3-Point Hitch How do I keep the trailer hitch from rotating?
/ How do I keep the trailer hitch from rotating? #21
Oh, well, I'll put a picture of the one I made, since it was just scrap material I had laying around the shop.:laughing: I wanted to move the ball back from the drawbar a little so I could turn shorter. I used it quite a bit, but never did get around to cleaning it up and painting it like I intended to do.:laughing:
My scrap iron is prettier than yours. :laughing: Don't think the guy I built it for ever painted it either. :laughing:
/ How do I keep the trailer hitch from rotating? #24
Just stick a 2" receiver on your ballast box, (or most often used impliment), that way the chances of the 3pth raising are minimized and you can stick whatever you wish into the receiver as needed. (tow hook, winch, tool carrier, etc) I just leave a 1 7/8 ball on mine, its fine for moving most trailers around, even those with 2 5/16 balls, as long as they are tongue heavy
/ How do I keep the trailer hitch from rotating? #25
This is what I use to pull my trailers and some implements around. It has two receivers the top I use to attach a trailer carry all and the bottom I put my ball in and it works flawlessly. I wired a 7 pin round connector to it so I can hook up any trailer and use all of the features (brakes, lights, signals, ect.)
/ How do I keep the trailer hitch from rotating? #26
Tractor Supply has a simple lock for your drawbar. Part #1000786. $20 Simple and easy to put on and off.
/ How do I keep the trailer hitch from rotating? #27
Has anyone made a bracket to keep the trailer hitch (that piece with all the holes that fits across the quick hitch) from rotating? I want to use it to pull boat trailers and thought some of you may have already made a quick solution to this problem.
Thanks
You can buy drawbar stay straps at Tractor Supply. You need an upper and lower for each side.
Drawbar Stay Strap, Category 1, Upper - 0267953 | Tractor Supply Company
Drawbar Stay Strap, Category 1, Lower - 0267961 | Tractor Supply Company
I connected mine with the drawbar pins thru the lower hole and top link pin to upper holes. It forms a triangle and captures the drawbar so it doesn't turn.
TSC has a diagram which shows it a little different than how I connected mine, but you get the idea.
http://www.tractorsupply.com/wcssto...products/KnowHow/3-Point_Hitch_Chart_0130.pdf
/ How do I keep the trailer hitch from rotating? #28
Ok, I have my draw bar lock ....what is the round hole for?
/ How do I keep the trailer hitch from rotating? #29
404 Page not found
Just so you know, none of your links work.
/ How do I keep the trailer hitch from rotating? #31
Is this what you have?
I've seen them with and without both the big hole and the top notch. Probably some specific tractor may need clearance for a bolt, etc, in that hole's position.
Bruce
/ How do I keep the trailer hitch from rotating? #32
Bruce
I bought one of those from TSC today along with a draw bar but it only came with one bolt. Seems to me it should have two so I got another bolt before leaving the store. I wish they'd had a decent draw bar chain hook but they didn't so I settled for a clevis or what I and others call a shackle.
/ How do I keep the trailer hitch from rotating? #33
I have the Qhitch on nearly all the time. Here's something simple I made to stop the crossbar from revolving.
The little plate (one on each side) is welded to a cat1/cat2 sleeve, then that assembly is slipped on to each pin and bolted to the crossbar on the inner side and also through the hole out near the tip of the pin - out where the clevis pin could go.
This is sufficient for my 18 and 24 hp tractors pulling a 2600 lb watering trailer on rough ground.
kimg1766rqh-toplinkpins-jpg.475243
Also in that photo - I use removable pins so I can adjust the height of the Qhitch's top hook, or even to mount it upside down to hitch an implement that has interference below its top pin.
/ How do I keep the trailer hitch from rotating? #34
If you put a ball on the 3pt drawbar go buy a new coupler now, because you well bend it and the tonge of the trailer. If you are just going stright or small turns then forget what I said. Take it from someone that has been moving boats around for 45 years. That 3pt drawbar well get you sooner or later and if it's a weld on coupler you well have a lot of work ahead of you.
/ How do I keep the trailer hitch from rotating? #35
Hey guys, thanks for answering about the "hole" in the draw bar lock. Makes sense now....just couldn't see how it would serve a purpose on my particular lifting arm.
/ How do I keep the trailer hitch from rotating? #36
Thanks
Here's what I did, and it's worked pretty well but limits how tight a turn you can make. Hitch-2.JPG
/ How do I keep the trailer hitch from rotating? #37
I built one, and I use it,, occasionally.
I did use it as a stand, when I painted my Gravely, it was the perfect height!!
/ How do I keep the trailer hitch from rotating? #38
I welded a little dimple on one of my drawbar arms and used a shackle to keep it from rotating. The dimple keeps the shackle from turning off the drawbar. Cheap and simple and you can use the shackle for other things, too.
Hi Redbug, I have a Kubota LX2620 with the same 3 point hitch arms (my old tractor had the straight arms that accepted the brackets available a most farm suppliers). I just found your solution for the drawbar rotation and I'm trying to to find a clevis that fits. Can you let me know where to get the clevis in your photo? Thanks!
/ How do I keep the trailer hitch from rotating? #39
Mine is in the ballpark of Redbud's clevis.
No picture so I'll describe mine. 1 12" piece of 2" angle iron with a 3/4" bolt hole in one end, a 3/8"" hole in the other end-same side of the angle. a 5/8" bolt holds it to the bottom of the 3-pt drawbar, the other end is fastened to the pull arm with a length of 3/9=8" all-thread, with a J bend on one end holds the angle iron to the pull arm. Takes me about 5 minutes to install. Bolt and J hook nuts are finger-tightened.
The size difference of the 5/8 bolt allows the drawbar to swivel just enough to raise/lower the 3-pt enough to get under a trailer hitch and raise it into the receiver.
I mean, it's not like there will be speed involved in moving a trailer with a tractor.
I used my old TO20 to move my 24' bumper pull trailer around the farm and haul in hay from field to barn.
250 Gallon Diesel Fuel Tank w/ Pump (A64047)
250 Gallon Diesel...
2016 Nissan Altima Sedan (A61574)
2016 Nissan Altima...
2007 PETERBILT 386 T/A 6X4 SLEEPER TRUCK TRACTOR (A59911)
2007 PETERBILT 386...
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
Case 1083 20ft Corn Head (A63118)
Case 1083 20ft...
2016 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2016 UTILITY VS2RA...
