120-Volt Mig welder.
Status
Not open for further replies.
/ 120-Volt Mig welder. #161
Watertight is no problem, it's a pretty quick pulse, about as quick as you can work that trigger finger. I have never quantified it but guessing from memory it's about 2/3 on, 1/3 off.
Why watertight, does it hold liquid? Or just to exclude water so it doesn't leak rust stains or fill with ice? You can do that with paint if the weld is decent.
This pic is 1" x 1" x .065" (=16ga) pulsed with .030 wire. You can make it a little tighter with .023 wire. I think you'll pick it up pretty fast.
388174d1409263300-120-volt-mig-welder-2inchmctow4_8358-jpg
Yeah it is more of it not collecting water inside and making a rust mess or filling up and freezing. But I also wanted to make a tool box for my tractor that is pretty much watertight. So... it is a skill I am trying to learn with sheet metal and tubing. I hate when I pick up something that has been sitting outside and I turn it and rust colored water pours out on my shoe. Just don't like water traps!
Using the exact tubing you mentioned, building a greenhouse bench, I was occasionally getting blow out with .030 wire. And dang it, I just got back from HD and forgot the .023 wire!!! :mur:
/ 120-Volt Mig welder. #162
I wouldn't worry too much about the wire, last week I was running .035" on 18 and 16 gauge tubing.
I welded it with straight weld, used a slight weave to keep a little more heat on the side of the tube instead of the cut ends.
The thinner the metal, the more important the fit-up is.
/ 120-Volt Mig welder. #163
Now I have a cheap HF flux core wire feed unit that does the job. A good brand of .030 wire seems to work quite well for stitch welding, the HF stuff is crappy. The last couple months I've ran 6 or 8 spools through that machine just for body work, some were 2 pound spools. .... I really should have bought one of these machines sooner.
Would I like a dual voltage MIG? Of course but this thing does the job I'm asking it to and the portability is priceless.
Which model HF welder? I'm impressed, if you can do good body work with their 90A AC welder.
And which brand of flux wire?
/ 120-Volt Mig welder. #164
[When doing flat butt welds I was taught to watch the keyhole. That goes for any process. The keyhole ensures full penetration if you do not see the keyhole chances are your not welding hot enough. Welding down hill will give you a flatter bead profile and up hill will be hotter and a taller bead.
I like the way my professor states that nobody he has ever seen, has ever made a perfect weld because nobody is perfect. If you get a 95 on a weld in his class you have made a darn good weld. I have been able to pat myself on the back a few times.20140809_160137.jpg I received a 90% on this weld, Root pass was 119 amps hot and cover were 145 IRRC. Tough grade yes but far from perfect. 3/16" base metal by the way.
/ 120-Volt Mig welder. #165
Thanks Dave! Yes this is pretty much what I learned from the gang here and trial and error. I was really curious though if the .023 would be more forgiving but on the other hand I am not thrilled (too lazy I guess) to have swap out the spool. ;)
/ 120-Volt Mig welder. #166
I think .023" is a little more forgiving - I had a fresh spool of .030" in the drawer, but was too lazy to change the roll for 3 hours of welding :laughing:
Yesterday I had some 1/4" so it was all good :)
/ 120-Volt Mig welder. #167
I don't know about good body work but it is strong and looks decent. It is the 90amp unit.
I redid the rockers on my daughters 92 Civic, you can't kill that car mechanically. Also the wheel wells on my mothers 96 Civic. The most recent job was repairing the rear corner of my nieces 99 Camry that was hit and ripped out. None are perfect but for what the cars are I think they came out pretty good.
My 18 y/o son used it to patch a rust hole in the bottom of the cab of his Ranger. With some direction, he cut out a 3 x 8 piece to get beyond the rust and welded in a new piece of metal. Unless you looked closely you may never find it. The grinder is our friend.
As for wire, the big box store Lincoln stuff works decent but I also like the INE INETUB wire I get off Amazon. 2 pounds on a spool for a couple bucks more than the Lincoln 1 lb spool.
At some point I'll upgrade the HF junker but it gets by for now. One of the small Everlast units would be nice.
/ 120-Volt Mig welder. #168
Sodo... thanks for the pulse idea. Played with that tonight and I am happy with the results. Used the 'inside the cover' settings and the pulse seemed much more forgiving than continuous on 16 gauge. Here are a few pics. Even with the pulsing, the second pic seems to suggest that I still got decent penetration. The third pic was pulsing a flat butt weld.
/ 120-Volt Mig welder. #169
Dragon, the name I've heard weldors refer to that trick is "trigger welding" - like a lotta stuff, there're probably a dozen other common names depending on geography. If you wanna spend enough, the machine can do it for you.... Steve
/ 120-Volt Mig welder. #170
Hey Steve... yeah had a lot of fun tonight triggering it. :D While I tend to purchase quality/capability beyond what I truly need... I have never regretted that. But that said... I think I can manually pull the trigger. :laughing:
/ 120-Volt Mig welder. #171
I'm no expert, but it looks to me like your trigger pulseing has allowed a lot of contaminates into your weld. Looking at every overlap, you can easily see little pools of silica. To me this suggest porosity. Pretty beads and penetration dont mean squat if the weld is full of worm holes. I would like to see that weld sliced down the middle with a bandsaw just to see if it is indeed full of hole, and it might not be, but then again it might be also. I think instead of pulsing the trigger, you pick up the travel speed.
/ 120-Volt Mig welder. #172
Silica shows up even without pulsing. But when youse pulse, it shows up at every ripple.
/ 120-Volt Mig welder. #173
Using the machine at full power shortens the duty factor to a few minute per hour. The 120V maxhine's welds are ok for welding sheet metal and lawn mower decks.
If investing in a Mig I would go with something that can weld thicker metal without smoking the welder's innards .
It's not a daunting task to run a 50amp 240V welder receptacle from the power panel. Plus when at it a 30amp circuit for the air compressor .
/ 120-Volt Mig welder. #174
At our country place I put 220 circuits in the shop for welder, compressor, and heater. The panel is on the wall. At our place in town the detached garage is fed by a 110 circuit, two wires in conduit that (from the panel) goes down under the house, 90 degree through the foundation, under a garden, under a sidewalk, 90 degree up the wall, 90 degree into the attic. Total run from panel to where wire is accessible, about 80 ft. The first was easy, the second is possible but a ton of work and I doubt I will ever get to it.
/ 120-Volt Mig welder. #175
Try to weld through the corners without stopping. A continuous weld bead will help make it water tight and will strengthen the corner. That corner among other things is weakened by the method of the start and stop. If you can't do a continuous weld through the corner; then tie the beads in together and it will work better for you.
/ 120-Volt Mig welder. #176
I'm also in favor of continuous beads vs tack-tack-tack.
Although I do use that method on occasion for rusty sheet metal repair and thin auto-body type repair.
Excellent fit-ups will largely eliminate the need for tack-tack method.
But if not, I'd recommend back-stepping short 1" beads or so. That way it ties into the prior bead quite nicely.
(ignore the run-on and run-off tabs in the photo since your are welding tubing)
/ 120-Volt Mig welder. #177
I think it was said that he wants the weld to be leakproof. Starting and stopping isnt the best way to achieve a leakproof weld. One way I test to see if the weld is indeed leakproof is to spary some WD40 inside the tube or tank and let it sit for a few minutes. If there is a leak or pin hole, you will start to see some weeping of the oil thru the weld or seam.
About the only time i do a trigger pulse is if I am welding something that is very rusty and probably should be replaced to start with. Money is money and I can live with a few pin holes in a muffler or exhaust pipe.
/ 120-Volt Mig welder. #178
Which model HF welder? I'm impressed, if you can do good body work with HF's 90A AC welder.
I redid the rockers ... wheel wells ... rear corner of my nieces 99 Camry ... patch a rust hole in the bottom of the cab ... Unless you looked closely you may never find it.
OK I am impressed. I get some decent work out of my HF 90A AC flux welder on slightly heavier material doing farm repairs, but for sheet metal I haven't learned to use it without burn through.
The Century 135 I bought recently is more adjustable and works fine on sheet metal with flux wire. I think this was originally advertised for body shop work.
/ 120-Volt Mig welder. #179
Having more amperage adjustability (is that a word?) is what I want in the next unit. Like mentioned above, pulsing the trigger gets it done. Certain angles seem to help too. I looked at youtube videos for stitch welding which is basically a quick tack weld every inch or so to keep the metal from blowing out. Then go back and do it again until the seam is filled. Depending on the metal thickness it seems sometimes after those initial tacks are in you now have a thicker base of material to start from so less blowout.
/ 120-Volt Mig welder. #180
Using a 120v mig on things like .25 and up is not advised by these you call pros for a reason. No one that has experience would do that. If you only have 120v power and need to weld .25 and up the only thing I would use is tig or 3/32 6010 stick, either way the same welding machine. Miller max star or dynasty 200 would be the best 120v choice. But I would not do this for anything that would be dangerous if it broke. Preheat may be required. Sounds like you were given good advice by others.
If you must use a 120v mig bevel is required, run flat or vertical up slightly. Preheat 300-450 and use that as your interpass temp but not recommended and results may not be good.
Hi Mike,
That is exactly the problem here, is why there's such a gap in 120v MIG info/instruction. Members (with experience) always always always want to tell how to they'd do it with a different welder. Sheild Arc, Arc Weld, and others have been doing this for years, and it doesn't help at all. Their inevitable conclusion is for the member to get a different machine, which has become so solid in forum wisdom that other members who know very little (at this point) will fight tooth and nail on that shaky premise.
The "member" wants to know how a pro would do it with the 120v MIG that the member HAS. But the pro doesn't have one and has no reason to ever use a 120v MIG or work out the tricks. This is a gap that requires a special "pro" who is interested to help newbies. And without pros, then it's left to a hobby/maintenance guy as time allows. And then you guys have to clean up after.
Mike, I'm sure the interest is much appreciated by many, but if you aren't showing it, testing it, and making actual conclusions WITH A 120v MIG, isn't it simply meaningless? Can you borrow one and pick up where Shield Arc left off? I doubt members have so much pent-up frustration with you as they (apparently) did Shield.
Status
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
2023 TEXLINE BOBCAT HAULER (A65643)
2023 TEXLINE...
2001 KENWORTH W900 72" STUDIO SLEEPER (A62613)
2001 KENWORTH W900...
2016 Caterpillar 304E2 (A64126)
2016 Caterpillar...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
