John Deere 1026r poor mowing results and poor loader dump control.
   / John Deere 1026r poor mowing results and poor loader dump control. #21
Kubota has a video that shows a comparison between the BX and 1 series. One thing they show is you can not use 2 functions of the loader at once.
   / John Deere 1026r poor mowing results and poor loader dump control. #22
It can be done, you just have to find that sweet spot. I never noticed the Rpm make a difference before, I'll have to give that a try.
To the OP, if your back gives you issues when mowing, I strongly suggest testing a ZTR in your yard before you buy it. You may be disappointed. I have a 2008 Z465, one complaint I have is the rough ride on rough terrain. I jiggle in places I didn't know I could jiggle! :) That could be a deal breaker for you if you have back issues though.
   / John Deere 1026r poor mowing results and poor loader dump control. #23
That stinks, I was thinking about trading up to the 2720. I have used other manufacturers loaders and never had this issue. John Deere needs to listen to this forum.
Yeah no doubt! Deere needs to focus on quality equipment and not on maximizing profits by making bean counter influenced machinery.
The dealer came and picked up the tractor today. They were able to see every issue except the loader issue and as I stated before it only acts up when loaded. They did tell me something that I was not aware of. There is a floating mode in the loader dump position (lever all the way to the right) that allows the bucket to float. It is possible that this the reason that the loader acts the way it does. Can anyone tell me the advantage or purpose for this feature? He also showed me how the you can position the loader to operate two functions at the same time. You had better not be in hurry if you want to use this feature. Oh well it is possible to roll the bucket at the same time you lift or lower the boom.
I will let you know how this turns out.
   / John Deere 1026r poor mowing results and poor loader dump control. #25
Here's the video of me curling while raising on my 300cx.[video]http://youtube.be/Du7oI6iHp2I[/video]
   / John Deere 1026r poor mowing results and poor loader dump control. #26
Hold on, I did something wrong trying to upload video. My first time. I'll try to get it corrected and get back to you.
   / John Deere 1026r poor mowing results and poor loader dump control. #27
I believe the extreme right float function is for a quick dump. It can be enabled or disabled with a lever / bolt under the floor. Mines disabled as I don't need it.
Yes the double action is slow. But that's why our machines aren't $60000.
   / John Deere 1026r poor mowing results and poor loader dump control. #28
Ok. I can't figure out how to get it to link here, but if you go to you tube and type in jd300cx/curl it will pop up.
   / John Deere 1026r poor mowing results and poor loader dump control. #29
   / John Deere 1026r poor mowing results and poor loader dump control. #30
I don't know if they changed anything on the 1 series, but I have a 2320, 200CX and 62D deck and I'll chime in that my loader will curl and raise/lower at the same time. It's not that hard to find the spot and even fine tune the rate of rise and curl. As others have noted, if the rpm isn't up, nothing happens very fast with the loader.
As far as the deck goes, it seems to me that two decks with the same width and same setting on the anti-scalp wheels will give the same cut, at least as far as evenness goes. LIke any 60 inch deck, mine will look pretty bad if you try to mowe short on uneven ground. I switched to Gator blades this year and I don't see a huge difference in the size of the clippings, but it does seem like the overall cut is smoother.
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
Multiquip Diaphragm Pump (A56860)
Multiquip...
2016 Bobcat E85 Midi Excavator (A56857)
2016 Bobcat E85...
New/Unused Quick Attach Auger with Three Bits (A57453)
New/Unused Quick...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
Electric Horseless Carriage (A57453)
Electric Horseless...
