Free electricity !
   / Free electricity ! #1
Tomtint
Elite Member
Boston
L3700SU
Well I guess it's sort of free.. If I can figure out how to harness it. We built our house about 4 years ago and I will try to explain this as good as I can, but we have power coming out of the ground. If you stand outside barefoot and touch something metal.. You get a tingle. For example, we were planting some trees and the root ball had the metal cage around it. The cage was in contact with the ground, and when I knelt down with a bare knee to the ground and touched the cage...zaaaaap ! My A/C guy was pressurizing the condenser last summer and was getting hit when his bare knee was on the ground and he touched the copper on the unit. In the basement, if you ground a meter, you can pick up voltage from the foundation ties ! After finding this last year I notified the electric utility and they came out and drove grounding rods tied to all our outside mechanicals, then I checked all the other houses on our road and they are all hot as well. I think I could stick some low voltage lighting into the ground and they may work. ..
   / Free electricity ! #2
Strange. What does your volt meter read?
   / Free electricity ! #3
Strange indeed.
Do you have any communication/microwave towers nearby? Power lines?
What doesn't make sense is the objects are in contact with ground, and so are you, so where does the "step and touch potential" (i.e. the voltage differential you experience) come from? (In addition to where does the current come from?)
[That is, we are all "birds on a wire". That is, it's all relative. There needs to be a DIFFERENCE in voltage to get a current to flow. Example, if my yard was at 200 volts compared to my neighbors yard, I wouldn't get shocks, because I and everything I touch is at 200 volts (compared to someplace else), but at zero volts compared to me. Understand? ]
Similarly if you ground a meter then measure ("grounded") tiles, how can there be a voltage? Either the tiles or the "ground" reference your using is not at zero volts.
In this case, how do you "ground" the meter?
At first I would say, you have voltage/current on your panel ground conductor (i.e. an floating/ungrounded electrode system) that you are measuring/feeling when you touch part of this system (the AC system / piping) and the "real" ground at the same time, but this doesn't explain the root ball where I assume you are away from the house?
If I use a volt meter and stick the ground onto anything metal the stick the other end into the ground, I can get 50 volts +/-. It is all over our neighborhood and we do have a power line about 700 yards through the woods. I'm assuming there is some issue that originates from there. My neighbor, about 1500 feet away has a pool. For a decade he has gotten poked from his grill, after he stepped out of his pool. Really really odd.
Correct, the root ball was in the mulch bed away from the house. Wire cage in the dirt and a bare knee in the same dirt, creates a nice zap when you touch the cage.
   / Free electricity ! #6
You should get the monsters and mystery TV crew there to make an episode. They could call it Electrosquach. He has been terrorizing the country for years. If you make any money off this idea I get half!
Seriously you get 50V from the ground.... Sounds like a major issue. Have you contacted anyone to report this? Who knows what the long term effects will be?
   / Free electricity ! #7
This is definitely not normal and potentially very dangerous. Since it is in the whole neighborhood, it is a power company issue that needs to be corrected. I would think they would want to fix the problem rather than face liability issues.
   / Free electricity ! #8
Do you get a shock from your car when you step in or out?
If you turn on your AM radio do you get a loud 60hz hum?
I wouldn't of guessed that a 60 Hz power transmission line wouldn't put out those kinds of EMF's at 700 ft. But maybe? Is it a big line?
If you told me you had a high frequency TV/communications/radar microwave broadcast/relay tower etc.. 200ft from your yard, then yes.
Use the 50 volts to charge an array of batteries, there's your free power!
   / Free electricity ! #9
meter set to ac or dc?
have you brought out a flourescent lamp tube to play with too / do some testing with?
any radio towers nearby?
   / Free electricity ! #10
I have been an industrial electrician for over 50 years, and ran into a very similar situation once.
I Turns out the neighbors (about 500' away) had a defective system ground, and a bad Electric hot water heater element, that was charging the ground.
I suggest you have all of your neighbors turn off their Mains while someone watches a meter, when you find the guilty party the voltage will disappear.
   / Free electricity ! #11
50v? I would demand this get fixed asap. A small child and a rainey day....recipe for disaster....
   / Free electricity ! #12
Call your local newspaper or TV station. Tell them "some little kid is going to get fried in a puddle" and see if that speeds up a response. :lightningbolt:
   / Free electricity ! #14
Google "Primary cause of stray voltage"
   / Free electricity ! #15
ive seen this in the past. and as stated before me, it from someones miswired and non grounded system causing the issue. Ive run into similar situations where ive touched a metal building (shop) and felt the tingle. you have to shut down one system after another till you find the culprit.
very..very dangerous indeed.
   / Free electricity ! #16
Your state should have a utility commission that regulates the power company. This should get their attention. Surprised that the power company did not solve the problem because they would be liable...
This kind of leakage in a marina has killed swimmers and it can corrode metal hulls very quickly.
Later,
Dan
   / Free electricity ! #17
I have the same problem at times, it is usually an electrical gadget that has a short circuit to ground. Begin your hunt by disconnect one and one thing and check with a multimeter if the error disappears
Out local utility is NSTAR. They were notified multiple times before sending someone out last year. They did the "pass the buck" shuffle and tried to blame the phone/cable company. Then they sent 3 or 4 different engineers of their own out to take a turn. If they knew what it was they did not say so. They went to all my neighbors and found the same voltage +\-. Then had a private contractor come out and ground all the outside metal pieces around the house. ... Now I know why my dogs hated to drink from the water spickets. At the time ( last year ) they said they were going to work on the situation, but I have not seen them since.
The power company killed my power last year from both the transformer and then further up line to where it originates. Even with no power feed to the house, I can still get poked as I described earlier and there is no drop in voltage either.
No radio towers nearby, not for miles anyway. I can't remember if it was AC/DC and I have not brought out a lamp, I'm not a electrical guru so I don't know how exactly to make it work. It would be nice to find a way to get low voltage lights to glow on my 1500 foot driveway though
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2023 WRANGLER 5500T ARTICULATED WHEEL LOADER (A58214)
2023 WRANGLER...
2015 Nissan Altima Sedan (A59231)
2015 Nissan Altima...
(15) WOOD PALLETS (A60432)
(15) WOOD PALLETS...
SKID STEER MOUNTING PLATE (A60432)
SKID STEER...
Hyster 60 6,000lb Diesel Forklift (A59228)
Hyster 60 6,000lb...
