My Harbor Freight Quick Hitch
/ My Harbor Freight Quick Hitch #201
So what do you guys do if some implements are 26.5" or 27"? Modify????
I bought longer pins and shimmed my little 4 ft disc. An all-thread pin using an inner and outer nut would have worked too.
Expect some minor modifying like this to bring everything closer to 'standard'.
My other implements matched the width close enough to connect up.
I've read here of many owners who completed 'final assembly' of their HFQH by widening its base with a Hi-Lift jack. (Called 'Farm Jack' at HF.)
Note HF sells (used to sell?) two different width Cat I QH's plus a Cat II.
I suggest measure everything you own before buying one.
/ My Harbor Freight Quick Hitch #202
"So what do you guys do if some implements are 26.5" or 27"? Modify????"
I made a combination three-point trailer hitch and quick hitch adapter for my "non-iMatch" attachments.
/ My Harbor Freight Quick Hitch #203
I've treated mine pretty rough and have had no problems with it
/ My Harbor Freight Quick Hitch #204
Runner,
You wouldn't happen to have some more pictures of your 3-pt trailer hitch and quick hitch would you?
/ My Harbor Freight Quick Hitch #205
The post above is the first I've read of someone tearing one up. Has anyone else with a 40 hp or smaller tractor done this too?
I haven't had any problems with mine in the last yr that I'v had it. I use it with a box blade and my chipper.
/ My Harbor Freight Quick Hitch #206
"You wouldn't happen to have some more pictures of your 3-pt trailer hitch and quick hitch would you?"
The quick hitch adapter also acts as a mount for my boom pole.
Here are a few pictures:
/ My Harbor Freight Quick Hitch #207
I just printed out a 20% off coupon and going to pick me up the quick hitch. They advertise the 27.5" width now....
Just in case anyone needs it...
coupon
/ My Harbor Freight Quick Hitch #208
my tractor has cat 2 hook up and my implements are cat 1 so i use the lil bushings my question is i know the hitch hooks up to the tractor as a cat 2 ok no problem there but where the implement hooks onto the QH is that cat 2 also so i would still need the bushings on the equipment its not a problem to keep it that way would it be better to get the cat 1 hitch and drill it out to cat 2
/ My Harbor Freight Quick Hitch #209
Although my quick hitch is a speeco, I ran into the same problem with my Leinbach Yard Tool aka pulverizer. Here are some pictures of the mod.
Basically I just cut the 2 angle iron strips from the main frame and moved them inwards just enough the the black arms could match up on the outside of the angle iron. Hard to explain, easy to see. Also had to notch out the angle right underneath the pin so the hitch would be able to slide under and connect.
Now after doing all that, I am ready to sell the Yard Tool because I have replaced it with a Harley Rake. :)
/ My Harbor Freight Quick Hitch #210
Picked up the 27-1/2" cat 1 HF quick hitch on Monday with a $79.99 coupon. Just looked at my rear blade and it needs the hitch adapter.
Called HF customer service and it is $17.79 with shipping, expected arrival 5 to 7 days.
In the mean time, I'll work on sandblasting and painting the rear blade and making some of the mods that others have done to their HF quick hitch, like replacing the hook bolts with pins.
Fingers crossed that the pto shaft for the brush hog extends enough to fit with the QH.
Thanks for the ideas.
/ My Harbor Freight Quick Hitch #211
/ My Harbor Freight Quick Hitch #212
Mine bent as well. Kubota l3700su. Was brush hogging, backing up and lightly tapped a tree while turning. My fault. Spread the two lower hooks enough for one of the pins to slip out. Picked up a used land pride qh. Quite a difference in the two as far as weight and construction. Haven't decided what to do with the hf qa as it could be straightened and reinforced.
/ My Harbor Freight Quick Hitch #213
Anybody have a working number for the adaptor? Everything I type in comes up blank.
/ My Harbor Freight Quick Hitch #214
What adapter?
Which post are you refering to?
/ My Harbor Freight Quick Hitch #215
Its mentioned early on in the thread that HF has an adaptor for the top hook attachment on the Cat 1 QH. It was mentioned it helps with implements that sometimes don't fit or meet Cat 1 design standards. When I search for the numbers listed, nothing comes up. It's an old thread, maybe it's not available anymore.
/ My Harbor Freight Quick Hitch #216
I needed an adapter for one implement, so I made one.
Two 3/8 x 2.5 bars about 9 inches long. Hole (3/4) in each end. Pin them on and go.
Bruce
/ My Harbor Freight Quick Hitch #217
Its mentioned early on in the thread that HF has an adaptor for the top hook attachment on the Cat 1 QH ... It's an old thread, maybe it's not available anymore.
Back then you had to call HF's Customer Service to order it. About $18 including shipping. I think this still applies today.
/ My Harbor Freight Quick Hitch #218
Try this one, 29309-0VGA
when you call to order it, may have to give them the part number for the QH and they should be able to look it up that way as a accessory for it.
/ My Harbor Freight Quick Hitch #219
I put that number into Google 29309-0VGA and it hit dozens of articles and posts confirming that's correct. Reading those links would be a good introduction for anyone who wants to know more about the QH.
When I ordered mine, I just phoned HF Customer Service and said I wanted a 'top link for a HF Quick Hitch'. She knew the number already, and wrote up the order immediately. Their order-by-phone service works pretty well.
/ My Harbor Freight Quick Hitch #220
I ordered a few of the adapters back in July. I had to call the # that is listed for questions and tell them i wanted the adapter referenced on the page of the manual. They sent it in a few days. I think they were $13 or $14 dollars a piece.:thumbsup:
2019 Freightliner 122SD (A62679)
2019 Freightliner...
2005 Dodge Caravan Van (A61574)
2005 Dodge Caravan...
2018 Navigator RT-6500 6,500lb Piggyback Forklift (A61567)
2018 Navigator...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
Brown 6' Tree Cutter (A64119)
Brown 6' Tree...
