Blackberring clearing
/ Blackberring clearing #1
sikboater
Member
Hey all,
I am working on a job that requires the removal of some very overgrown blackberry bushes (probably over 10 years worth of growth)... I have part of it done but the hard part is still coming up. My tractor a brush hog do a pretty good job but now I am getting into some growth that includes some small trees and there is an old building in there (I have already worked around two sides of that).. Also I don't know what is in the bushes and after 1 front flat tire, not sure I want to put my tractor into the unknown. There is probably about an acre or so left. You can see the the pictures what I am working against (and being pretty effective for the most part). I have a MF 1240 (about 30 hp) and a 5 foot mower (just to help with the sizes of the picture)... I have already spent about 6 hours over there to get about 1/2 of the area cleared. The current way I am doing it is to drive through it first, then mow it after knocking down the bush and checking for hidden suprises...
I know in the future I will need to come back and keep it mowed down but the initial clearing is the hard part.. :^)
I thought maybe there would be some other options. Maybe renting something would be more effective at knocking all this down..
My initial thoughts came up with two options:
1. Rent an small excavator with a mower and work my way through it (Kabota 161). Could use the front blade and a bucket to clear out things I was not able to mow down.
2. Rent a dozer and just run it all over and push into a big pile (maybe they could burn it later).
He is willing to pay for the rental of the equipment and my hourly rate to get job done. Plus there is a few stumps up by the house he would like taken out..
Does anyone have any suggestions? Which option would you go with to clean up the area?
Thanks
/ Blackberring clearing #2
I use one of these on my tractor to clear blackberry bushes.....works great.
BXpanded Piranha Tooth Bar
With the building you describe and the unknown.....the dozer is probably your best option.
/ Blackberring clearing #3
I would say a dozer and make sure all the roots are gone.
/ Blackberring clearing #4
No doubt a dozer would work, but we used a tracked skid loader on growth like that last year in combination with our tractors. My son is pretty good with a skid steer or excavator but has no experience with a dozer nor do I.
We could have done it with just our tractors, but flats are a real hazard in some of that stuff, we still managed to get one.
So nobody thinks one of the fail type brush mowers (that can take down small trees) on a excavator would be a good fit for this job? I first thought a dozer would be the key but wonder if chopping it up with a mower would be better and easier to clean up.
Thanks for everyone thoughts!
Tim
/ Blackberring clearing #7
Tim
May be, I just have no experience with one and we piled ours up into brush piles that we can burn or leave for wildlife cover.
Sorry should have told ya all that..... In Bellingham WA area... North of Seattle.
/ Blackberring clearing #9
I had the same thing when I bought my place in 2004 and started the house. Along with the blackberries the area had been clear cut about 15 years earlier and there were all sorts of stump rows to deal with, mostly rotten by then but you just never knew where the next one was. I had/ have a 90 HP 4wd MF491 with loader and did some of it (about 2 of 12 acres) but eventually chose the dozer route with a root rake. Took a couple of days but so worth it.
Be aware that there could be some very nasty stinging insects nesting up in those thick bushes and trees.
I suggest a cabbed dozer OR use this as an excuse to buy a grapple.:D
/ Blackberring clearing #10
I have only once needed to clear similar ground - about 10 acres. It was a previously clear felled pine area and similar regrowth to your photograph and hidden stumps. After much deliberation and discussion involving quantities of reasonable quality whisky (it was the Scottish Highlands) with a neighbour we decided he would do the job with a small dozer he owned. We had previously used it to make heaps out of a less well regrown area, but thought this needed different treatment. He dug a wide ditch and then dragged or pushed all the nearby top growth into it and repeated this across the whole 10 acres. In effect it was similar to using a gigantic plough that tipped all the top growth into the bottom of the furrow. It worked. We seeded it down to grass and the grass grew very well. I then moved to Portugal, but my son saw the land about 5 years afterwards and he said it looked well.
It might not work for you, and the landowner might not like the idea either, but it is worth a thought.
/ Blackberring clearing #11
I did a similar black berry job, but much smaller, earlier this spring. My wife wanted to push back our black berry jungle a little to give her more room around her blue berries. I have a small dozer. I ran the dozer back and forth thru the berries to chop them up with the dozer tracks. Didn't use the dozer blade at all. Then I ran my tractor and land plane thru the area to even things a little and get some of the roots out and also to collect up the debris w/o collecting to much dirt. It is tough to get all the roots out so they don't grow back so I don't even try. I have found that if you just keep mowing the area when you mow the lawn the black berries will disappear and it will fill in with grass. I should put some grass seed on this to make it grass in quicker but haven't got around to it yet. This is how it looks now after about 6 weeks and you can see my debris pile is pretty clean.
Maybe this wiil help.
/ Blackberring clearing #12
We rented our goat herd out a couple years ago to clear a old home place like that out. Let them eat for a few weeks and came back in and bush hogged the rest. They got it so we could see through it easy enough by eating the leaves and small branches off. We just backed the bush hog into the remaining thicket until it was gone. No flat tires but lots of scratches. Good luck I don't envy you unless you are getting paid good.
/ Blackberring clearing #13
Since I own one (5 ton) I'm biased, but a mini-excavator with a thumb works well. Rip the ground and shallow roots with the bucket teeth, get rough level. If you hit a stump pull it, big rock, old car axle, etc. drop into piles. Final level with front blade (ground should be pretty loose by then). When you're done dig a hole(s), bury the debris, cut big trees into 2-3 foot chunks, add dirt and pack down as you go, cover with a couple feet of dirt, spread the excess dirt where you need it. It might settle a little over a couple decades but not much.
In the photo There'a a 500lb rock and a 100' 5/8" poly rope grown into the grass in an area I was preparing to mow.
/ Blackberring clearing #14
thats the ticket if you leave the goats there long enough they will deatory them bushes and fertlize your ground as they do it. we cleaned off around 20 acres with goats they eat the stuff down to where you could walk up to the big stuff and cut it. worked well for us
/ Blackberring clearing #15
Tim
I've been using a Mott 74" flail mower to clear some very substantial multiflora bushes out here on the east coast at my neighbors pretty successfully. About a 5 acre field that had not been mowed in quite some time, the bushes are very stalky and invasive around here, trunks up to about 2" thick and full of prickers, nasty stuff. Biggest issue is the hidden stuff you can't see, like felled trees. I put the FEL down low to do a little "exploratory surgery" before I proceed and I go slow. I've been very impressed - have not yet lost a blade.
/ Blackberring clearing #17
Just hang in there. Drop your loader and make a pass. mow what you can then see. You can get it if you take your time. Just keep working on it until you get some paths. It gets easier after that. A dozier for blackberry briars is overkill. The building in the middle may be a different story.
Thanks all for the replies and ideas! I also discussed this with a friend of mine who owns some larger equipment.. He recommended the Dozer route.. The one aspect I did not think of was that with the Dozer and a brush rake you can push all the vines and other stuff into a pile and get the ground clear of that stuff.. (that would make him happy) I will recommend to him that we need to plant some field grass to help keep the weeds at bay (along with keeping it mowed a couple of times a summer). The small excavator would work but with the unknowns in the bushes the Dozer would be less likely to damage... :^)
I checked on rentals around here and can get a Dozer and rake for about $305 plus delivery and fuel for a day, 8 hours of run time. Plus I will charge the operators (me) expense.
I will try to take pictures and post them when I get it done for everyone. Probably will not get to it until July...
Tim
/ Blackberring clearing #19
Those blackberries are a problem out here......if I didn't cut them back.......you wouldn't see my house or shop in 2 or 3 years. Between my toothbar and DR.......they cry when they see me coming!
2016 Kubota L3301 (A62177)
2016 Kubota L3301...
Quick Attach Grapple Bucket (A66285)
Quick Attach...
(4) 10-16.5 Tires (A65640)
(4) 10-16.5 Tires...
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A65053)
2016 CATERPILLAR...
2025 Auger Bits Skid Steer Attachment (A61567)
2025 Auger Bits...
