FEL Snow Blade Build
/ FEL Snow Blade Build #41
Too bad you just got the welder for the tale-end of the project. That would have been a good one that would get you lots of practice. Now you have to come up with another project. :DWhat a drag. :D:
I asked about the welder because I didn't see the signs of slag-chipping along the welds on the skid shoes.
Your right about me getting the welder but I actually did have to chip off the slag on the welds your talking about. I use the flux-cored wire from lincoln.
/ FEL Snow Blade Build #43
I am not sure if you have Praxair welding supply down there but you will find their fluxcore wire is a much better weld and much cleaner once slag knocked off. Otherwisw switch to gas, but then metal has to be very nice and clean before welding.
Sorry I haven't posted anything sooner. Here are a couple pics of the finnished blade. I will try to get more posted while mounted on the loader when my yard dries up a little. I pretty much got a soaker walking to the cover-all to take the pics.
/ FEL Snow Blade Build #45
Wow, that is a excellent looking blade. Well done. Have you had an opertunity to try it out.
I've actually have been using it for the last two years. Works awesome... I was thinking of putting small sides on it to help it float a little better. It tends to want to dig into my laneway. I was also going to weld a pipe on the cutting edge which should solve the problem. Thanks for the complements.
/ FEL Snow Blade Build #47
Did you have someone roll the steel for the blade
/ FEL Snow Blade Build #49
Wow, that is really slick! Did you end up having any problems moving snow without angles and all that?
Also, is it really much different from just using the bucket?
/ FEL Snow Blade Build #50
I built a plow for mine that angles. I found that I hardly ever had a need to angle it. I am seriously thinking about doing something similar Nyen0004's setup but adding wings to the end.
I had no problem pushing, unless we get a really wet snow fall it worked great. I dont really have a long lane way so i have enough pushing power to make it all the way.
I can clean the lane way in a 1/4 of the time it would take with a bucket.
Sfrankland, I was actually thinking of making side wings. That way i wont get the spill out therefor have to make less passes.
KING CULTER FM-72-Y (A62130)
KING CULTER...
2024 Blue Diamond Trencher (A63116)
2024 Blue Diamond...
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
2021 FREIGHTLINER M2 106 S/A 4X2 24FT BOX TRUCK (A59909)
2021 FREIGHTLINER...
UNUSED CFG INDUSTRIAL MH12RX MINI EXCAVATOR (A62130)
UNUSED CFG...
2017 CATERPILLAR 420F2 BACKHOE (A60429)
2017 CATERPILLAR...
