Well pump light
/ Well pump light #31
BTW: Many/most people spell gage as g-u-a-g-e, but it has become standard practice in some areas of technical writing to use g-a-g-e instead because it saves a letter. After working 20 years for a company who chose to spell it g-a-g-e, I use the 4-letter spelling to mean a physical instrument and use the 5-letter spelling to refer to a system of measurement like the gauge of a shotgun, metal gauge, or wire gauge. I suppose either spelling is proper.
:confused: Good point Jim. When I first came to NASWI I worked in the aircraft hangers. Now I work in the aircraft hangars.
/ Well pump light
thatguy, jinman's suggestion, we were just pokin a little fun, the gauge he suggested under sink is for the convenience factor.
I myself would like the light because I would know when the pump was actually cycling, I would have one mounted in my bedroom too.
My :2cents:
The more I thought about the pressure gauge vs pump light I was really getting confused.. After thinking about it way too much, I was actually going to come back and get more information on how the gauge would help me .. lol
I agree with you, I think I would rather know when the pump cycles on/off..
thanks
Brian
/ Well pump light #33
I have what many have suggested... a 120V light that is on when the pump is operating. Simply wired to one hot on the pressure switch and then to neutral.
A couple of years ago I had returned to the house from some tractor work and noticed the light on. Nobody was in the house, so no water should have been running.
Some quick investigation discovered a split supply line to the house. No telling HOW long it'd have taken without the light since that line was under the home.
Phil
/ Well pump light #34
light vs gage
guess it depends on how good you are at wiring vs. plumbing.
My gage is fairly convenient to look at, but if I was going to add one or the other, I would add the light, because for me the wiring mod would be easier than the plumbing mod.
/ Well pump light #35
thanks
Brian
Do you have any experience at all in electrical wiring, if so I will post later how I would do it.
/ Well pump light #38
Can the wiring for the light be all done in the breaker box?
My well pump is a two wire pump.
/ Well pump light #40
If you want to monitor pump cycling, no, you would need to connect to load terminal on pressure switch.
Thats kinda what I thought since my well is about a 100' from the house and is 20 years old I'd have to trench and bury a new wire back to the house four a light monitor.
I guess a pressure gage may have to do.
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
DECORATIVE METAL GATE (A58214)
DECORATIVE METAL...
2022 FORD F-150 XLT CREW CAB TRUCK (A59823)
2022 FORD F-150...
INGERSOLL RAND  G25 GENERATOR (A60736)
INGERSOLL RAND...
