Filled My B2920 Tires With Windshield Washer Fluid
/ Filled My B2920 Tires With Windshield Washer Fluid #1
Howard92
South Pittsburg, Tn
B2920 Kubota, GT275 Deere
Siphoned 12 gallons of 0 degree Walmart windshield washer fluid from a 5-gallon bucket into each rear tire. Lifted the rear tires slightly with a floor jack and deflated them. The tires seemed to be a little above the level of the axle. I believe 15 gallons would have put them at the 3/4 mark. The whole process took about 3 hours. It will be interesting to see how the ballast and the 2" rear wheel spacers effect the side to side stability.
/ Filled My B2920 Tires With Windshield Washer Fluid #2
wouldn't work for me ,no cab or windshield.
/ Filled My B2920 Tires With Windshield Washer Fluid #3
Just kidding ,what method did you use for the transfer.
edit; guess i should have read instead of just looking at the picture.
20,000 comedians out of work................ :donkey: :donkey: :donkey:
/ Filled My B2920 Tires With Windshield Washer Fluid #5
View attachment 360681View attachment 360682
I put 40 gallons in each rear on my last tractor.
You will find an improvement in stability.
Between the spacers, and the extra 180 or so lbs. down low - You will be pleased.
Lunk
/ Filled My B2920 Tires With Windshield Washer Fluid #6
Of course it works and FANTASTIC thinkin BUD..............For me, when I did this, I put the valve stem at 10 oclock and when it started to "flow out" I knew where I was..............Anyway, it works...........God bless...........Dennis
/ Filled My B2920 Tires With Windshield Washer Fluid #7
So you take the shrader valve out of the stem and connect the flexible tube to stem. How does the air in the tire get out as it's displaced by the fluid? Or is there enough head pressure to keep the flow going without letting air out?
I originally planned on removing the shrader valve and using a very small plastic tube (about 1/8" od I think) that would pass thru the shrader valve opening and still have a little clearance for air to escape from the tire. I had done a test shiphoning windshield washer fluid thru that small tube. It would have worked, but it would have been 3 or 4 time slower.
But I found that the valves that came on the wheels where the type of valves that the whole shrader valve section could be unscrewed and removed (it seals with a small o-ring). That allowed me to use a larger plastic tube (1/4" od I think) which made siphoning much faster (about 1 gal per 8 minutes).
My main concern was that the tire might start leaking around the bead before I could get the fluid in and the tire aired back up, but that did not happen.
/ Filled My B2920 Tires With Windshield Washer Fluid #9
/ Filled My B2920 Tires With Windshield Washer Fluid #10
Guys here is the fill valve to use.
Amazing the gizmos that are out there, and I've never even heard of them.
/ Filled My B2920 Tires With Windshield Washer Fluid #12
I removed the rear wheels and took them to my local tire shop and had them break the bead on one side only (did it for free). Then back at my shop I laid them on their sides and poured washer fluid in thru the opening between the rim and the tire. A ratchet strap around the middle of the tire to seal the bead then popped it back on the rim with some air. Voila! Huge difference in stability.
2014 Chevrolet Impala Limited Sedan (A59231)
2014 Chevrolet...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
2006 John Deere 120C Hydraulic Excavator (A56857)
2006 John Deere...
2023 Bobcat E60 (A53317)
2023 Bobcat E60...
