Ballast filling tires
/ filling tires #1
Hughman
La Grange, CA
NH TC33DA
Digging a pond and thought the tractor seemed lite in the rear end with a full load of dirt in the FEL. Always went on the assumption that the dealer did what he said an filled the tires when I bought the tractor 4 years ago. Checked it (stem down) and nothing but air. Oh well.
I'm going to buy an adapter like this one. Amazon.com: Slime 20073 Air/Water Adapter: Automotive
Is there anything else I need?
Do I need to jack up the tractor to take the weight off the tires before filling them?
I was going to start with just water on the thought that any weight is better than just my box scraper.
Is there any reason to add something other than water (like anti-freeze)? It is parked in a garage and there is little to no risk of freezing temps in my area.
/ filling tires #2
Jack the tire off the ground so you can rotate. The valve stem is 2 piece, unscrew it at the first shoulder down form the cap and you adapter will screw on there. Valve stem should be at the top when filling. You may have stop water flow when close to 1/2 full and bleed the air out before finishing.
I filled mine with water first to see if it gave the results I was looking for. Now I will have to drain the water out and fill with some anti-freeze for winter.
I used the same adapter you have pictured, got mine at Tractor Supply for about $5.00, then hooked it up to the garden hose.
/ filling tires #3
Filled the tires on my John Deere 3038E this past weekend. My rear tires took less than 10 minutes per side. I rotated the valve stem to the top, attached the adapter and started filling. Just be careful when putting the air in the tires. They fill pretty quick............:thumbsup::thumbsup:
/ filling tires #4
You will probably be able to get fluid in there with that, but it just is not correct. Spend a few dollars and have one of the local tire services come out and do it right to begin with. What are the winter temps like in your area????
If you have tubeless rubber, you can use alcohol or the beat juice stuff. Either one is noncorrosive. If you have tubes, you can use calcium chloride which is much heavier, about 3 pounds a gallon heavier. A good tire service will have the proper tool to put on the valve stem and remove the inner stem at the same time.
This link is for the tool I am talking about. This is the professional model, and the service will have the pumps that go with it to get the job done quickly and easily.
Hydro Inflation Core Ejection Tool, Liquid Ballast Supplies - GEMPLER'S
Yes you can get it done cheaper, but the truely easy way is just bite the bullet and pay someone to do it right to begin with.
/ filling tires #5
i like to add non toxic rv antifreeze to mine. adds corrosion protection.. etc.
soundguy
/ filling tires
The outside temps in my area may get down close to freezing once or twice a year, but not often. The tractor always sleeps in the garage so the chances of that much water freezing is next to nothing. If it's that cold outside, I can find other things to do than play, er...uh... I mean work with the tractor. Maybe inject some anti-freeze or just drain them in the winter.
I really need to find a way to fill it my self. It's about a 90 mile round trip for the dealer to drive out to my place and I have no way of hauling it into town. At least not for just a tire fill. Save that expense for when it really breaks.
/ filling tires #7
jack, garden hose, burp valve, ballast if any.
air compressor.
all ya need.
I do all my own..
soundguy
/ filling tires #8
Im in the Northeast and I use water only. its garaged in under the house garage and no problems ..I wouldnt think youd have much trouble even in a garage.With the water you have the option to drain it for winter, or repairs.
Id like to get the el cheapo filler sometime but I just used a garden hose and stepped it down to a small hose that goes inside the stem ..
Slime Air/Water Adapter Kit - 1170832 | Tractor Supply Company
/ filling tires #9
What you have will work fine, mine was similar. I used the RV antifreez, non toxic and we can get to -15F here at times so need freeze protection. I used a simple drill pump and some garden hose. Burp often with the drill pump as it wont pump into much of a head of pressure. Air pressure builds up as the fluid goes in, due to reduced volume in the tire for air. Probably not much of a problem with the water supply pressure.
James K0UA
/ filling tires #10
Definitely fill the tires (might want to ask your dealer what happened, especially if you paid to have them filled).
But you should add ballast to your 3PH too. I use a ballast box with 600-700 lbs of sand, but a heavy implement (box blade, for example) would work too.
BTW, NAPA sells those air-liquid adapters if you want to save shipping costs.
/ filling tires #11
So do you fill them until water is all you are getting from the bleeder valve? With the valve at the top of the wheel I imagine this leaves very little room for air. Thanks.
/ filling tires #12
The manuals call for a 75% fill,. which is about where the valve stem will be when it is at 12 o'clock to not let any water out just air out when you remove the water fill valve. In other words when water stops coming out, or is more air than water then that is about right. So then screw valve stem back in and pressurize to the recommended tire pressure per the manual. Or to suit.
James K0UA
/ filling tires #13
I had my valve stem at the 10 O'Clock or 2 O'Clock position when I filled them.
But you do want them at the 12 O'Cock position when airing up or routinely checking tire pressure...
/ filling tires #14
The NAPA adapter is the one I used. Part #90-234. Think I paid $16.99.
/ filling tires #16
James K0UA
James,
My dealer used the RV antifreeze to fill mine. His argument was it is potable, so even if it does leak someday, it is not poison.
Seemed like a good idea to me:D
Be well,
David
/ filling tires #17
soundguy
Excuse the ignorance soundguy. What type of antifreeze is non toxic?
/ filling tires #18
RV anti-freeze is non-toxic. it is Propylene Glycol. Not Ethylene Glycol. It is red/pink and looks like strawberry soda. I didn't try drinking any tho.:)
a lot of food/cosmetic items have Propylene Glycol in them is some amount. When we say RV anti-freeze, we don't mean the anti-freeze in an RV's radiator, we mean the anti-freeze that is used to winterize the water systems in the RV.
James K0UA
/ filling tires #19
My dealer mixed in windshield washer fluid in my tires..not sure of the mix ratio.
/ filling tires
Does rv anti-freeze add any corrosion protection over plain water, or is it just to keep it from freezing in the winter? If I were to add anti-freeze, what mix ratio should I shoot for?
2014 DODGE RAM 2500 (A58214)
2014 DODGE RAM...
2006 Ford F-550 Flatbed Truck, VIN # 1FDAF57PX6EB82087 (A61165)
2006 Ford F-550...
2014 Bobcat T550 Compact Track Loader Skid Steer (A61567)
2014 Bobcat T550...
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A52709)
1987 CATERPILLAR...
1667 (A57192)
1667 (A57192)
2006 International 7400 SFA Terex Hi-Ranger 6TC-65 65ft. Insulated Bucket Truck (A60352)
2006 International...
