Buying Advice B2920 or B3200
/ B2920 or B3200 #1
Hotrocks
Member
BX2200HST
Hi,
As I stated in a earlier thread, I felt I was just about at my financial limit with the B2920HST with FEL and 60"MMM. After a review of the B3200 price, I may be able to swing the extra for the bigger tractor and FEL.
Question, I will use it for landscaping, brushhogging 10 to 12 acres of field with 5ft brushhog, finish mowing 2 or 3 acres, maintaining the remaining 50 acres for leisure and hunting. I have a 4 ft rototiller for garden and planting feed for deer and turkey. My land somewhat hilly, but not terrible. Can anyone see why I would need the bigger tractor? With all the woods, I still want to be nimble in the woods and felt the B2920 would fit the bill better as it is a little narrower. Thoughts and opinions? Thanks, this is a big purchase for me and I want to make the right choice.
/ B2920 or B3200 #2
I owned a B3200TLB and used a 72" Woods rear finished with it. Had great power which was great plus.The extra 3 more horse's could be a plus for you. Never heard anyone say I wish I had a tractor with less horse power.
DevilDog
/ B2920 or B3200 #3
The B3200 is bigger and with a heavier frame will handle the 5' brush hog easier than the B2920. It will also be better for ground equipment such as a box blade. The MMM for a B3200 is a ground contact mower instead of the suspended mower used on the B2920 or your BX. You adjust the mower height by adjusting the wheels. Many that buy it seem to go with the 6' version. Some have converted them by using chains to a suspended, but there seems some disatisfaction. Posibly sticking with a 5' one would be better or just use an RFM. Also the B3200 has a 4 cyl. engine. If you drive each, especially at the PTO operating speed, you will notice much more vibration in the B3200 than the B2920. So that should be part of your test to make sure you are ok with the amount of vibration at PTO speed since a lot of your time will be mowing. When we bought our B2920, we also test drove a B7800 which was before the 3200 and noticed the vibration.
The B2920 will make the better lawn mowing machine in my opinion because of its size, smoothness, and the type of MMM. But as I mentioned before, the 5' brush hog is a lot for it.
Both of these machines have the 1/4" valve instead of position control. Using a brush hog with the tractor with a 1/4" valve on the 3 pt hitch requires you to make adjustments to the mower height every 10 minutes or so or the front of the mower will be dragging on the ground. I use chains to maintain the mower height on mine now.
/ B2920 or B3200 #4
Because of what KUgator said about the 1/4" valve, and the fact you'll be cutting 10-12 acres with your brush cutter, you might want to consider a B2630. It is physically just a tad larger than a 2920, has 3 less HP (might be a big deal) but also has a position control valve on the 3 PH. It will also have a ground contact mower. The floating deck and slightly smaller size is why I went with the 2920, but I have to admit that 1/4" valve is a real PITA. I'm not real sure where the money shakes out on the 2630 versus the 3200, but it's probably fairly close.
/ B2920 or B3200
I believe you also said before I could get a 54" brushhog...but I've never seen one. Where can you by that size? Everything I see is 4,5,6 foot even. However, I do have a 42" brushhog for the BX2200, that was on it when I bought it. I really have my mind set on the B2920...not sure why I keep looking around and asking questions. I don't think I like the sounds of the B3200 MMM.
/ B2920 or B3200 #6
As mentioned, the slightly larger B3200 will handle the 5' rotary cutter better than the B2920, but it is still a tough choice for the chores you want to do. My B2620 is great with it's 4' implements in my woods since my trails are in the making, or pretty narrow, and in my small yard / field. I have a 4' rotary cutter, and am not sure I would want much more back there, but I'm not mowing any acerage either, just trimming around the edges, and perhaps 1/2 acre of open ground.
/ B2920 or B3200 #8
Ask a hundred guys? :D:D Get a hundred opinions. But seriously, you are getting key differences pointed out, and that is what makes these threads valuable.
I agree with fredhargis. So, here's my 1 in a 100 opinion. Either buy the B2620 or, if you really do want to spend more, then head right to the 30 series, with the 2630 being the right kind of machine with the right features if you want "more" machine.
/ B2920 or B3200 #9
I almost bought the B3200, but I decided to keep looking at other colors, and kept reading about all brands on this site, and after reading all the horror storys about the excessive vibration of the B3200, and comparing the cheesy construction of the Kubota verses almost every opther color, I pulled the trigger on Bobcat.
Better price point, and as far as I am concerned a much better tractor
/ B2920 or B3200 #10
Well not to start an argument here, but as far as quality and dependability and dealer support I'll take the Kubota anytime. Just look at the Bobcat forum and see how many complain about premature rusting and poor paint and weld quality. Many more talked about weather effecting the electronics. Bobcat for you but not for me. Oh by the way I owned a B3200TLB and never experienced a vibration issue at all. Only quirk I noticed was it had more power then traction, not sure if that's a bad thing.
DevilDog
/ B2920 or B3200 #11
I would have bet that Land Pride had a 54" version, but I do not see it on their website. Woods does list one. I do not know the Woods line, but they tend to get good reviews from owners.
That's what I got with my B3200, no problems so far. Seems like a good match for the tractor.
/ B2920 or B3200 #12
I am very pleased with my B3200. It has scads of power. If you are doing pto work then hp is your friend.
As for the vibration issue I hardly notice it anymore and I swear it is less now then when new.
Oh did I mention it has loads of power.:laughing:
Also you get a beefier loader with the B3200.
/ B2920 or B3200 #13
I have a B2920, and it is great for finish mowing three acres. If I had to brush hog 10 - 12 acres I would have probably moved up in size to a B3030 or B3200. I seriously considered the B3030, but the size was a little to big for the majority of the CUT stuff I need to do (and I don't need to brush hog 10+ acres).
If possible, rent the 2920 and brush hog your 10+ acres. Then you'll know for sure if it is the right machine for that job. My guess is that you will find it just a little undersized for the job if you are doing it regularly.
/ B2920 or B3200
Thanks for the info. I don't mind taking a little extra time to brush hog the field with a smaller tractor, gives me more time in the seat and in the woods where I hunt. I think the 2920 will be good for the landscaping I want to do as well near the house...not to big. I'm already in touch with Barlows crunching numbers.
/ B2920 or B3200 #15
I have the B26 which is in same size as your looking but only 19.5 pto hp and use a 5 foot landpride brush mower on and it does fine I ussually mow in Med range and only thing that slows me down is real heavy grass like switch grass. In brush it does fine and will pull 6 foot finish mower.
/ B2920 or B3200 #16
If you don't mind taking your time, then I think you will like the 2920 :)
/ B2920 or B3200 #17
I agree that the smaller B is a great size for most projects, especially close to the house, finish mowing, etc. when compared with the larger tractors. My B2620 works fine with my 4' rotary mower, but I've never had a larger one on it so I can't speak to that. I've used it to work on my trails in the woods, and it has been great there too as long as I keep things in perspective, and don't start pushing on things that are just way too large.
/ B2920 or B3200 #18
Hi,
What will this entail?
/ B2920 or B3200 #20
I'm sorry, I don't understand the question.
What will you be doing to maintain the 50 acres, bush hogging (how often), planting food plots etc., what is the makeup of the 50 acres?
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
72in Hydraulic Rotary Tiller Skid Steer Attachment (A66734)
72in Hydraulic...
Rears PT 1000 Gal Orchard Sprayer (A64911)
Rears PT 1000 Gal...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
More info coming soon. (A64557)
More info coming...
CAT 963C GP Bucket (A68134)
CAT 963C GP Bucket...
