper as well. Seems like everyone is happy with their BXM-42, but does someone have experience with a more powerful chipper/shredder (gas powered or PTO drive) that they can recommend?
Not hard to imagine that a flail mower/shredder would be much faster. Never seen one in action on prunings, so I don't know how effective they are at collecting the prunings that have been laying on the ground for a few weeks and grinding them throughly. As compared to chippers, which are easy to rent, finding a properly set up flail mower shredder of precisely the right width (needs to have a total width of 60"-64) to rent is impossible. Would like to try it out before committing to purchase one.
Of course, a sure solution to my problem is to have both. It only money, right?
/ Chipper or Shredder for Grapevine Prunings #11
I have a wine grape vineyard in Oregon. I can't imagine how difficult it would be to have to transport all the clippings out of the rows to a chipper, not to mention trying to get the tangled cluster of vines to go into the hopper. I think it would take a much larger machine to grind the cuttings,I have seen construction companies use huge trailer mounted bowl type grinders that can do a loader full of wood mass easily. Maybe hire one of them for a trial run.
I prefer to flail mine into the cover crop between rows, fast,cheap, and eventually improves the soil on the vy floor.
/ Chipper or Shredder for Grapevine Prunings #12
My cousin grows 140 acres of grapes and this is how he said he does it.
We did vine prunings for years with a 6 foot Bush Hog, but it didn't do the big trunks that get lopped off- it would just throw them to the side or maybe break them in half. Now we use the (brand name) Perfect chopper, which is a flail mower. It does a beautiful job and pulverizes everything in its path. We also have a brush rake which rakes brush from under the trellis to the chopping zone between the rows.
Hope this helps.
Well, I rented a Bearcat 8720 chipper and spent the better part of a day with help gathering prunings and feeding them to the chipper. While the chipper had no problem processing as much material as you could feed it, as rgr surmised, the main limitation was how bulky the material got when you gathered it together. The self-feed on the machine did a great job pulling in the tangled material, but accumulating and organizing it for feeding required quite a bit of effort.
Thanks to both rgr and sixdogs for input on the flail shredder approach. It certainly looked like the way to go, but I needed some reassurance that it does a good job. As luck would have it, I may have found a source that will rent me the right sized machine so I can test it out. If it pulverizes the material well, then I can go ahead a buy a machine with some confidence. The good machines aren't cheap, so I want to make sure.
I will still buy a chipper or chipper/shredder before too long. I have many uses for a machine like the Bearcat 8720, even if it's not to eliminate prunings.
Sixdogs, I just left you a PM about connecting further with your cousin. Thanks, jr
/ Chipper or Shredder for Grapevine Prunings #15
Interesting "Dump Cart" you have there. Looks like it has built in seats too! What brand model is that?
/ Chipper or Shredder for Grapevine Prunings #16
It is an older, single axle MULTI USE TRAILER SYSTEM (MUTS) all terrain trailer from Canada. The 'seats' place the trailer load low, on the plane of the axle, so it will go anywhere your utility vehicle or tractor can go.
MUTS dumps with a mast and boat trailer winch, which is a real labor saver.
MUTS - Multi-Use Trailer System for your ATV, Quad and 4 Wheeler - Welcome
/ Chipper or Shredder for Grapevine Prunings #17
Riddler - For our 5 acre vyd I use a flail(Ferri) with hammers to mulch cuttings. This is the most efficient method used by orchards and vineyards. The orchards use heavier duty choppers from Rears, Perfect W, and others make. Some vineyards take their cuttings out of the vineyard by trailer or I've seen an Ontario grower use a bailer to bind up their cuttings on each row. On occasion a small vineyard will use a pulled fire pit to burn cuttings as they prune.
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
UNKNOWN  SPOOL TRAILER (A58216)
UNKNOWN SPOOL...
Husqarvana Riding Mower (A56857)
Husqarvana Riding...
LIMA MAC 60KW GENERATOR (A58214)
LIMA MAC 60KW...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2021 Kubota RTV1140 4x4 Diesel Utility Cart (A59228)
2021 Kubota...
