John Deere 1026r poor mowing results and poor loader dump control.
   / John Deere 1026r poor mowing results and poor loader dump control. #31
Ok. I can't figure out how to get it to link here, but if you go to you tube and type in jd300cx/curl it will pop up.
Saw the video. I really appreciate it. That appears to be light manipulation like what others explained. I can do that. What can't be done is full dump an full raise. If you pull the loader stick back all the way and dump all the way, your machine will stop dumping or raising.
   / John Deere 1026r poor mowing results and poor loader dump control. #32
Just as a point of clarification, the 1026R & 1025R use a H120 FEL. A 200cx or 300cx or 305 FEL are different equipment & the joystick stacks associated with them may be different as well, with differing functionality...
Nick
   / John Deere 1026r poor mowing results and poor loader dump control. #33
I move dirt a lot so the double action function of a loader is important to me. I am able to get a full load of dirt in the bucket by driving into the dirt slowly, curling and raising the bucket at the same time. I can load my 4 yd trailer in under 10 minutes with either of my machines. The gear drive tractor hydraulics is faster acting than the HST tractor. Think that has to do with the same hydraulic pump powering all the functions on the HST. I would have considered going Green but for the loader operation.
   / John Deere 1026r poor mowing results and poor loader dump control. #34
I thought all the way to the right on the loader joystick was called regen? Maybe it is different on a JD.
   / John Deere 1026r poor mowing results and poor loader dump control. #35
Thanks JF. BigMike, I can have a full load of dirt of gravel in the bucket and get the same result. I was going slow so it would show up in the video. I've also noticed my 3320 has the stacked rops lighting like the 4000twenty series instead of the single light. Was that way when i bought it. Never really gave it much thought. untill now. 3320 005.JPG
   / John Deere 1026r poor mowing results and poor loader dump control. #36
Thanks JF. BigMike, I can have a full load of dirt of gravel in the bucket and get the same result. I was going slow so it would show up in the video. I've also noticed my 3320 has the stacked rops lighting like the 4000twenty series instead of the single light. Was that way when i bought it. Never really gave it much thought. untill now.View attachment 320106
Nice brush guard!
   / John Deere 1026r poor mowing results and poor loader dump control. #38
nevermind. there seems to be a clarity issue on what im talking about. Yes you can open both vales at the same time but you cannot pin the lever to the corner opening both valaves at 100 percent and expect a cycle of both actions. seems to be verified throughout this thread and I verified today on my cousins open station 3720. you have to be at a mid point.
   / John Deere 1026r poor mowing results and poor loader dump control. #39
Ok. I guess I'm not understanding completly what you mean. That's fine. Maybe someone can post a video of what your talking about with a piece of equipment that can do it. That way I'll know too.
   / John Deere 1026r poor mowing results and poor loader dump control. #40
What he means is that you can do one or the other movement well and at full speed, but when you do both at the same time you can only go at a slower speed
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
2014 Ford Edge SUV (A56859)
2014 Ford Edge SUV...
2014 LOAD KING BELLY DUMP TRAILER (A58214)
2014 LOAD KING...
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
2018 HINO CONVENTIONAL TYPE TRUCK (A55745)
2018 HINO...
SKID STEER ATTACHMENT CEMENT MIXER (A58214)
SKID STEER...
