How to install purlins, quick question
/ How to install purlins, quick question #1
rholmes69
Zebulon, NC
Mahindra 2810
Building my first pole barn, old timer across street is giving me pointers. He said to install purlins like the picture shows I have done. 3.5in 16d nail. Joists/rafters are about 40 in space between them. Putting purlins 24 in on center. Do I need to redo the purlins just straight across on top of the rafters? It would certainly by a he'll of a lot faster than cutting so many boards... at this point I've only cut 6 2x4's
/ How to install purlins, quick question #2
Are the the rafters notched for the 2X4 purlins or the purlins cut down?
/ How to install purlins, quick question #3
I would run them across the top, not only faster but I believe stronger. Just dont have all the purlins butt together on the same rafter, you need to alternate the joint (like a block wall). And when you put the fascia board on use a 2x(dont know what width you need) not a 1x, it will give more meat for hanging gutters on.
Hope this wasnt confusing
No, the rafters are not notched, I cut each purlin individually.... took me like an hour to hang 8 40in purlins....
I wasn't planning on hanging gutters, but I will use 2x4 on fascia in case I decide to at a later date. Thanks!
/ How to install purlins, quick question #5
I have a Morton building and a BCI, both commercially constructed of wood structure. The Morton uses pre cut vertical 2x6 purlins on 2' centers between the 10' rafter spans, best I can recall. The BCI uses 12' horizontal 2x4s on 2' centers on 5' rafter spans giving you a foot of overlap on each 10' of support which makes for a sound joint....no split ends. The BCI way you just buy the board and nail it up. Goes real fast and on my self built wooden pole barns that's the way I did it. One of my first is over 35 years old and shows no sign of giving up.
HTH,
Mark
One more quick question, He has a couple large pole barns on his property and did not putting any sort of barrier between the metal roof and the purlins. I have been over to his place a number of times and have never seen any condensation on the under side and/or the ceiling "raining". With a non sealed, non conditioned building in a mostly shady area, do I need to worry about condensation? The joists/rafters are 2x10x12's flush with the ridge joist, but attached to top of side plates with simpson hurricane straps. So there will effectively be about 10in gap on the side walls between the roof and the wall.
/ How to install purlins, quick question #7
If the only thing holding the purloins is a nail into the end grain, that is very lousy support. And slow going. Normally they get nailed across the top. The long length and the nailing across grains gives lateral bracing. Sitting on top of the rafter gives vertical support. Right now you have neither.
/ How to install purlins, quick question #8
Oy. I've seen 2X purlins laid on their sides attached to the top of the rafter/truss. I've seen 2X purlins attached between trusses with narrow side up. I've seen 2X purlins on their edge on top of trusses/rafters. But never something like you've desribed and shown.
Seems like a terrible idea... from both strength and time to build perspectives. Did the neighbor offer any reasons why he would suggest going this route?
You've got a relatively wide span between rafters for laying 2X4's down for purlins. If you have any risk of snow load, and given that 2:12 or 3:12 pitch, I would get some 2X6's in there for the purlins.
$0.02
Reasoning was a wider surface to nail into and I could nail along the entire edge of the joists as well. I will remedy the situation though. At least it is only like 12 bucks in wood worth of a mistake.
No snow loads really to be concerned with. We might get a dusting to a couple of inches if we are lucky. Last winter we had around 5-6 inches in one snowfall and that was an anomaly. We had 12 inches over 15 years ago, that was the most in like like 30 years. Not really worried about snow here....
/ How to install purlins, quick question #10
I would run them across the top as said earlier. Stagger the joint locations. The couple I have help build put two nails and a 3" to 3 1/2" screw at each rafter. With the condensation, If you are not going to insulate it I wouldn't worry about a thing. Google garage journal and there is a website like this one with a wealth of knowlege.
/ How to install purlins, quick question #11
One more quick question, He has a couple large pole barns on his property and did not putting any sort of barrier between the metal roof and the purlins. I have been over to his place a number of times and have never seen any condensation on the under side and/or the ceiling "raining". With a non sealed, non conditioned building in a mostly shady area, do I need to worry about condensation? The joists/rafters are 2x10x12's flush with the ridge joist, but attached to top of side plates with simpson hurricane straps. So there will effectively be about 10in gap on the side walls between the roof and the wall. http://s98.photobucket.com/user/rholmes69/media/20140708_144542_zpshb37k7vz.jpg.html
I'd run them across the top of the rafters and leave ends long to give you a roof overhang front and back.
/ How to install purlins, quick question #12
You're going to screw the tins onto the purlins, right?
To prevent uplift, I would use some construction screws on the purlin-to-rafter connection. Especially if you're going to have open sides or big gaps under the eaves.
/ How to install purlins, quick question #13
On my outdoor deck by the pool, I ran my purlins across the top of the joists (wide side down), 2 feet between the joists, with the purlins spaced about 16 inches apart on the advice of the person installing the metal roof. I attached the purlins with 3.5 inch screws (2 at each joint). Very sturdy.
/ How to install purlins, quick question #14
If you want to do it like Morton, the 2x4 purlins are spaced every 2ft on top of the rafters and stood on the skinny side, then nailed in with a 6 inch ring-shank nail.
Them guys can shake your hand and you won't forget it.
/ How to install purlins, quick question #15
I have always seen them place on top of the rafters, sometimes tall side down sometimes narrow side down but always on top and on 24" centers. I think if I were building and put them narrow side in the vertical plane I would buy some of the galvanized steel hangers that nail or screw into the rafters and then to the purlins. I always hated toe-nailing even with a pneumatic gun.
/ How to install purlins, quick question #16
Morton does't toe-nail the purlins, they pound that 6 inch ring-shank nail all the way through the center of the purlin 3.5 inches and the remainder of the nail goes 2.5 inches into the rafter.
/ How to install purlins, quick question #17
purlins are put on edge when the trusses are larger and spaced further apart. It all depends on the design, you can have fewer trusses, but they have to be heavier and the purlins have to be able to span the increased distance, or you go with closer, lighter weight trusses, then you can use smaller purlins, even lay flat if the trusses are closer. Or you can put trusses on 16" center and sheath it. There are many options, it all depends on the design and load calculations per that design. I would not do it the way the OP shows, by nailing pieces of 2x4S between the trusses.
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
UNUSED PARBREAK GCC56 2 PRONG BALE SPEAR (A65055)
UNUSED PARBREAK...
(3) JOHN DEERE DRY FERTILIZER DISTRIBUTORS (A64278)
(3) JOHN DEERE DRY...
2011 Ford Explorer 4X4 SUV (A64557)
2011 Ford Explorer...
Ari-Hetra HDML-8 15,000lb Four Post Auto Lift (A64553)
Ari-Hetra HDML-8...
2012 Toro Z-Master 72in. Zero Turn Commercial Mower (A64553)
2012 Toro Z-Master...
