Well pump light
/ Well pump light #31
BTW: Many/most people spell gage as g-u-a-g-e, but it has become standard practice in some areas of technical writing to use g-a-g-e instead because it saves a letter. After working 20 years for a company who chose to spell it g-a-g-e, I use the 4-letter spelling to mean a physical instrument and use the 5-letter spelling to refer to a system of measurement like the gauge of a shotgun, metal gauge, or wire gauge. I suppose either spelling is proper.
:confused: Good point Jim. When I first came to NASWI I worked in the aircraft hangers. Now I work in the aircraft hangars.
/ Well pump light
thatguy, jinman's suggestion, we were just pokin a little fun, the gauge he suggested under sink is for the convenience factor.
I myself would like the light because I would know when the pump was actually cycling, I would have one mounted in my bedroom too.
My :2cents:
The more I thought about the pressure gauge vs pump light I was really getting confused.. After thinking about it way too much, I was actually going to come back and get more information on how the gauge would help me .. lol
I agree with you, I think I would rather know when the pump cycles on/off..
thanks
Brian
/ Well pump light #33
I have what many have suggested... a 120V light that is on when the pump is operating. Simply wired to one hot on the pressure switch and then to neutral.
A couple of years ago I had returned to the house from some tractor work and noticed the light on. Nobody was in the house, so no water should have been running.
Some quick investigation discovered a split supply line to the house. No telling HOW long it'd have taken without the light since that line was under the home.
Phil
/ Well pump light #34
light vs gage
guess it depends on how good you are at wiring vs. plumbing.
My gage is fairly convenient to look at, but if I was going to add one or the other, I would add the light, because for me the wiring mod would be easier than the plumbing mod.
/ Well pump light #35
thanks
Brian
Do you have any experience at all in electrical wiring, if so I will post later how I would do it.
/ Well pump light #38
Can the wiring for the light be all done in the breaker box?
My well pump is a two wire pump.
/ Well pump light #40
If you want to monitor pump cycling, no, you would need to connect to load terminal on pressure switch.
Thats kinda what I thought since my well is about a 100' from the house and is 20 years old I'd have to trench and bury a new wire back to the house four a light monitor.
I guess a pressure gage may have to do.
2018 CATERPILLAR 12M3 MOTORGRADER (A52709)
2018 CATERPILLAR...
2018 SPORTSTER BUMPER PULL (A60736)
2018 SPORTSTER...
CHALLENGER VACUUM PUMP (A60736)
CHALLENGER VACUUM...
Roto Grind 760 (A60462)
Roto Grind 760...
2014 TIELKE TRAILER 20 FLOAT UTILITY GOOSENECK TRAILER (A58214)
2014 TIELKE...
2004 INTERNATIONAL 7400 20FT TANDEM AXLE FLAT BED (A59906)
2004 INTERNATIONAL...
