Snow Attachments Snowblowers vs PTO HP
/ Snowblowers vs PTO HP #1
Toddao
Gold Member
jeffersonville VT
GC2410TLB
Who is running the largest blower with the least amount of PTO. HP??
Sent from my iPad using TractorByNet
/ Snowblowers vs PTO HP #3
I ran a 60 inch on my 1700 Ford. It was 28 engine hp.
/ Snowblowers vs PTO HP #6
Haven't tried it yet but my 19 pto hp 2650 has a 63 inch blower . Others have and they report good results . With hst you just go with the conditions . I have 7 ft. on the back of my 5700 and that has about 50 pto hp and in heavy snow I have to use creeper gears with that .
/ Snowblowers vs PTO HP #7
Seems silly to have low pto hp with something that gobbles up power like a snowblower.
/ Snowblowers vs PTO HP #8
60" blower with 19-20-ish hp on my 1510. Seems silly to have a snow blower narrower than the tractor. :cool:
Joe
/ Snowblowers vs PTO HP #9
Life is a series of compromises. :D
35 pto HP with 74" blower. Deep, dense drifted snow can work it very hard. Once in a while I have to put the clutch in (gear tractor) even in 1st gear out of 12.
/ Snowblowers vs PTO HP #10
AMEN! I also have to push down on the clutch in the deep, heavy stuff in 1R (out of 4). 98% of the time. it's just fine, and it operates in places I'd never dream of taking a larger tractor.
Joe
/ Snowblowers vs PTO HP #11
I am not saying they do not work. Just the snowblowers I have used always seemed underpowered. Maybe they are too much for garden tractors.
/ Snowblowers vs PTO HP #12
74 inch, 30 at the PTO. I have had good luck with it not bogging down.
/ Snowblowers vs PTO HP #13
I'm also using a 74" blower and 30 PTO HP. As long as I clear the snow son after it stops, no problems. I will have to use the clutch in frozen snow or high piles (such as you get at the end of the driveway after the county truck plows through). I've gone through drifts that were 4' deep, but it's real slow going.
/ Snowblowers vs PTO HP #14
I didn't think you were. :) Just say'n most of us have to work with what we have.
If blowing 2' deep snow by 6' wide by the diameter of the auger, think how heavy that would be to shovel by hand, the strength required to throw it, and how much weight is involved if it is dense snow. blowing snow is by far the hardest my tractor ever works.
It would be interesting to see a head to head comparison rating of blower brands that compares their efficiency (most done with equal power or something like that).
/ Snowblowers vs PTO HP #16
Adding a bit to Dave's response...lawn and garden tractors are normally powered by single or twin cylinder air-cooled gas engines...not much torque as most CUTs which, of course, are normally diesel. Nor do lawn and garden tractors have the low gearing. So, I'd reckon many lawn and garden tractors are underpowered for snow blowing...especially if there's significant accumulation (anything more then 6")....worse if it's a wet snow.
Just stating my opinion here...I've had lawn and garden tractors, but never used one with a snow blower.
/ Snowblowers vs PTO HP #17
60" with 22 HP @ the PTO ...
/ Snowblowers vs PTO HP #18
Running a 64 inch with 21 HP @ the PTO......hoping for lots and lots of snow to feed it this season too!
/ Snowblowers vs PTO HP #19
I run a 74" blower with 22 HP at the PTO. The HST makes all the difference in heavy banks rolled up by the city plow.
/ Snowblowers vs PTO HP #20
This is a 5 foot Lorenz on a TC33D in heavy drifts and I wished I had at least 10 more HP.
2018 CATERPILLAR 326FL EXCAVATOR (A65053)
2018 CATERPILLAR...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A59914)
2020 KENWORTH T680...
New Carbon Steel 4.75-12T Shackles, 38 Total (A62679)
New Carbon Steel...
2018 CATERPILLAR 573D FELLER BUNCHER (A62129)
2018 CATERPILLAR...
(2) 4 WAY WRENCHES (A64276)
(2) 4 WAY WRENCHES...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A61573)
2007 Western Star...
