Snow Equipment Owning/Operating Should I take the tooth Bar off my FEL to remove snow?
/ Should I take the tooth Bar off my FEL to remove snow? #1
CrestonNC
Creston, NC
Kubota L3800
Getting a new tractor this week, the bucket has as tooth bar. My driveway is gravel and gently slopping. And advice would be appreciated.
Thanks
/ Should I take the tooth Bar off my FEL to remove snow? #2
I certainly would. IF a layer of hard packed snow/ice, then I might have it on for a short while.
But it depends on what kind of a job you are happy with. :)
/ Should I take the tooth Bar off my FEL to remove snow? #3
Yes - unless you are in an area with certain melting after storms, in which case you could probably get by leaving an inch or two behind by tilting bucket to not dig in and let the rest melt. In sustained winter conditions you want to be able to scrape the packed snow-ice down with the edge of the bucket and that would be nearly impossible to do without driveway damage with teeth on.
/ Should I take the tooth Bar off my FEL to remove snow? #4
Let me make it a third vote to take it off.
/ Should I take the tooth Bar off my FEL to remove snow? #6
It looks unananimous. Take it off or you'll be digging up your gravel driveway.
/ Should I take the tooth Bar off my FEL to remove snow? #7
I'm getting a new FEL with tooth bar and was wondering the same thing...thanks too.
/ Should I take the tooth Bar off my FEL to remove snow? #8
TAKE IT OFF BABY!!!!
or.... if you can justify it, and get a good deal, buy a second bucket.
-Jer.
/ Should I take the tooth Bar off my FEL to remove snow? #9
Remove the tooth bar, it only takes a few minutes.
/ Should I take the tooth Bar off my FEL to remove snow? #10
Take it off!
It's starting to sound like a strip club in here. :eek:
Joe
/ Should I take the tooth Bar off my FEL to remove snow? #11
Well hey, if you leave it on the huge gashes in the gravel you leave behind could be used for traction :thumbsup:
/ Should I take the tooth Bar off my FEL to remove snow? #12
Is there any risk to the mounting holes while it's off??
-Jer.
/ Should I take the tooth Bar off my FEL to remove snow? #13
I don't think so unless very heavy use with lots of scraping of gravel. If you think you'd use it in that way you could presumably use same holes to mounts a removable wear bar-scraper edge.
/ Should I take the tooth Bar off my FEL to remove snow? #14
Leave it on and try it that way. If it does not work to your satisfaction then take it off.:thumbsup::thumbsup:
Might do a good job of getting rid of ice??:D
/ Should I take the tooth Bar off my FEL to remove snow? #15
Another vote for taking it off. I take mine off each year and put it back on in the spring.
/ Should I take the tooth Bar off my FEL to remove snow? #16
I have a gravel drive also and I take mine off the bucket. Merry Christmas everyone!
/ Should I take the tooth Bar off my FEL to remove snow? #17
I only put the tooth bar on if I want to dig dirt.
Don't need it otherwise. It sticks out and is too easy to hang up on things, like garage doors, etc.
Ralph
/ Should I take the tooth Bar off my FEL to remove snow? #18
-Jer.
Been using my bucket for moving snow for about ten years...no problems with the toothbar holes.
I do suggest you paint the bare metal with Rustoleam or similar though.
/ Should I take the tooth Bar off my FEL to remove snow? #19
In this part of the country, you can be moving snow one day and moving buckets of dirt the next. Think I'll leave my toothbar on and see.:confused2:
/ Should I take the tooth Bar off my FEL to remove snow? #20
Yes....
Chris
2024 Linx EQ07020RS (A60463)
2024 Linx...
2015 John Deere 3038E (A60462)
2015 John Deere...
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
2016 FREIGHTLINER CASCADIA 125 6X4 T/A MID ROOF SLEEPER TRUCK TRACTOR (A59906)
2016 FREIGHTLINER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
SDLD25 MINI DUMPER (A58214)
SDLD25 MINI DUMPER...
