Snow Largest snowblower for a BX
/ Largest snowblower for a BX #1
Scooby074
Super Member
Nova Scotia
BX 25, ZD 326
Whats the largest snowblower that you can fit on a BX comfortably?
There are no 48-54" blowers available used here so im wondering if anyone's ever ran a larger blower on a BX?
There are lots of 72"+ machines around, but i doubt that a BX could even carry one let alone have enough hp to run it.
I missed out on a nice hardly used 54" for 1000 OBO a few weeks ago, and im kicking myself now:(
I run a 50" Buler on the back of my Bx2350, I wouldn't recommend going any larger than that. Mind you the buler blowers are way too over built and under designed, not a very efficient blower and I am looking to get rid of mine.
Interesting. Ive seen a few videos of the Buhlers on youtube and they seemed to work decent?
What are you going to go with?
If i get one im thinking Pronovost. Both Prono and woods are available locally.
/ Largest snowblower for a BX #4
Last winter we had more snow that usual in our area.I have a 60" Buhler/Farm King mounted on my BX2200 and it worked very well. If the snow is heavy/wet then the first cut must be taken fairly slow and followed by narrower subsequent cuts.
I have been extremely happy with my unit.
TGR
/ Largest snowblower for a BX #5
TGR
Wow, I can see why folks up north like the idea of a cab on their Kubota ;)
Danner, in Fort Worth...
/ Largest snowblower for a BX #6
I'll be going with the Shulte BX-62 Tractor Loader Snow Blower with the hydro pack for the pto which is hands down a better blower than the Buler,even the three point version.
Now don't get me wrong, in my thirty plus years as a pattern maker I have worked for Both Johny Buler and John Shulte and considered them both friends and whist the Buler will move snow the Shulte is just simply a better machine. It's more expensive yes, but you get a lot more bang for the buck and with the Hydro pack on the three point running off of the pto I can put the blower where it needs to be, namely on the loader lift arms. Plus the Hydro pack can be used for a whole bunch of other applications such as post hole auger, log splitter,and hedge trimmer,etc.
Last winter I installed rubber pads on the fan to get rid of the 5/8" gap between the fan tips and the fan housing which helped a lot and I replaced those saucer shaped things with proper skid skis, but it still needs a second smaller top auger a shorter three knuckle pto shaft with bearing support so that it can be moved closer to the tractor , cupped fan blades and a few other things that I just don't feel like doing.
The only reason that I have the Buler is that the wife bought the tractor for me as a birthday present last year and it came with the tractor and for no other reason.
David
TGR
Good to hear.
David
Do you think the BX can handle a 62" blower? In your first post you suggested not going above 50. A 62 and a powerpack sure isnt going to be a cheap setup unless your getting a significant discount ;)
I looked at the shulte brochure and i see what you mean. It does look heavier than whats typical around here. There are no Shulte dealers that i know of in my province however.
A dealer 200 mi away started carrying a "made in canada" blower but they dont mention the brand. If i was to guess id say its JWC, but i thought they went out of business. Im not crazy on the design. It has a flat area behind the auger and i prefer a curved area. These are cheap blowers, starting at around $1950 for a 48" IIRC. See attached image.
I have a Honda 928 blower so i know the importance of good design. That thing throws a mile. And never clogs. Thats a good design and what i want in a tractor mount if i go that way.
/ Largest snowblower for a BX #8
I've run a 60" Meteor on the back of my BX23 for the past 2 winters. I have a 1/4 mile long steep gravel driveway and it has performed flawlessly, and we get quite a bit of snow. Rear tire chains are a must for my use.
/ Largest snowblower for a BX #9
Good to hear.
Your correct, I did say I wouldn't go over a 50" blower but what I meant is that I wouldn't go over 50" with a conventional blower. The Shulte is Not a conventional blower. Most people wouldn't go for the Front mount Shulte simply because of cost as the full package would cost almost as much a Bx itself, but as I said I can use at least four implements with that one power pack and with my property being fully exposed to the north and a 1/2 mile long gravel driveway I need all of the blast that I can get.
Now the Shulte blower is not for everyone, the reason being cost but they will outperform any blower that I have seen.
If you live in town or in a different type of local l than I do than the Buler or many of the others will do the job, they just won't do it as well.
David
David
The powerpack will be nice for those other uses. Member grsthegreat just got a front mount blower for his Kioti? and posted a thread. His is a Quick Attach brand. THere is some interesting discussion in the thread, particularly about the potential for damaging the loader arms.
If anything id say a conventional would end up with more horsepower applied to it because you dont have any losses from running the hydraulic pump.
do you think that a BX could handle a shulte 62" rear mount?
I did find a Shulte dealer in the province, its the deere dealer in Halifax. Unfortunately thats a couple hours away.
/ Largest snowblower for a BX #11
Jason; Seems like the only Shulte dealers anywhere are also John Deere dealers, perhaps only people who buy jd are willing to spring for the big bucks for a Shulte. Because of the better design of this blower and depending on your snow load of course I'd say that you probably could get away with it on a Bx.
The only thing that I wish Shulte would do with the Bx series of blower would be to put in a 7" or 8" top auger but thats an easy mod to do. Two bearings an auger shaft a weld on sprocket and a longer chain ,one days work and it's done. Mind you if indeed I do order one this winter I think that I will have the top auger installed by Shulte if for no other reason than that I'm getting lazy in my old age.
David
David
Any idea how much a premium Shulte charges over say a Buhler?
I know your set on Shulte, but since you mentioned 2 auger units, have you looked at the Lorenz models? They have 2 augers, but im not crazy on the style of auger flighting they use. And they really dont appear to throw the snow very far.
rbs kubota-lorenz - YouTube
EDIT: I just found a Shulte BX62 Rear mount. $4899... Eek. That REALLY is a premium over the Woods and Puma's that sell for 2500. Unless the price on Northern is way out of whack, i dont see the value there (to me at least) http://www.tractorbynet.com/forums/...6304-largest-snowblower-bx-2.html#post2592750
/ Largest snowblower for a BX #13
Well Jason the wife payed $1600. for the Buler 500 and the price for the Shulte basic three point hitch mounted unit is $5,612.00 so you figure it out. Like I have said the full package Shulte costs as much as a Bx tractor.
As for the Lorenz I have never sen one except for pictures, I also don't really like the design with the exception of the two augers.
I used to have a Allis 10 hp garden tractor with a front mount belt driven single stage blower on it, it would move a huge amount of snow. If the blower had been a two stage that is to say with a fan the design would have been flawless. It was built much like a Honda walk behind I don't know why companies who make blowers can't simply look at these walk behind blowers and build theirs the same, just BIGGER. Design is the key, not weight.
David
/ Largest snowblower for a BX #14
David
The parasitic loss of the hydraulic system might change your thoughts!
David
I dont know why either .
The videos ive seen online of all the BX mounted blowers regardless of brand, (although some are better than others) are a little discouraging.
My 928 honda, with 9 measly horsepower, throws snow about 30'+ without breaking a sweat, yet a BX with 18hp (pto), 23 (eng) cant seem to throw half that. They both have about the same hp/inch. Its all in the efficiency of the design.
/ Largest snowblower for a BX #16
Maybe the rear mount blowers don't do well but my BX2750D does excellent. Throws snow further than my Honda walk behind and has never clogged up. Even heavy wet snow doesn't really bother it.
/ Largest snowblower for a BX #17
I run a 60" Farm King (Buhler) on the back of my BX2350. I have to say that I wouldn't want anything smaller due to the ease with which the front tires will run over the fresh snow when turning while going in reverse. For most snowfalls up to maybe 10", I can go full speed in low range and the blower/engine can keep right up. Anything more and I just slow down some. I've put it directly into snowdrifts that completely filled the intake (60"x24") and as long as I just creep it along it will blow a nice path.
Our driveway is about 1,200' long and includes a section with a 15% grade. For those reasons, I use chains all around and keep the bucket full of sand for better steering traction.
/ Largest snowblower for a BX #18
I'vebeen running a 48" Loftness blower for 6yrs now behind my BX1500 with 6" of snow no problem. 2' then snow goes over top and BX starts to lug in low range. I am really satisfied with my loftness and would buy another if need be. I would feel comfortable putting a 60" on a 23 hp given that your avg snow fall is 6"-8". when it get deep just drop speed
/ Largest snowblower for a BX #19
I'm running a Lucknow L48 on my BX25. This will be the second full winter - used it yesterday. Very satisfied with both.
Cheers Dave
I managed to find a E60 Econor with full hydraulics. However it might already be sold. Ill find out more next week but before i go any further, has anyone ran an E60 on the back of a BX?
Ive seen 60 farmkings mentioned, but the farmking is 470lbs,about the same as the Factory Kubota b2789 (51"), where the Econor minus the hydraulics is 506lbs. Add 10-20lbs for the hydraulics and your ~525lbs. I wonder if that will cause issues by making the front end too light?
When it comes to a decision, ive narrowed my choices down to just three brands (from the 11 or so i started with).
Basically it was down to fit and finish, metal thickness, skid shoes and most importantly chute rotation system.
I looked at and tried the chutes on the woods, kubota, agrotrend, pronovost, Normand (econor) and frontier. Woods and agrotrend chute rotation was very crude and stiff. That eliminated them from the competition.
THe kubota (RAD) was well made with a good rotation system, but lacked any bearings. It also had no skid shoes.
Pronovost (lynx and puma) had a good rotation system with hdpe inserts on the bearing area which made for an easy rotation.
Econor had both the HDPE inserts and ball bearings on the rotation as well. This was the best system ive seen. It also had skid shoes (i have a gravel drive) and the construction was very heavy. Its the winner by far. If the weight will work, the units not sold and hooking up aux hydraulics wont break the bank, ill likely go with the Econor
