Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #1,601
now that I have seen thier video I can candidly say "no dont buy it" for two reasons.
There are no tubular weldments to hold the shroud and side weldments square and
to prevent it from racking/ twisting and thats never good.
The other reason is the side plates are bolted to the mower shroud.
That is not good simply because the mower can still twist and rack
even with thick steel plate that looks substantial. that is the reason
you see high quality flail mowers with tube frame construction and
full welds.
I would rather see you purchase a four foot Caroni with the F rotor and yes they
will order them and import them for you.
Disclaimer: The opinions offered by me are mine and mine alone alone and based
on my 30 plus years of ownership and operating flail mowers as a consumer.
Thanks for the heads up!
I WAS surprised that there are no videos of the unit in operation.
Which Caroni drum & flail combo would be best for 90% lawn & 10% light weeds/brush?
/ Let's talk flail mowers #1,602
I bought a Caroni last year...but have to say that the Woodmaxx looks to be a quality piece. Lots of nice features, and a two year warranty. If I had heard of it before now, I would have driven to their place to check them out, last year.
Don't know how fast you plan to do your mowing, but I always use low range. 3rd gear, low range, on my tractor is good for 2.05mph at the rated 2500rpm. I do my mowing in 3rd, at 2100rpm, which calculates to 1.72mph. According to the owner's manual, my tractor somehow looses 7hp from the fly wheel to the pto shaft, leaving me with 23pto hp. I'm having no problem powering my TM1900 at the ground speeds I run. Last week I was mowing our old horse pasture (no longer have horses) for the 3rd time this year...when I got to the area that has been to wet to mow until now, the grass was as high as the top of my CK30's hood...dropped down to 2nd gear, left throttle setting unchanged, and eased on thru it. Engine speed didn't drop by more than 50rpm's.
Think you'll find that ground speed figures into this equation as much as hp does. Then too, there is no rule saying you have to make full mower width cuts in very tall, heavy cutting conditions
As long as your tractor can handle the 600 pound weight of the Woodmaxx, I'd say go for it....Hill Billy Bob
/ Let's talk flail mowers #1,603
My machine is hydrostatic. 3cyl 1.0 diesel. Max operating RPM IS 3200.
I can make it inch along at .5MPH while running wide open.... though I hope I don't have to.
I see what leonz was saying about the sides being bolted on.
I'm really torn now... The Caroni costs a little less... But the WoodMaxx has some features that I really like. Mostly being able to open up the rear for tall grass & brush.
I'm primarily using it to mow the lawn & take down a rough area at the bottom of the property.
I wish I could demo both pieces on MY machine. :(
Don't want to make a mistake on a 2k purchase.
/ Let's talk flail mowers #1,604
I picked up a old Mott 88 flail mower from a local township today for 232.50. This unit is 88 inches wide and has a slight offset to the right. The township had a extra set of knives for the mower, but the employee was afraid to give them to me as all that was bid out for sale was the mower. { I really am loosing my touch.] I would get a practice piece like this as others have done before ordering a new 2000.00 mower. If any thing bad happens I still have scrap to sell.
/ Let's talk flail mowers #1,606
I also have a new to me 917. Dieselscout, do you take the knives off when you sharpen them with the flap wheel or are you able to do it with them still on the flail?
I used the 917 for the third time yesterday. I changed the belt prior to using. I didn't have belt failure but just thought I would preempt any potential problems. The old belt looked pretty worn.
I use it at my property a couple of hours from home. I have a cabin and cut the yard area the first couple of uses. Yesterday I cut a grown over food plot area. The grass/weeds were about waist high. I wasn't sure what to expect. It is a six foot mower on a Kubota 3430, 34/29.5 HP. The cut was excellent compared to a bush hog and barely lugged the tractor at all. A flail is truly a good dual purpose cutter. It works well for finish type cutting and getting into the taller stuff as well. By the way, I got mine for $400.00 on CL. It has been trouble free so far, knock on wood.
TNhobbyfarmer,
I sharpen mine on the mower just set it on jack stands. It doesn't take to long that way.
/ Let's talk flail mowers #1,610
It the Coroni a Reverse Rotation? I can't seem to find this info......
/ Let's talk flail mowers #1,611
What you are referring to is either clockwise or counter clockwise rotation.
The Caroni is referred to as a clockwise rotation flailmower which reduces the
chance anything can be sent flying as the material will be picked up and carried over
the flail mower rotor and thrown back down to the ground just as the clippings would be If
the flailmower is operating and folling the ground contour.
You have not tolds us much as we do not know what size mule you have or whether its a gear drive or hydrostatic transmission.
If you have a high horsepower (fifty plus) Mule with a hydrostatic transmission you not suffer huge power losses due to the automatic transmission and heat buildup.
You need not worry about this for the following reasons if you use the flail mower
as it was intended to be used.
1. mowing a higher cutting height is detrimental for the following reasons.
1. The flailmowers counterclockwise rotation is ment to slice the material
into smaller clippings.
2. any flail mower is working at its most efficient when the tractor speed is
a. proper for the operating conditions
b. the Engines PTO speed is set for the 540 RPM operating speed and no less!
c. The Mower is lowered to the ground-
1. the flail mower rotor creates suction when it is operationg at the proper speed and the mower hood
acts as part of the vacuum system BECAUSE the mower is lowered to the ground AND the rotation of the flail mowr rotor
and the entire knive count creates the air current and suction to mow and recut.
NOW if you have not gone over the area you are mowing thats not a good idea because
you can make a mountain out of a mole hill.
The cut will look like crap and you will have material that will not decompose quickly!!
Perhaps you can rent a york rake after you mow wth the flail mower you choose
/ Let's talk flail mowers #1,612
The tractor i am upgrading to has 30.5 PTO HP and 36.2 Engine HP on a gear drive. I would NEVER mow with a hydro as they suck too much power. I walk these properties every year but it never fails i miss stuff in the tall grass and contractors leave crap lying all over. Typically i cut at around 4" or maybe a little less. I am worried that the "clockwise" rotation will not pick up the grass that the "Counter-Clockwise" rotation would pick up. My main concern is the $500K homes i am mowing around as well as all the people walking in the public areas. Here is a photo of one of my main jobs which totals 30 acres..........
/ Let's talk flail mowers #1,613
I would REALLY like to find something like this with dolly wheels.........
/ Let's talk flail mowers #1,614
The clockwise rotation is preferried BECAUSE the flail mower rotor will throw any thing it contacts iforward and impact the flail mower hood and then fall to the ground as I have labored to explain to you.
You can safely mow at two inch height which I explained is the optimum height for mowing
which creates the suction needed to lift and carry the clippings over the flail mower rotor
and back tot he ground SAFELY.
Your tractor upgrade is going to be to low in useable horsepower at the Power Take Off.
If you can afford a 40 horse power hydro unit you should at least consider that as many retailers are offering zero percent financing.
Again the clockwise rotation is fine! The problem is your 4 inch mowing height
which I have labored to explain to you will be the problem.
Unless you purchase a Vrisimo road sider or spend a small fortune on an Alamo flailmower
you will not be able to buy a flail mower with casters.
AS I mentions previously mowing at two inch cutting heightthis will provide with the cut
you need and the safety in mowing while pedestrians are inthe area.
We used a John Deere 25A with a Ford Jubilee so think about that please as a JD 25A will work
well for you mowing at the 2 inch cutting height. You really dont need the casters if you mow
slowly in a spiral pattern as you will overlap avoid braking and backing up wasting fuel and time.
/ Let's talk flail mowers #1,615
The issue here in Montana is there are plenty of rocks you would need an excavator to move. The property above eats a set of bush hog blades in 22 acres even after all the loose rocks are pulled up unless i mow at at least 4" If i where to mow around all of these large rocks at 2" i would have to have a laborer to mow about 1/3rd of these lots with a hand trimmer. Much of the grass is a thin wirey type grass that don't suck up well and i have a horrible time with it on smooth lots with my Grasshopper finish mower. The point of a flail is it can't pick up anything really large and anything it could pick up would get stopped by the plates on the front in a clockwise rotation unit or the rubber belting on the back with a CCW rotation. The rocks are another reason that the casters wheels would be preferred as the roller would get the crap knocked out of it. I can fab up casters as long as i have a good solid surface to mount them too.
/ Let's talk flail mowers #1,616
(Are you in the Powder River Basin?)
(Has this land been strip mined fror coal and then reclaiimed?)
all the loose rocks are pulled up unless i mow at at least 4".
(The only real option you have is to mount a York rake in the
front of the tractor to catch the rocks before you hit them)
If I were to mow around all of these large rocks at 2" i would have to have a laborer to
(Is it Buffalo Grass?)
(This is what I have been explaining to you; unless you purchase a combination front/rear
mount flail mower you will not have the debris catching plates as standard equipment.)
(you cannot fabricate heavy enough casters for this)
(The casters are there ONLY to allow the flail mower "which is in contact with the ground
surface" to prevent the rear roller and side weldments from gougeing the ground.)
In order to sove this you will need to buy a motorised towed flail mower with front and rear caster wheels OR
Simply purchase a small horsepower Vrisimo flail mower and ask to have front and rear casters installed as an add on item with casters and ask them to install front casters on it as well for you.
Rear casters alone will not solve this issue as the area was not finish graded with dozer apparently.
Either way you are going to have to install a York Rake in the front of this tractor with your mowing conditions.
If you purchase a JD 25A seven foot finish flailmower you will be able to weld the caster weldments to the front box beam BUT
saying that you would have to attach the casters to the side weldements behind the flail mower rotor using steel tubing the thickness of the box beam to mount the casters.
It will be much simpler for you tp purchase Vrsimo flailmower sized for your tractor and have them make a change/add
order to ad front casters to the mower as they have to mount the four casters in the proper location onthe flail mower to prevent interfering with the rear wheels and the lifting arc created by the three point hitch.
Dont expect to be able to mow fast with a low horsepower flailmower its not going to happen.
Again I want you to suceed and not fail. I do not have my hand on your wallet. I am simpy trying to be realistic with you and your operating conditions.
Ask Vrsimo how much a 5 foot flail mowr would cost with front and rear casters and more structural steel to support them.
The flail mower shroud is designed to complement and add strength to the side weldments of a flail mower.
The with shrouds with the mounted casters are thicker steel to increase the structural strength of the shroud and side weldments as the caster add two more points stress to the flail mowers weldments.
I take it this mess is a HMA with fussy owners?Homeowners Management Association?
You need a york rake to help with this period.
/ Let's talk flail mowers #1,617
Yes, It's an HOA. I have most of the loose rocks picked up but there are MANY huge rocks that would need an excavator to move. The frost tends to move them up out of the ground over winter. I have mowed different HOA's for 20 years and it's always the same issues. Rebar, Blocks of wood, Chunks of concrete, Rocks Ect. I make sure i get paid well for the headache. As far as casters, i have seen these 2 units. One is a JD with home made casters and the other looks like a Factory Alamo??
/ Let's talk flail mowers #1,618
You ought to seriously invest in the rental of a wide vibratory roller with all that you have going on in those areas,. renting the vibratory roller for a week will save you a lot of worries and you will be able to mow closely with a standar flailmower sized for your new tractor
You still need a York rake mounted on the tractor front and
a flailmower that will work well with a thirty horse
power mule and you need to have the manufacuturer
install front and rear casters on their frames
Call Vrisimo in California and ask them how much a five foot road sider
would cost with front and rear casters AND BUY IT.
/ Let's talk flail mowers #1,619
10K Nearly 1/2 the price of the tractor.............
/ Let's talk flail mowers #1,620
It is referred to as the opportunity cost-what you willing or able
to give up for what you desire or need
I would rent a large vibratory toller for a week before you mow
with a less expensive flail mower
Your in business to make money.
TO make money you have spend adequate funds for
machinery(physical plant).
Invest in vibratory roller rental for a week and a good York rake
and then purchase your flail mower.
Your running out of options other than the renting a Vibratory roller and
purchasing a York Rake OR purchasing the Vrisimo with dual casters.
1996 John Deere 8400 Tractor (A66285)
1996 John Deere...
2015 PALMER MACHINE WORKS 24' DUMP TRAILER (A60430)
2015 PALMER...
2013 CATERPILLAR TH514C TELESCOPIC FORKLIFT (A65053)
2013 CATERPILLAR...
New/Unused CFG Industrial MH12RX Mini Excavator (A65583)
New/Unused CFG...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A63118)
2023 New Holland...
