Well pump light
/ Well pump light #21
Another idea that might be useful: If you wire into 120v of the line in parallel, you could wire in one of those analog on/off "lamp timers" (the kind you use to turn lamps on and off while you're away from home). You plug your indicator light (I like the LED nightlight idea) into that. Then make sure all the little "switches" on the timer are set to "on", and set the timer to a known start time (say 12 midnight).
What this gets you is a way to see if the pump is on (instantaneous indicator), and also you can look at it at the end of each day to get an idea of how much total time the pump is on for any given day (long-term indicator). I specified an analog timer because a digital one may just reset when it loses power (when your pump is off, or when it's off for a while), while the analog ones just keeps advancing while power is on, and rest while the power is off.
-Mitch
/ Well pump light #22
You could just put a pressure gauge somewhere else like under your kitchen sink
/ Well pump light #24
What an incredibly simple and brilliant idea. You are one of the smartest people I know.:thumbsup::laughing:
Jinman, those Polk county boys are known for that!!!:thumbsup::laughing::laughing:
/ Well pump light
WOW.. My brain is overwhelmed with all the suggestions.. Too bad im not smart enough to quite understand all of them right off LOL
RE - pressure gauge under the sink - I can only assume that when the faucet is OFF (no water flowing) that when the pump kicks on, the pressure will change??
Brian
/ Well pump light #26
Larry, you don't have to check the tank gage. You can put a pressure gage in the cold water line under your kitchen sink; no wires - no worry. Remember, pressure is the same thoughout the system. If you want to watch your pressure and see if it is dropping, just open the door under the kitchen sink and look at the gage. If you have a leaking tank checkvalve or a leaky toilet, that gage will tell you as quickly as a light and require no wiring of any kind.
thatguy, jinman's suggestion, we were just pokin a little fun, the gauge he suggested under sink is for the convenience factor.
I myself would like the light because I would know when the pump was actually cycling, I would have one mounted in my bedroom too.
My :2cents:
/ Well pump light #27
Brian
Brian, your pump has a cut-in and cut-out pressure. So if you were to check the gauge under your sink and didn't "use" any water for say an hour, there should be no change. If the gauge drops OR if there is a rise in pressure (pump cycled at cut-in pressure), you lost some water somewhere. No change in the gauge means you have tight lines.
/ Well pump light #28
The typical pressure is 40-60 psi. The pump comes on when pressure drops to 40 psi and shuts off when the pressure rises to 60 psi. Of course, that pressure is felt anywhere throughout the system. With a pressure gage you can see just how fast the pressure is dropping. As soon as the pump comes on, the pressure will rapidly rise back to 60 psi unless somebody has water running fast enough to keep the pressure from rising. So, if pressure is holding steady or decreasing, the pump is off. If pressure is rising, the pump is on. Pressure inside the house plumbing is the same everywhere, so you can just pick the most convenient spot to mount the gage.
BTW: Many/most people spell gage as g-u-a-g-e, but it has become standard practice in some areas of technical writing to use g-a-g-e instead because it saves a letter. After working 20 years for a company who chose to spell it g-a-g-e, I use the 4-letter spelling to mean a physical instrument and use the 5-letter spelling to refer to a system of measurement like the gauge of a shotgun, metal gauge, or wire gauge. I suppose either spelling is proper.
/ Well pump light #29
bahahahaha. Guess I should have read more than the first post or two before replying.
2016 Lawnhorn Utility Trailer (A60352)
2016 Lawnhorn...
2007 FORD EXPLORER (A60736)
2007 FORD EXPLORER...
2025 GPS Trailer (A56858)
2025 GPS Trailer...
1003 (A61166)
1003 (A61166)
2019 CATERPILLAR 5K FORKLIFT GP25N (A60736)
2019 CATERPILLAR...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
