Wiring subpanel
/ Wiring subpanel #61
That explains it, we're on the 2008 version of the code so I guess the answer depends on which version the OP's authority is using.
Thanks for clarifying that, Aaron. I was beginning to think I was going crazy.
/ Wiring subpanel #62
I absolutely agree that the code should be followed and if what you're saying is correct, I've misread code. I understand NEC to call for an isolated ground and have installed it as I described more than once with the advice and supervision of a licensed electrician and it always passed inspection...
After seeing Aczlan's post about the revision, and your post about it passing inspection, I guess the revision took place after your installations.
Sorry if I was too blunt. Just trying to be emphatic.
Edit: I was still typing when you posted, STx.
/ Wiring subpanel #63
No worries about bluntness, my skin is much thicker than that, especially on the Internet... lol
I'm just glad someone was able to clear up the confusion.
/ Wiring subpanel #64
/ Wiring subpanel #66
Soo all of Texas is stuck in 2008 ?????
/ Wiring subpanel #67
Couldn't tell you about all of Tx, every county or city can adopt their own codes. The City of Houston is actually enforcing NEC 2006 and has begun the process of thinking about adopting NEC 2012. Change is slow in larger municipalities.
At my place in South Texas, there is no permitting or code enforcement so you can do whatever you want to. If your house burns down because of improper wiring, they figure it's on you.
2017 Nissan Altima Sedan (A64557)
2017 Nissan Altima...
2019 AUTOCAR XPEDITOR TRASH COMPACTOR TRUCK (A63276)
2019 AUTOCAR...
2013 JCB 506-36 TELESCOPIC FORLKLIFT (A65053)
2013 JCB 506-36...
2025 10,000lbs. Two Post Auto Lift (A64194)
2025 10,000lbs...
JOHN DEERE 467 ROUND BALER (A64278)
JOHN DEERE 467...
Heavy Duty Booster Cables (A64557)
Heavy Duty Booster...
