Is the "5hp. per Mower-foot" Rule Inviolate? Want a 6' MMM on a B2630 vs. B3030
/ Is the "5hp. per Mower-foot" Rule Inviolate? Want a 6' MMM on a B2630 vs. B3030 #1
My Hoe
NYS--Various Parts
Kubota B3000HSDCC, BH77, 5' Belly Mower, 6' Hyd. Angle Plow
Hi all,
I have read that one should have 5hp. for every foot of mower-span--but I'm not sure if this applies just to THP mowers, or to MMM, as well?
I am a fan of the "old" (discontinued in, I believe, 2012) "Premium B" series, comprised of the B2630 and the B3030 (and it's cabbed variants).
I prefer the B2630 because I tested one, and it's 3-cylinder engine was even smoother than the BX25's 3-cylinder I tested. (IIRC, the B2630 I tested--at 67 hours--went into service about 2007, and the BX25 was newer, but not the 2014 BX25"D", with all of it's improvements, like Kubota's proprietary "QA", etc...) I tested these tractors in 2010, IIRC.
I am leaning toward the B2630, but have never tested a B3030. However, I've read that some B3030's might suffer from the four-cylinder vibration problems reported in some of the B3000 and B3200-series machines (no offense to those owners, and I understand that reports vary, and that there are many of these B3000, B3200 and especially, B3030 owners, that have NO vibration complaints).
I just do not like excessive vibration. It's a personal quirk/failing/idiosyncracy and I've accepted it, so I hope you all can, too. :D
I also like the B2630 for it's smaller displacement (68.5 cu. in. vs. 98.5) as most of my usage will be FEL, BH and forks. However, I will have to mow the portion of our 1.8+ acres that are not covered by our 36' x 38' barn, four-car garage, house and outbuildings. Most of it is quite flat, but there are trees, the aforementioned buildings, and 2-3 additional outbuildings, which is why I prefer the MMM, despite the mounting hassles. IOW, I feel I'll hit less buildings, with a MMM setup, than I would with a TPH model. Plus, my neck doesn't turn around backwards as far as the rest of the humans.... :laughing:
However, I believe I want the 6' MMM, instead of the 5' MMM, for quicker mowing time, and possibly being able to get in closer to obstacles, with the wider mower.
I have seen B3030's with 5' MMM's, and B2630's with 6' MMM's--and vice versa.
My Questions:
1. Is the B2630's 19.5 PTO hp. enough for a 6' MMM, given that I want to mow infrequently, at the 12"-14" stage?
2. Should I go with a B3030, given it's 23 PTO hp. if I want a 6' MMM?
Please keep in mind, before you answer, that I am not "precious" about my "yard/lawn" and, given that I will have to remove the FEL and BH to mow, I don't want to mow every week--I'd be happy not mowing for 2-3 weeks, until it gets tall enough to worry about the Town's Code Enforcement Unit--I just have too much to do in my life to manicure my lawn for others to look at. And I don't see it--it's just green. When it gets too tall, so that it wets my shoes with dew, or risks getting ticks on my dawg, then it's time to mow.
So...is the B2630's 19.5 hp enough for a "high grass mowing" (think 12-14" or more) or do I need the B3030's 23 PTO hp. for this duty, to run a 6' MMM?
And I do realize that, at 23 PTO hp., even the B3030 does not match the "5 hp. per foot" rule, as it would have to have 30 PTO hp. to do this--and it does not.
Also, does a MMM require MORE, or LESS, hp. per foot, than a TPH-mounted mower, all other things being equal? Or doesn't it matter?
And please--don't spare my feelings--if I've overlooked something in this calculus, please "fire away"--I'm here to learn, not make myself feel good.
Thanks, very much, in advance.
My Hoe
/ Is the "5hp. per Mower-foot" Rule Inviolate? Want a 6' MMM on a B2630 vs. B3030 #2
Re: Is the "5hp. per Mower-foot" Rule Inviolate? Want a 6' MMM on a B2630 vs. B3030
I run a 3PH 6 footer on a 26 hp Cub Cadet gear model and it works flawlessly. I tried the same mower on my L3940 Hydrostat and it did NOT work well at all, it would bog and almost kill the engine.
Is you machine gear or hydro?
Good luck, Fred
/ Is the "5hp. per Mower-foot" Rule Inviolate? Want a 6' MMM on a B2630 vs. B3030 #3
I ran a 48" brush hog on the back of my B3030 and felt--in my opinion--that it was under powered.
/ Is the "5hp. per Mower-foot" Rule Inviolate? Want a 6' MMM on a B2630 vs. B3030 #4
Mom has a B3030 and it is very smooth running tractor vibration wise. Find one and try it before you get too commited to the B2630. Its never lacked for power but we just use it for tilling in her flower beds,she had a large number of flower beds.....
/ Is the "5hp. per Mower-foot" Rule Inviolate? Want a 6' MMM on a B2630 vs. B3030 #5
The 5 hp per foot of mower is a good "rule of thumb" but certainly not inviolate. It can depend on both the height of the weeds and grass you're mowing, as well as the thickness of same. And of course, if need be, you don't have to mow the full width of your mower; i.e., you can mow 3' swaths with a 6' mower, but of course if you have to do that all the time, you defeat the purpose of the wider mower.
/ Is the "5hp. per Mower-foot" Rule Inviolate? Want a 6' MMM on a B2630 vs. B3030 #6
We have a Kubota B2710 27HP with 20HP at PTO and run a 72" MMM without any problems. Also run a 60" Bush Hog cutter on same tractor.
/ Is the "5hp. per Mower-foot" Rule Inviolate? Want a 6' MMM on a B2630 vs. B3030 #7
Is the MMM SIDE Discharge? If so I believe you'll need the extra power. It takes a toll getting the cuttings from one side to the other. I comfortably run a 5' FM with REAR discharge using 17.5hp (that's 3.5hp/ft) for what its worth.
/ Is the "5hp. per Mower-foot" Rule Inviolate? Want a 6' MMM on a B2630 vs. B3030 #8
Our 72" Kubota MMM is side discharge and will throw cuttings at least 12-15 ft.
/ Is the "5hp. per Mower-foot" Rule Inviolate? Want a 6' MMM on a B2630 vs. B3030 #9
I run a Woods RD7200 rear discharge finish mower on my Ford 8N, anything over 8" and it struggles and bogs. I run a Woods RD7200 rear discharge finish mower on my L3940HST, 8" is fine, will not bog. If the grass is taller than 10", I use a Land Pride RCR1272 bush hog, as the finish mower does not provide good quality cut. If you are waiting till your grass is 12"+ to cut, I would use a bush hog (in my experience). Good luck. Philip.
/ Is the "5hp. per Mower-foot" Rule Inviolate? Want a 6' MMM on a B2630 vs. B3030 #10
I have a bx1860 with a 48" mmm and a 48" big bee brush hog. The mmm is powerful and the brush hog is ok. It may have to do with mmm rpm being higher?
Bx1860=18hp with 15pto
/ Is the "5hp. per Mower-foot" Rule Inviolate? Want a 6' MMM on a B2630 vs. B3030 #11
Like Bird says, it all depends on the grass /weeds and how tough they are. I have some grass (I call it wire grass, don't know what it is) that is so tough that it will stall my 60 HP tractor with a 7 foot BH and I have to slow down a lot to cut thru wet areas where it grows proficiently. The guy I bought my B26 Kubota from routinely ran a 5 foot bush hog in waist high grassland with the 19PTO HP but the grass was tender to cut. MMM and rear finish mowers don't take as much HP per foot as a bush hog mainly because the blades are sharper/thinner and turn faster.
You may pull a 6 foot mower OK but have to go slower. At some point the travel speed that you have to go to run a 6 foot compared to a faster travel speed with a 5 foot is going to outweigh the wider mower in production factor. There are just too many variables to say absolutely that it take 5 HP per foot or 10 or 4. Every pasture/yard is different and every tractor's PTO power may be a little less than advertised or less than another model. Each engine runs a bit different and HST models suffer a larger loss at the PTO than a straight gear drive.
Thanks to one and all.
Your answers were VERY helpful.
I apologize for the long delay in following up--to much LIFE got in the way.
Thanks again,
My Hoe
/ Is the "5hp. per Mower-foot" Rule Inviolate? Want a 6' MMM on a B2630 vs. B3030 #13
If Kubota offers a 72 inch mower for your tractor,they must feel it has enough power or they wouldn't make it available.But that would be for normal mowing which I don't think 12-14 inches is.
/ Is the "5hp. per Mower-foot" Rule Inviolate? Want a 6' MMM on a B2630 vs. B3030 #14
can't go wrong w/advice given here. i would also add that the brush hog weight is also a consideration. a tractor pto hp may handle a given size hog, but be iffy on handling it's weight esp on slopes. assume you have a fel which helps considerably to counterweight the rear load. of course, finish mowers are lighter but can't handle the wider application of heavier duty models..... your manual should give maximum specs for various implements on your model. just to keep in mind imho
kcender,
Re:
Agreed and agreed. 12-14" is not normal mowing height. Good points, both. Thanks.
I agree--I really appreciate ALL of the great advice I've received here!
And thank you for your point about the weight of the tractor itself possibly being inadequate. I do know that Kubotas are some of the lightest CUTS, for a given horsepower, as a general rule. I had not considered your point before, because I was not considering a brush hog, but perhaps that's really what I'd need, rather than a finish mower, if I were to mow as infrequently as planned. And I had never considered that brush hogs were heavier, per a given width, than a finish mower, but that only makes good sense, now that you mention it.
Since I don't want to leave the FEL on (as a counter balance to a heavy brush hog), given the number of obstacles I'll need to mow around, I may have to concede that my plan to only mow at (abnormally high) heights is unrealistic, and go with a lighter, finish mower, and be more "normal," and less lazy.
I appreciate the reality check--from all of you. And especially, the courteous diplomacy with which it was given. That's yet another thing that's truly special about this Forum.
Thanks again, to all.
My Hoe
/ Is the "5hp. per Mower-foot" Rule Inviolate? Want a 6' MMM on a B2630 vs. B3030 #16
Hi all,
<snip>
<snip>
My Questions:
<snip>
My Hoe
Answers to questions based on my own experiences:
1.) 19.5 HP is plenty for a 6' MMM under normal conditions. 12"-14" is not normal though IMHO. Even with nice sharp blades you will struggle. A 5' rotary cutter is a better choice for that type of length. If you want to chop down that height of grass with the MMM, go with the 5' for sure.
2.) I would try to go B3030. Four PTO hp is actually a lot IMHO.
Your last question about hp requirements between different types of mowers is loaded question lol.
So let me clarify what I'm trying to say. 72" single spindle mower/cutter takes more HP than a 72" three spindle mower/cutter. A lot more.
Rear discharge mowers should use less HP than side discharge.
Hope this helps some.
/ Is the "5hp. per Mower-foot" Rule Inviolate? Want a 6' MMM on a B2630 vs. B3030 #17
I with Gary. I have done a couple of acres of 3 ft tall grass and weeds with a 48" bush Hog behind my B4200 with only 10 PTO HP. It could do it, well could not lift the rotary cutter but could cut grass. Then I got tired of mowing in low, 2nd gear so put the cutter on my MF135 and proceeding to cut 8 more acres in the time I cut two acres with the B4200. I would not worry about the weight as its centred and usually has wheels. All my tractors rattle and shake, 1 is 2 cyl, one is 3cyl and my B3200 is 4cyl. Having two gear tractors and one HST, all I can say is with your options, ear protection is a must. (HST is so loud) I love my old Massey, super quiet and comfortable.
2018 Ford F-150 Pickup Truck (A59230)
2018 Ford F-150...
Case-IH 160 Puma (A57148)
Case-IH 160 Puma...
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
2006 Freightliner M2 106 T/A Dump Truck (A59230)
2006 Freightliner...
2017 BX2680 Sub Compact Utility Tractor (A61306)
2017 BX2680 Sub...
2023 Kubota M7-174P (Premium) 4WD Tractor - 400 Hours (A61307)
2023 Kubota...
