Building The Outdoor Stairs
   / Building The Outdoor Stairs
The side look of the stairs. Formwork removed.
A look from underneath.
The look of the two top stairs. The upper one got a test putty, the lower one like the rest ones will be grinded and also puttied.
   / Building The Outdoor Stairs #82
I notice on several steps there's a shallow indentation where the riser meets the tread below it from the forms. What do you plan to do with that? I'd imagine it would trap water and freeze in the winter.
You're right. Recently I have tested my grinding tools on another project I have carried out weeks ago. It is also the stairs on my parents' tomb, which I also concreted. The diamond disc worked great, the job took not much time, just it's too much of dust. Some watering helped. Since we'll have some more comparatively warm days remaining before winter time, I hope I'll be in time to even the surfaces of those stairs this year. The puttying process will be left for next year.
Anyway, thank you for your observation. (y)
   / Building The Outdoor Stairs #84
Can tile be installed over the steps? That's too much to grind in my opinion, it will just create a mess that will be impossible to get flat. Tile would be slippery unless you could find a special tile used for steps in cold climates. I've seen them before, but couldn't guess where to buy them.
Eddie, my grinder works great and quite fast. I'll seek to make each stair under slight angle to let water to go down.
Even if I would install tile, the surfaces should be grinded, because they are very rough. In addition, the tiles accumulate moisture among and under them which freezes, experts say. Therefore, it is also not very good for open-air structures.
Thanks for advice.
   / Building The Outdoor Stairs #86
Just a suggestion - that space could be filled easily. I used a product called pli-stix. I think Ace hardware carries it here. It is a somewhat hard plastic material that you heat with a propane torch and it melts into the space. It cools and seals the space - forms a hard plastic seal. I also have gotten it from Home Depot here.
I used it and it worked pretty well. There are youtube videos about using it. It comes in black for asphalt and gray for concrete. Be sure to use the concrete one if you do. I think any product that stays in place would fill the space and prevent the accumulation of water, even if it did not seal.
I think Pli-Stix comes in about 30' strip for about $20. Best Wishes.
Oh, that top step sure looks smooth now. Might be slick. Don't make them too smooth. If smooth, even a light frost can make them dangerous.
It seems to me that the only way to beware slippage in the winter on the outside stairs is ... a handrail. :unsure::)
   / Building The Outdoor Stairs #88
All icy stairs are slippery, you can always keep a bucket of sand at the ready with a scoop nearby. You’re right, the handrails will make those stairs look and feel much safer.
Lets step aside a bit out of topic and make an interruption in our stair building process.
I know you fellows see in the pics some lack of quality on those stairs (cracks...). I've really made a mistake in one stage of concreting. But I thought it'll be even worse. Anyway I'm still optimistic. The mistakes can be fixed. Just needs more "expensive" time for that.
I'm very busy this year. That's why I'm visiting this site not often. I have individual projects with the clients' tractors, my home house (in a city) balconies' renovation, which we have just finished, my own tractor modifications, and many more jobs and thoughts.
Examples, which say more then the words, I guess.
A client purchases a 3 pt bucket from me, but wants it to be hydraulically operated. That's what it had to be arranged.
My home house in Vilnius. It was built in 1912. This is the first renovation of the balconies' since then. Totally 10 units. I'm a board member of the house community.
I'm still shocked with what happened in Ukraine. I'm in close touch with the people there. The feeling is like Muscovites are knocking at my door too.
Since the winter comes along, some jobs will be postponed, some of them will be done, then there will be time to post remarks on what was done good or bad, to describe a mistake in concrete pouring. And why has it happened.
Thank you all for the support, advices and interest shown in this thread.
   / Building The Outdoor Stairs #90
That tractor is crazy. Tires say it goes one way, steering wheel says it goes the other way. I've never seen anything like it!!!!
It moves both ways, operator seat together with a steering wheel and all control equipment rotates around. It's a BCS, 97 HP tractor.
   / Building The Outdoor Stairs #92
I was going to look it up on Youtube last night, but forgot. The thing I like the best about your posts is how different everything is there. I just find stuff like that amazing!!!!
Here is a link about it: techspecs
From my side I don't feel too many differences. Maybe it's because I see many different things all around the globe myself, and I got used to them. If the differences on my side could be noticeable from the other sides, then it's all right. The differences lead to the diversity. Hey, we're not robots yet! Aren't we? :):)
   / Building The Outdoor Stairs #94
I live a very isolated life. I try not to travel too much, I hate visiting people, and the only place I want to be all the time, is at my home. If it wasn't for websites like this, I would be completely clueless on what's out there!!!
Years ago when I've been working in the international division of Renault Corp. I was responsible for the affairs in several countries and traveled a lot. To tell you true, at the beginning the differences, which I could see even among small Baltic States were confusing me. Then I had to realize I need to find common language whatever happens. And I understood, that the differences are as a constant you should live with and to respect or even admire them. Same like a family which consists of different personalities.
Now I don't travel anymore. Internet, like for you, is a place to see what happens anywhere in the world, and to communicate. It was the websites that my eyes got used to seeing differences as a constant given. For example, the differences from my point of view between my area and North America (of course they exist and cannot be otherwise, although I have never been there) are somehow very close to me. I also find them fascinating.
   / Building The Outdoor Stairs #96
ArtMech,
One of my first jobs in my youth was working with a guy named Vilnius. He was from Lithuania. Some of my fathers side of the family fled from ******’s Germany in the early 30’s to Lithuania, then on to the US.
Do you like the European Union? Or do you wish Lithuania to be a 100% sovereign nation?
Thanks for sharing pictures of Vilnius. The balcony rehabs look real good.
ArtMech,
Hay Dude, the man's name meaning country's capital name is very rare here. At least me, I hear it the first time. But it's okay.
I remember you have mentioned somewhere in another thread you have Lithuanian roots. I thought... uh, is this world so small? But I'm sure the history of your family is very meaningful.
If Lithuania would be trying to remain sovereign nation for 100%, its destiny would be the same like Georgia's/Caucasus or Moldova's/Transnistria's. Or it wouldn't already exist anymore. Thanks to the international support of not only LTU, but Latvia and Estonia too, we are free countries sharing our sovereignty with the other members of EU. In terms of democracy, safety, economics, nature pollution, culture and many more things.
For instance we in the Baltics were selling new Renault passenger cars and LCVs up to 3.5 t. Starting at about 2000 year the numbers by each dealer were between 800-1500, or up to 2000 new vehicles a year. In Poland the sales at that time was starting from about 300-500 vehicles by a dealer. There were 2 dealers in each country, totally 6. The jump of new vehicle sales was treated as the fast economics growth in the Baltics region. That was a mutual result between businessmen and the vehicle sellers. I was on the front line of sales at that time, and I'm glad that it has happened.
Suppose if Lithuania had remained in Transnistria's place. Do you know what in general Transnistria means, or South Ossetia, or Abkhazia? Answer is - ruins... Who did that? I'm sure you know who. The fate of the Baltics would have been the same.
Indeed, we have the issues. But we know it and are seeking of their solution, and the being in EU helps much in it.
That's why no, I don't wish Lithuania to be a 100% sovereign nation, although I'm a lover of absolute freedom.
Here we don't speak about common international EU policy. That's something else.
We have had a commission today to check the quality of those balconies. You know, we found the cracks on the top layers. We'll have to fill in the claim and the foremen will be obliged to fix them. Looks like the upper layer was left uncovered, it was not moistened during curing, therefore it probably cracked.
   / Building The Outdoor Stairs #98
We were in Lithuania in July, and only went up to Kretinga on our tour. My wife and I were amazed how beautiful your country is along with Estonia.We went to 9 different countries in July and Lithuania was our favourite . Poland was least favourite.
You probably have had a cruise ship tour.
Estonia is really beautiful. There are excellent dishes at the restaurants in Tallinn. I always love to visit this country too.
Poland is comparatively big and very fast developing country with a big number of different kinds of business. Poles are nice people. They have many talented artists. We're buying steel, some food products from them. There are many things where their and our views coincide.
   / Building The Outdoor Stairs #100
So the EU protection from Soviet aggression is worth the slight loss of sovereignty?
Or am I misunderstanding?
2017 JOHN DEERE 470G LC EXCAVATOR (A60429)
2017 JOHN DEERE...
2019 F-550 Bucket Truck (A61306)
2019 F-550 Bucket...
2007 Heil Heavy Duty Aluminum Tank Trailer (A61306)
2007 Heil Heavy...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
MURRAY PUSH MOWER (A58214)
MURRAY PUSH MOWER...
