Wiring subpanel
/ Wiring subpanel #61
That explains it, we're on the 2008 version of the code so I guess the answer depends on which version the OP's authority is using.
Thanks for clarifying that, Aaron. I was beginning to think I was going crazy.
/ Wiring subpanel #62
I absolutely agree that the code should be followed and if what you're saying is correct, I've misread code. I understand NEC to call for an isolated ground and have installed it as I described more than once with the advice and supervision of a licensed electrician and it always passed inspection...
After seeing Aczlan's post about the revision, and your post about it passing inspection, I guess the revision took place after your installations.
Sorry if I was too blunt. Just trying to be emphatic.
Edit: I was still typing when you posted, STx.
/ Wiring subpanel #63
No worries about bluntness, my skin is much thicker than that, especially on the Internet... lol
I'm just glad someone was able to clear up the confusion.
/ Wiring subpanel #64
/ Wiring subpanel #66
Soo all of Texas is stuck in 2008 ?????
/ Wiring subpanel #67
Couldn't tell you about all of Tx, every county or city can adopt their own codes. The City of Houston is actually enforcing NEC 2006 and has begun the process of thinking about adopting NEC 2012. Change is slow in larger municipalities.
At my place in South Texas, there is no permitting or code enforcement so you can do whatever you want to. If your house burns down because of improper wiring, they figure it's on you.
1991 Polar MC 312 General T/A Chemical Tanker Trailer (A64194)
1991 Polar MC 312...
2022 Mack Pinnacle T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
2154262019 FAE UMLV SSL- 150VT HYD MULCHING HEAD (A65053)
2154262019 FAE...
2008 KOMATSU PC78MR-6 EXCAVATOR (A65053)
2008 KOMATSU...
2013 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2013 Caterpillar...
